Question about Canon PIXMA iP1300 Printer
The ink cartridge cannot recognized (refilled 3 times)
I am having canon pixma ip1300 inkjet printer.
it worked properly till 13th april 09
i got refilled both cartridge and fix it in my printer
but the cartridge was not recognized.
i had tried installing the cartridge many times and also tried switch off and on it again many times but the printer shows the same error that
"An error occurred.Some ink cartridges cannot be recognized."
and a message box is opened and it shows that
"An ink cartridge is not installed properly.Open the printer's cover, make sure the ink cartridge is installed properly, and close the cover."
help me to recover from this problem i can't afford to buy new cartridges.
suggest me some ideas and procedures to make my printer work again.
give me the remedy as quickly as possible
Thank you
  • Anonymous Mar 17, 2014
    Cartridges are not recognized after I refilled them both last Friday. I have tried installing the cartridge many times and also tried switch off and on again many times but the printer shows the same thing:
    "An error occurred. Some ink cartridges cannot be recognized." What can I do?
I am having canon pixma ip1300 inkjet printer. it worked properly till 13th april 09 i got refilled both cartridge and fix it in my printer but the cartridge was not recognized. i had tried installing the cartridge many times and also tried switch off and on it again many times but the printer shows the same error that "An error occurred.Some ink cartridges cannot be recognized." and a message box is opened and it shows that "An ink cartridge is not installed properly.Open the printer's cover, make sure the ink cartridge is installed properly, and close the cover." help me to recover from this problem i can't afford to buy new cartridges. suggest me some ideas and procedures to make my printer work again. give me the remedy as quickly as possible Thank you
Posted on Aug 08, 2009
4 Suggested Answers
SOURCE: problem with my canon printer ip1300
You can try this it works for my 1500 printer.
Go to the printer settings and turn off the ink low messages.
Switch your printer on and hold the paper feed switch down for the count of five the orange light should flash. Then switch off the power and switch back on again the green light should stay steady. If you do not come right on this one you can email me at grayjem@mweb.co.za
Posted on Aug 10, 2009
MUKHTAR
  • 2022 Answers
SOURCE: i am having canon pixma ip1300 inkjet printer.
try to clean the print head.but it is adviseble use genuine catridges.
Posted on Dec 29, 2009
  • 232 Answers
SOURCE: ink cartridges cannot be recognized in canon printer
Hello!
Remove the cartridges and gently wipe the cartridge contacts with a dry cloth, then put them back in. Then, hold the "resume" button for 10 seconds for each cartridge, that should reset them.
If that doesn't work, one of your cartridges (sadly) needs to be replaced.
Posted on Apr 11, 2010
Cannot recognized ink in my canon pixma ip2770
i am having canon pixma ip 2700 inkjet printer. it worked properly till. I got refilled both cartridge and fix it in my printer but the cartridge was not recognized. i had tried installing the cartridge many times and also tried switch off and on it again many times but the printer shows the same error that "An error occurred.Some ink cartridges cannot be recognized." and a message box is opened and it shows that "An ink cartridge is not installed properly.Open the printer's cover, make sure the ink cartridge is installed properly, and close the cover." help me to recover from this problem i can't afford to buy new cartridges. suggest me some ideas and procedures to
Aug 31, 2012 | Canon Office Equipment & Supplies
Tip
I am having canon pixma ip1300 inkjet printer. it worked properly till 13th...
Things you will need.
Needle nose pliers.
Paper towels
97% rubbing alcohol
Plastic gloves.
Flashlight
Disposable waste container, lined with plastic.
Disposable plastic tray about 6x9 or thereabouts.
Plenty of ventilation, outside if need be.
a. With the printer on, open this lid as if to change cartridges.
b. Turn Printer off. Unplug the printer. Unattach the communication cable. You will be moving it to a work area with excellent ventilation, such as outside.
c. At the far right where the the cartridges normally park themselves when not printing you will see a platform with rectangular compartments. When the cartridges park, this platform rises, seals off the nozzle area and captures any leaking ink, which till happens today.
d. Examine the platform with your flashlight and you will see what looks like sponges in the compartments. This material with holes in it, like a sponge, is plastic.Put on your gloves.
e. Place a paper towel folded over on itself underneath this platform as best you can to catch any spilling ink.
f. Use paper towels soaked in alcohol slightly and your needle nose pliers to push
the paper towel into each compartment, gently at first, until the majority of ink is
removed.
g. This will take quite a long time and plenty of paper towels and patience. So be
patient and ready for the long haul. Avoid smoking and the fumes.
h. At some point the sponge material, itself, may become dislodged and loose.
When you witness this, go ahead and remove it carefully using your needle nose
pliers and place it on some paper towels placed inside your disposable plastic tray.
i When you have one or both, if needed or more sponges removed and in the tray,
pour alcohol over these until the ink runs pretty thin. Leave to everything to dry.
i. Use a paper towel damp with alcohol and your pliers to clean out the compartment and its sides as best you can.
j. When you have completed these tasks allow the compartments and sponges to dry.
k. You are ready to reassemble the sponges into the compartments. Do so now.
l. Nearly done; take a towel wet with alcohol and hold it very gently against the bottom of the ink cartridge until ink flows freely onto the paper towel. If its stubborn, knock
the cartridge gently but sharply against a hard surface with the alcohol soaked towel held against the nozzle area.
k. Re insert the cartridges now.
l. Return the printer to its working location, attach power, attache the comm cable and with the lid closed apply power.
m. Run your printer through its normal setup routine, deep clean the print heads, run a nozzle check and finally do a print head alignment.
m. Your Printer is now ready to be used again.
Thank you,
Worldvet
on Apr 15, 2009 | HP Officejet 5610 All-In-One InkJet...
Canon pixma ip2600 cartridge not installed properly
Please check if there is not some dirt, or something blocking the contacts from reading. Also the ink level is measured by optical sensor that can also be dirty. Also make sure you use an Original Canon cartridge. It could be the chip on the cartridge has either gone bad or could no longer be reset. The chip is what tells the printer that it is ok to print (i.e. there is ink available and that the cartridge is approved). Some chips will only be reset with available procedures a few times. Other times refillers are not succesful in resetting the chip or just give you another cartridge that is already refilled and could just happen to have a bad chip. You should probably return the cartridge and try to get one that will work based on the argument that refilling is not only related to ink but also to chip. Otherwise here is a web site that has a special page for your Pixma that contains all possible refill products: http://www.inkfilling.com/inkjet-refill-... Source(s): http://www.tonerguru.com
Aug 07, 2012 | Canon Pixma iP2600 Photo InkJet Printer
My new pixma canon ip 2770 cannot recognize the black and colored ink
May 08, 2011 | Canon Pixma iP2700 InkJet Photo Printer
Problem with my canon printer ip1300
Aug 10, 2009 | Canon PIXMA iP1300 Printer
Ink cartridges cannot be recognized in canon printer
Hello!
Apr 15, 2009 | Canon PIXMA iP1300 Printer
Canon pixma ip 1300
Make sure the cartridge is seated properly in the correct place. If the cartridge is a refilled compatible, throw it in the bin and get a new one. Approx 30% of compatibles can be faulty.
Jul 16, 2008 | Office Equipment & Supplies
Canon PIXMA iP1300 Printer Logo
3,071 people viewed this question
old marine
old marine
