Question about Foxconn NF4K8AC-RS-1.0 Motherboard
No display sir, i have: foxconn nf4k8ac rs mobo amd athlon 3000+ ati x1600 sapphire graphics card. 512 hynix pci 3200 ddr ram. it was working fine earlier(for 3 years) but now it doesnot give me display(lcd monitor goes to power saving mode). have chkd monitor,graphics card, harddisk, ram on other system and they are absolutely fine. all the fans are working.led working fine.harddisk whirring. have not chkd the processor wid oder system.. Please help me out ....
  • 358 Answers
After all your troubleshooting, I think this is likely to be as a result of your processor over-heating, maybe because of your environment, or because the fan is not cooling the processor properly again. Therefore my suggestion would be for you to unscrew your system (If you can do it by yourself), and try to clean, or better still replace your processor fan.
If you cant do it by yourself, you can easily get a technician to do it for you. This solution is actually if your processor is not yet burnt.
But if your processor is burnt, then you might have to change it to a new compatible one. but before changing it, try to test the motherboard with another working, compatible processor first, just to be more sure.
Then always make sure that your PC is in a well ventilated, cool environment and that the environment is free from dusts.
Hope this helps you out.
Posted on Jul 15, 2009
Have tried even wid crt monitor even that gives no display.
theres no on board graphics on this motherboard
  • prasad_ashu Jul 16, 2009
    cleard the processor. removd the arctic silver(or whateva mateial). no signs of burnt processor. its well ventilated,
    there was no beep frm motherboard wen i tried to boot widout any ram sticks.
    still getting the same prob
    i guess all this leads to a faulty graphics cicuitry on my mobo
    more help please....
    thanx mr damilare and niceguy for your valuable inputs.
  • 742 Answers
Resolution issue.
If you have a CRT monitor, use it to connect to the CPU. Then let's see if it works, if it does, adjust your system display resolution to 1024x??? then save then shutdown. Use your LCD now with CPU and see if you will get a display.
Another issue would be, if you are having an EXTERNAL VIDEO card overriding your built video in the mobo. Please make sure that your LCD is connected to the external video card and not in your built-in video port.
Regards
Sir! i have winfast NF4K8AC motherboard with Vga display card 128 MB DDR (ROHS Compliant Lead - Free). It was working 6 month smoothly but now I am having problem with display .I have checked the same Vga...
the drivers might not be installed correctly you might have to uninstall the graphics card restart your computer then reinstall the graphics card and its drivers
If your computer came with a motherboard disc the drivers could be on it
Click start control panel administrive tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers
hope this helps
Aug 16, 2011 | Foxconn NF4K8AC-RS-1.0 Motherboard
Will My ATI RADEON 9550 Video Card Work With GTA IV/4? the boz says: "ATI RADEON 9550 FUELED BY SAPPHIRE" "256MB DDR MEMORY" "WITH TRIXX OVERCLOCKERS UTILITY" This Is The Same As My Video Card:...
these are the specs you need!!
Minimum System Requirements
  • OS: Windows Vista - Service Pack 1 / XP - Service Pack 3
  • Processor: Intel Core 2 Duo 1.8Ghz, AMD Athlon X2 64 2.4Ghz
  • Memory: 1.5GB, 16GB Free Hard Drive Space
  • Video Card: 256MB NVIDIA 7900 / 256MB ATI X1900
Recommended System Requirements
  • Processor: Intel Core 2 Quad 2.4Ghz, AMD Phenom X3 2.1Ghz
  • Memory: 2 GB (Windows XP) 2.5 GB (Windows Vista)
  • 18 GB Free Hard Drive Space
  • Video Card: 512MB NVIDIA 8600 / 512MB ATI 3870
Jun 15, 2010 | ATI RADEON 9550 Graphic Card
Problem with my sapphire x1650 bootup
Whenever you install, add or remove hardwares from your computer, always clear the CMOS or reset the BIOS Settings. Try these methods:
http://pcsupport.about.com/od/fixtheproblem/tp/clearcmos.htm
Mar 01, 2010 | ATI RADEON X1650 Xt, (256 MB) Graphic...
Abit NF7-s - hynix ram support problem
The problem probably is you mixing fsb speed, all the cards should
be pc3200 or all of them should be pc2700.
You don't mix.
Feb 13, 2010 | Computers & Internet
Graphic card stopped working normally
Uninstall the current display drivers from the Control Panel > Remove Programs.
Then, go to Windows Update to download their version of the driver. It will work.
Aug 06, 2009 | Pine Technology XFX GeForce 9400 GT, PCI...
No display on monitor
this lead to cpu overheating problem
clean your cpu fan and put some thermal grease between the fan and cpu
Jul 17, 2009 | Foxconn NF4K8AC-RS-1.0 Motherboard
Still lagging in WoW!
Answered originally by TimIsHectic:
Assuming you mean a bad framerate and not actual 'lag', the problem would appear to exist in your processor, as it is old and outdated. and only just fits the minimum requirements to RUN THE GAME, not run the game well.
Answer: You should upgrade your CPU to a Pentium Dual-core at least.
WoW System Requirements
Processor:
Minimum: Intel Pentium 4 1.3 GHz or AMD Athlon XP 1500+
Recommended: Dual-core processor, such as the Intel Pentium D or AMD Athlon 64 X2
Memory: Minimum: 512 MB RAM (1GB for Vista users)
Recommended: 1 GB RAM (2 GB for Vista users) Video: Minimum: 3D graphics processor with Hardware Transform and Lighting with 32 MB VRAM Such as an ATI Radeon 7200 or NVIDIA GeForce 2 class card or better
Recommended: 3D graphics processor with Vertex and Pixel Shader capability with 128 MB VRAM Such as an ATI Radeon X1600 or NVIDIA GeForce 7600 GT class card or better
May 03, 2009 | Blizzard Entertainment World of Warcraft...
Old Geforce 7300 works fine on Windows XP, when I insert Ati x1600, the motherboard fan turns for two seconds, then stops, the system will not boot. I have a 400W power supply, even though the ATI X1600...
1-go into safe mood and verify that the card is recognized
2-if you cant enter safe mood for some reason use ati flash just type atiflash -i
3-if you cant boot at all then try using a pci card and check for the cards status
either your power supply is faulty or something in the bios maybe wrong......you should give more info
Apr 01, 2009 | ATI RADEON X1600 Pro 512MB AGP Graphic...
AGP texture acceleration not avalable :(
Well your card is still an ATI & things have changed a bit. You don't just need the drivers but you need ATI's Catalyst Control Center. Through the Catalyst Control Center you have a ton of control that you just don't get with drivers alone. Suggest you update windows first. You'll need .Net framework 2.0 min. Do not skip lower versions of .Net framework & only install one at a time. Install DirectX 9.0c from Microsoft here: http://www.microsoft.com/downloads/Browse.aspx?displaylang=en&categoryid=2
Than download ATI's Catalyst Software Suite File size 46.6MB:
http://ati.amd.com/support/drivers/xp/radeon-prer300-xp.html
Uninstall any other versions currently installed on your system.
If for what ever reason the uninstall fails download and run ATI's uninstaller "cat-uninstaller.exe" to clean your system from here:
http://searchna.ati.com/promosearch/?site=us-en&la=en&qt=cat-uninstaller&selectsite=ATI&sp_a=sp10039240&sp_p=all&sp-x-1=col&sp_f=ISO-8859-1&sp_q=cat-uninstaller&Search.x=9&Search.y=8
Don't forget to vote!
Dec 06, 2007 | Sapphire RADEON 7000, AGP Graphic Card
Compatible Processors
Can only support Processor: Socket 939 for AMD Athlon™ 64 and 64 FX processors
Please don't rate me Inappropriate if you don't like my solution or rate me SOLVED if you accept the reality. Thanks
Nov 22, 2007 | Foxconn NF4K8AC-RS-1.0 Motherboard
Foxconn NF4K8AC-RS-1.0 Motherboard Logo
152 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
