Has a clear view of the sky and sometimes does it when sitting still.
Have you got a heated wind screen? reception can be interupted by this type of screen. you need an external anntena
The antenna may be unplugged. You can check by removing the SD card, carefully unscrewing the four screws from the back of the device and then running your fingernail (NOT a screwdriver) around the seam on the case to split the two halves. The antenna is the small panel on the back of the receiver, it plugs into a computer board on the inside of the receiver. Look inside for a gold colored connector, it should be plugged into one of the boards, if it is not then that's your problem, you need to plug it back into the board and you should be in good shape.
Thank you, but when I opened up the unit as you suggested the antenna was already plugged in and taped down to the board to prevent it from coming unplugged.
I appreciate your suggestion though. Any thoughts on why the touch screen is not responding either? I have tried to recalibrate it and get no response.
Rick
