Question about Dell (M6790) DVD RW Burner
I have pictures on a cd-rw, I want to add more,
It tells me its a read only, and I want to delete some pictures, but it won't let me, I would like to fill this CD with more.
  • killerwhaled Jul 15, 2009
    Hi, how are you? I am OK. I did copy the pictures I wanted to save to the desktop and put them into a folder. I then went back into the disk drive E: and looked for how to erase, I could not even find a format. The system I am on is windows XP. I put in a DVD-RW into drive E: and brought up my computer from desktop. But it said, it was not accessible and these are new. Never used.
  • 40 Answers
It looks like you haven't enabled multi-session when you wrote that disc, Even if you enable it you can't delete the files written to the disc, but you can add more files to the disc.
Data written to the disc cannot be deleted but can be erased, which would erases all the contents of the disc. Here is the work around.
1. Copy the contents of the disc to a local drive
2. Erase the disc
3. Write the required contents back to the disc and enable multi session.
Posted on Jul 15, 2009
How to burn another song?when i try it say insert a blank cd??im using cd-rw..then i try to delete some song it still on the list.. :( why??
Some where in the process there's an option called leave the session open. This tells the cd file system to allow more songs or data to be added later.
If not as you burn a track it makes the the cd read only hence the put in another blank cd even though there's plenty of room on cd and that your using cd rw
Dec 20, 2012 | Computers & Internet
I already wrote disc but how to overwrite a disc
On a CD-R, if you don't finalize or write protect the disk, can you overwrite a file?
Or in overwriting are you simply creating a second file of the same name in the TOC/directory and deleting the name, only, of the first file
You can add more data if there is space on the DVD+R, but you can't overwrite it.
You see, when a disc is burned, little microscopic ridges are put onto the disc. This is your data.
You cannot overwrite this data.
It's kind of like trying to use a permanent marker on the same spot of paper twice.
CD-ROM
Known as a read-only disc, usually used to store commercial programs and data. You can't add or delete information on a CD-ROM.
650 megabytes (MB)
Highly compatible with most computers and devices.
CD-R
You can burn files to a CD-R more than once (each time is referred to as a session), but you can't delete files from the disc. Each burn is permanent.
650 MB and 700 MB
You must close the session to read this disc in a different computer. Highly compatible with most computers and devices.
CD-RW
You can burn files to a CD-RW more than once. You can also delete unwanted files from the disc to reclaim space and add additional files. A CD-RW can be burned and erased many times.
650 MB
Compatible with many computers and devices.
DVD-ROM
Known as a read-only disc, usually used to store commercial programs and data. You can't add or delete information on a DVD-ROM.
4.7 gigabytes (GB)
DVD-R
You can burn files to a DVD-R more than once (each time is referred to as a session), but you can't delete files from the disc. Each burn is permanent.
4.7 GB
DVD+R
You can burn files to a DVD+R more than once (each time is referred to as a session), but you can't delete files from the disc. Each burn is permanent.
4.7 GB
You must close the session to read this disc in a different computer. Compatible with many computers and devices.
DVD-RW
You can burn files to a DVD-RW more than once (each time is referred to as a session). You can also delete unwanted files from the disc to reclaim space and add additional files. A DVD-RW can be burned and erased many times.
4.7 GB
You don't need to close the session to read this disc in another computer. Compatible with many computers and devices.
DVD+RW
You can burn files to a DVD+RW more than once (each time is referred to as a session). You can also delete unwanted files from the disc to reclaim space and add additional files. A DVD+RW can be burned and erased many times.
4.7 GB
DVD-RAM
You can burn files to a DVD-RAM more than once. You can also delete unwanted files from the disc to reclaim space and add additional files. A DVD-RAM can be burned and erased many times.
2.6 GB
4.7 GB
5.2 GB
9.4 GB
DVD-RAM discs can generally only be used DVD-RAM drives and might not be readable by DVD players and other devices.
hope this helps
Aug 28, 2012 | Ahead Software Nero Express 6.0 (NERO6OEM)...
My pc have SAMSUNG CD-R/RW SW-252S installed in it and os is window xp. my cd driver neither can read or burn any cd. i ran microsoft fix-it. it fixed reading problem but could not solvr the burning...
Rony, it sounds like your CD drive is dead or dying. Or, you might be running on low power. Did you add anything new, like a new video card, or anything else that would draw power to it?
Aug 28, 2011 | Samsung (sw 252 frns) CD-RW Burner
Cannot delete read only audio file from cd
You cannot delete a file from a CD-R or CD+R which is why it is a read only file. If you left the session open when you wrote to the disk you can add files to the CD. If you closed the session with your burning software it will fill the disk with blanks not allowing you to write any more files to the CD. You can Erase and Write to a CD-RW, but you will have to erase the entire disk and rewrite to it. You can copy the files to your hard drive and insert a new disk or erase the CD-RW and reburn the files excluding the one you do not want on the CD. Bottom line the CD has optical information physically burned on the CD unlike magnetic media it cannot be erased by rearranging the metal oxide making the file unreadable. Magnetic media works similar to an Etch-a-sketch where you can easily erase the image by shaking it. CD's and DVD's work like a canvas where you can paint easily, but you have to paint over the image or strip the paint to delete the image.
Apr 06, 2010 | Microsoft Windows XP Home Edition
Computer does not recognize it as a CD RW drive
When you try to write data to an optical disc, you may experience any of the following symptoms:
* You receive various disc write error messages.
* You experience issues with the drive and the built-in recording feature of Windows XP.
* You experience issues with third-party programs that you use to write data to the disc.
* You cannot read the disc in all versions of Windows.
* You cannot read the disc, or some files on the disk, by using an MP3 player.
* When you add files or folders to a disc that already contains data, some files are lost.
* Recording files to the disc is inconsistent.
* The disc recording operation is consistently unsuccessful.
TROUBLESHOOTING
Troubleshooting specific errors
If you experience one of the following errors, follow the appropriate steps to resolve the error.
* There is no disc in the drive. Please insert a writable CD into drive.
This error can occur if the CD-R drive or CD-RW drive is not recognized as a recordable device. This error can also occur if the device driver has been corrupted. To resolve this issue, see Method 3 in the "General troubleshooting" section and Method 1 in the "Advanced troubleshooting" section.
* Drive not accessible, incorrect function
This error message typically occurs when you try to write to a CD-R or a CD-RW, and the Windows XP built-in disc recording feature does not recognize the CD drive as a recordable drive. This error message may also occur if specific third-party programs are installed. For more information about how to troubleshoot this error,
when you access the CD-ROM drive, the DVD-ROM drive, or the CD-RW drive
* Error Deleting File or Folder.
Cannot delete file name. Files on this CD-ROM drive are read-only. You cannot copy or move files over to this CD-ROM drive.
This error message can occur because individual files cannot be deleted from the CD-RW. You cannot use the CD disc recording feature of Windows XP for random-access storage while you are writing to disc.
To set the service to Automatic, follow these steps:
1. Click Start, click Run, type services.msc /s, and then click OK.
2. Double-click IMAPI CD-Burning COM Service.
3. Under Service Status, click Start.
4. Try to write data to a CD.
Jan 28, 2010 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
Which dvd disks do I buy to burn a dvd on my optiarc dvd rw ad 7563a ATA Can I add later batches of pictures? can I reuse the DVD disks?
DVD media has several types:
* DVD-R ("write-once-read-many")
* DVD+R ("write-once-read-many")
* DVD-RW ("write/erase/rewritable")
* DVD+RW ("write/erase/rewritable")
* DVD dual-layer ("write-once-read-many")
Some CD/DVD-writing software allows multiple "sessions" (write a bunch of files, do not "close" the disk, much later write a bunch of files), so that you can "add" files to an "open" ("non-closed") CD/DVD disk.
Jan 24, 2010 | Gateway (5500652) (  5500652)...
I HAVE A CD - RW I WOULD LIKE TO FORMAT,IT TELLS ME THAT IT IS READ ONLY & I CANNOT FORMAT THE DISC
it is not possible to format the CD-RW, if yours is a re-writable CD then you can do that. Use NERO Burning software to Delete the Files for the re-writable CD.
Oct 26, 2009 | Computers & Internet
I can't get my cd's I recorded on my sony dvd player
Check file extensions of files on your recorded cd's. Add file extension to Roxio, Windows Media player and check your drive settings.
Apr 22, 2009 | Sony DRU840A DVD-RAM Burner
Get Error msg - RW CD is Read Only
OK for CD-RW you have to make sure you are using a burning application that allow's CD-RW. This is DIFFERENT to making a MULTISESSION disk whereby you can add file later.
If you use a CD-RW media and just burn normally, the application will finish off the disk as a CD-R media.
Basically, the disk must be 'formatted' correctly for CD-RW which will allow you to add/remove/modify the files on the CD.
Most versions of NERO should have this facility.
Mar 25, 2009 | HP Computers & Internet
Can't delete Songs.
if you have a cd rw (read/write) device and a cd rw disc then you can delete songs. same is true for dvd...must have dvd rw capabilities. if you have the rw capability, and still cannot delete then there is a problem with the hardware or software of the device or windows.
Sep 06, 2007 | Computers & Internet
Computers & Internet Logo
127 people viewed this question
Alun Cox
