Question about HP LaserJet P3005 Printer
HP p3005 printer cartridge error but cartridge is ok...how to solw this error..
  • Dave King
    Dave King May 11, 2010
    Usually the errors can be reset by removing and reinserting the cartridge. When you have it out gently give it a shake side to side to redistribute the toner. Put it in and maker sure everything is inserted and closed locked properly. It should clear. If not then there is a issue with the cartridge. Have you recently replaced the cartridge? Do you have another one to try? If that doesn't clear it then what is the exact error code being shown? HP's will show a numeric code such as 051 or display a text message or both.
  • 25 Answers
The cartridge is not ok. Just because you replaced it doesnt mean its a god cartridge. You installed a bad cartridge so replace it and get your money back for the old one. P3005 printers are very intelligent!
Posted on Jul 16, 2009
Hp p3005 print cartridge stuck right side
Toner Cartridge Drive need to be change
May 12, 2014 | HP LaserJet P3005 Printer
10.10.00 supply memory error
10.00.00 SUPPLIES MEMORY ERROR alternates with For help press ? Description An error has occurred in one or more of the printer supplies. Values of xx and yy are listed below: xx
  • 00 = memory is defective
yy
  • 00 = black print cartridge
Action
  1. Turn the printer power off, and then turn the printer power on again to clear the message.
  2. If the message persists, go to this site for HP support (http://h20000.www2.hp.com/bizsupport/TechSupport/Home.jsp?locale=en_US&prodTypeId=18972&prodSeriesId=238800) .
  3. If the printer has a 500-sheet Tray 3 installed, turn the printer off again and replace the print cartridge with a new HP print cartridge.
  4. Turn the printer on again.
  5. If the error does not clear, turn the printer off and remove Tray 3.
  6. Turn the printer on and verify if the error clears.
If the error does not clear, contact HP support. reference site:http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=bpl51389#A3
Another option would be: 1. Open the top cover, remove
the print cartridge, and
reinstall it.
2. Install a new HP print
cartridge.
3. Check the connection
between the
DC controller PCA
(location J97) and the
memory chip on the print
cartridge (location J600).
4. Replace the memory chip
cable and contact assembly.
5. Replace the
DC controller PCA.
kindly read this forum 1st:http://www.fixyourownprinter.com/forums/printer/35236
Aug 26, 2011 | HP LaserJet P3005 Printer
Printer giving supply memory error
Try this:
10.XX.YY SUPPLY MEMORY ERROR
For help press
The device cannot read or write to the print cartridge
memory tag, or the memory tag is
missing.
1. Open the cartridge door.
2. Remove the print cartridge, and then
reinstall it.
3. Close the cartridge door.
4. Turn the device off and then on.
5. Verify that a genuine HP print cartridge
is installed in the device.
6. Install another print cartridge.
7. Verify that the memory tag PCA is
8. Verify that the memory tag connector is
firmly seated in connector J510 on the
ECU. You might have to remove the
main cooling fan to see this connection.
9. If the error persists, contact HP Support.
Jun 28, 2011 | HP LaserJet P3005 Printer
Hp laser jet p3005n printer 10.00.00 supply memory error
Bad toner cartridge, replace the cartridge, if this happen with a new cartridge... or re-manufactured cartridge, pack it up and send it bad for credit.
Apr 18, 2011 | HP Hewlett Packard LaserJet P3005 Printer
Error 52.00 on laserjet hp p3005
Hi there! Error 52.00 is laser scanner motor error.There could be two things causing this problem.The first one is the toner cartridge.Look at the toner and try to locate a black plastic on the top of the cartridge.It should be at the top-right and it looks like a leaver.If this plastic is broken the printer will say 52.00.The other thing that can make such an error is the motor itself.To see if the motor of the laser scanner unit is ok , you need to open the printer.If you need any other help please replay!
Apr 02, 2011 | Rhinotek HP Q7551A LY BLKHP LJ P3005 M3027
SUPLY MEMORY ERROR
Memory Supply Error 10.00.00 The printer is unable to read or write to the print
cartridge e-label, or the e-label is not on the cartridge.
Basically what is happening is the printer cannot read the small chip on the toner cartridge. The chip is located on the front right of the toner cartridge as it is inserted into the printer. 1 - Make sure the toner is firmly seated into the printer. 2 - Power cycle the printer with the toner out of the printer. Install the toner back into the printer. 3 - Install another toner cartridge. 3 - Verify that the e-label connector is firmly seated in connector.
10.00.00 Troubles shooting Link GOHERE
Contact a local HP Authorized Service Center for further assistance.
Aug 17, 2010 | HP Hewlett Packard LaserJet P3005 Printer
HP LJ p3005 dn printer will not recogonize hp print cartridge.
you may use a non genuine toner cartridge, check another working cartridge
Mar 30, 2010 | HP LaserJet P3005dn Printer
Replaced cartridge on HP P3005 printer with OEM model 51A but still get message "Order cartridge less than 100 pages."
there is 3 different ways to solve this:
1. remove cartridge and replace it again
2. you have problem whit cartridge e-label (printer can't "read" it) - replace cartridge
3. E-label reader is dirty or broken...bad, visit HP authorized service
Nov 10, 2009 | HP LaserJet P3005 Printer
In HP LJ p3005 DN Printer when i given to selftest continious blank page comes i have checked using change scanner assemblay and formetter but problem not solved pls suggest what to do
try removing the cartridge shutter, maybe is not opening. if after that you continue with the same issue without any errors there's a chance it would be the power supply
Aug 18, 2009 | HP LaserJet P3005 Printer
Error code: 49.2F9D
ok, go to the link to fix your problem--
https://forums11.itrc.hp.com/service/forums/questionanswer.do?threadId=1158526
Thanks
Nov 27, 2008 | HP LaserJet P3005 Printer
HP LaserJet P3005 Printer Logo
528 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
