Question about Vacuums
Pullman built-in vacuum cleaning system
Having problem with lose of suction
  • Anonymous Feb 23, 2008
    When my vac is sucking water, water will come out of the motor at the same time, how do I fix this problem?
  • 1,673 Answers
Is the suction poor at all inlets? If so, you may have a clog in the hose. If just certain inlets, then you may have a clog in the piping. Run a small slip of paper with a number on it (number for each port) then see which one didn't make it to your cannister. Then you will know which section has a clog. Disconnect the pipe at the cannistor, turn it on and see if the suction is good there, if not then you have a problem within the main unit.
Posted on Feb 22, 2008
Electrolux Ultraactive losing suction and turbo head brush won't spin. Canister is empty, no blockage in hose or nozzle of turbo head, filters cleaned, but Hepa not replaced recently. Could that cause it...
Hi, it's Jeremy from Crucial Vacuum.
There are a few potential solutions you should try to fix the suction of your Electrolux vacuum. The first thing you should check is the height of your brush-roll. Your height setting may be too high for the type of floor you are vacuuming. Raise or lower your brush-roll depending on if you are vacuuming on carpet, tile, or wood surfaces.The second thing you should check is the vacuum bag. If it is full your vacuum can lose suction. This is simply remedied by replacing it with a new and clean bag. The third reason for a loss of suction is your hose is clogged. Check the hose for debris or foreign objects that may be obstructing the flow of air in the vacuum. The last potential reason for your vacuum losing suction could be the brush-roll itself. If it is clogged with dirt and hair it may not be spinning and not picking anything up. Check to see the condition of your brush-roll. If it is clogged remove the debris.
You can purchase direct your Electrolux replacement vacuum parts from Crucial Vacuum with free shipping and an exclusive 10% coupon for readers, use code: FIXYA10
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
Aug 05, 2014 | Vacuums
Pullman vacuum model AS5 user manual
Hi There, The Pullman AS5 is exactly the same machine as a Cleanstar Hypervac AS5. If you email us on the VacuumSpot contact us page I can forward it to you.
May 25, 2013 | Vacuums
Does the vacuum lose suction when in the floor mode if the belt is broken?
To put it simply, no. By floor mode I'm assuming you're stopping the brush roll from turning so that you can clean hard surface floors instead of carpet. When the brush roll doesn't turn you do lose agitation which vibrates the carpet so that the dirt is more easily picked up by the vacuum. But you don't lose suction because the brush is not turning.
May 18, 2010 | Eureka Smartvac 4870 Bagged Upright Vacuum
Hello,We have an Hoover Mach 5 Cyclonic vacuum that has no suction. We have cleaned and checked all hoses, belts & filters. Please help us.
With this model, remove the dust tank, and turn it on, check for suction at the lower intake. If you have suction, install the tank and remove hose, and check for suction there. keep following until youn lose it. Then you problem will be between those 2 areas
Mar 27, 2010 | Hoover U5194-900 Mach5 Multi-Chamber...
No suction for Kenmore upright vacuum
You have not stated which model vacuum you have. Bipass vacuum have a bipass compartment which is under drive unit. Make sure there are no cracks around housing as this is where you vacuume is created. In order to have vacuum you must have airflow, in assences suction. No air flow, no suction. If the airflow is deverted somehow suction will stop. Your filter, your bag are all sources of air flow. Clog either and you lose suction. Start with loss of air, being cracks in housing,bag or filter
Feb 23, 2010 | Kenmore Vacuums
No hose suction
Clean your round filter and make sure there is nothing in the elbow tube in the bottom/back of the vacuum.
Jan 13, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Cleaner won't dispence cleaning solution
I have the same problem and each time I have to get the thing sent to Sydney to get the hose cleared out. Costing me $60 to $80 a pop.
Mar 10, 2008 | Pullman Holt Vacuums
Wet vac has no suction
check for clogs in hose. maybee clogged filter, clean or replace.
Nov 09, 2007 | Pullman Holt EVAC II 15 Gallon Wet/Dry...
Vacuums Logo
277 people viewed this question
Top Vacuums Experts
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
