Question about Bosch HBL 745 Stainless Steel Electric Single Oven
HBL 745 error code: "SVL EE CHIP/ CHT BAD OR RTDS NOT CAL". This is displayed on powerup, so display seems to be working. Buttons don't seem to do anything in this mode and oven is unusable. I believe a previous attempt to fix had replaced the display (part # 445414) and touch panel (489274), and I just replaced the temp sensor (418417) with no luck, so not sure what else could be broken.
  • markahlady Jul 15, 2009
    Thanks, will order that part and report back.
  • markahlady Aug 22, 2009
    The problem was the display board, part 445414, which has the display plus the most complex circuitry, which is maybe what you meant localwonder, although there is another board with they call the control board, part 489273, which has the relays and some power stuff and less circuitry.
    The oven now works, and when i move that bad display board to another identrical working oven, that oven shows the same problem.
    That board was replaced by Bosch for the previous owner less than a year ago so it doesn't sound very reliable.
  • 6,784 Answers
HI. this error code concerns the actual main control board. the logic chip set or, SVL EE Chip is not able to react to the resistance signal that is sent, via RTD(temp sensor). replacing the Main control Board will fix this issue.
The unit is programed to render itself inoperable in this state.(Failed Chip set). In this state, it is unable to properly regulate the heating cycle.
Posted on Jul 15, 2009
  • Michael Masters
    Michael Masters Jul 15, 2009
    Ok, i will monitor the thread for further comments...
  • Michael Masters
    Michael Masters Aug 22, 2009
    Yes you are correct. Bosch has issued numerous recalls within the following months. most are concerning the dishwasher control boards for 2005-2009. There were several touch screen boards that were recalled as well. this concerned the oven line.
    I miss-spoke, as you stated. i was referring to the actual touch pad board. this is a separate section that is linked to the main.
Thermador C302U error code
most of error codes disappear when a hard reset is done.
did u try a hard reset first?
Jun 28, 2008 | Thermador C302U Electric Double Oven
How do adjust the clock to daylight saving?
Touch TIME then the display will begin flashing timer
Use rotary knob to change this to CLOCK
Touch TIME again and it will say ENTER TIME with the time flashing
Use the rotary knob to change the time as required
Touch START and the time is now changed
Page 12 if you need it
Bosch HBL745AUC Use and Care Manual
Oct 07, 2014 | Bosch HBL 745 Stainless Steel Electric...
Hbl 745 error rtds not cal, how do i get the food out
Did you ever get an answer?? Same issue here. Oven is 10 yrs old. Had a different issue the first year & won't be buying an expensive Bosch again.
Apr 20, 2014 | Bosch HBL 745 Stainless Steel Electric...
I have a bosch Oven model HBL745A UC and the heating element at the back of the oven won't turn off.
Most likely part is the oven control board, it has relays on it . There is one stuck. IT is 2235 dollars to replace.
Dec 09, 2013 | Bosch HBL 745 Stainless Steel Electric...
Kenmore modle number 911.41185890 keeps beeping and displays fo on display and no buttons will work
Hello & Welcome to FixYa
Error code F0 is displayed due to electronic oven control failure and the only way to solve this problem is by replacing the control board which is bad. Sorry for the bad news but hope you understand... Please get back to me if you have any other questions.
Kevin
Mar 05, 2011 | Kenmore Ovens
Bosch HBN745AUC control panel broken and needs to be replaced. Any DIY advise appreciate, included the parts no. and cost information.
If you mean the glass in front of the display and touch panel is smashed, you can buy a new glass panel, about $200, part 239424 (for a stainless oven), see bosch parts link below. Probably the electronic touch sensor board underneath is fine, but its basically glued to the glass panel so will be a bit tricky to peel off and re-glue to the new one.
http://www.bosch-eshop.com/eshop(bD1lbiZjPTAwOQ==)/bosch/us/prodp.htm?prod=HBL745AUC%2f02&ESHOPTYPE=S
Jul 12, 2009 | Bosch HBL 745 Stainless Steel Electric...
HBL 745 - stopped working
seems the oven was locked by the kids by mistake - found the manual and unlocked it.
Oct 14, 2008 | Bosch HBL 745 Stainless Steel Electric...
Wall oven error code
Having the same problem.
Has anyone found a solution to this problem?
Thank you
David
m5beemer(at)gmail.com
Sep 03, 2008 | Bosch HBL 745 Stainless Steel Electric...
Bosch HBL 745 Stainless Steel Electric Single Oven Logo
260 people viewed this question
Top Bosch Ovens Experts
ashburton
reliableservice
Are you a Bosch Oven Expert? Answer questions, earn points and help others
