Question about Hampton Bay Heating & Cooling
There is water inside the air conditioner - Hampton Bay Heating & Cooling
  • 417 Answers
It is normal for window air conditioners to have a puddle inside them during operation, actually they are designed so the evaporator fan wicks up the excess water onto the hot evaporator coils, keeping the unit cool, if it bothers you some, you can possibly adjust the outside brackets so it slants downward some or if your mechanically inclined , drill a small hole so that the water can drip outside, use caution though if drilling, be extremy careful what your doing- and make sure your not going to hit anything on the inside, you can see through the side maybe, hope that helps
J
Posted on Jul 15, 2009
Water leaking inside the house
The air conditioner should be mounted in such a way that there is a slight tilt outside to direct condensate away from the inside. Your air conditioner may be level or slightly tilted toward the inside. The installation instructions should have made this point clear
Aug 04, 2013 | Haier hwr10xc6 Air Conditioner
My Frigidaire Window Ac Unit is Collecting Water on the Styrofoam Thats Facing Inside The Home By The Vents,Why Is this Happening?
tilt your ac down on the outside,so it will drain properly,if that doesnt help,pour some bleach in the water inside to get rid of mold that clogs the drain
Apr 18, 2017 | Heating & Cooling
I have a sharp window AC unit, model af-609x. does it have a drain hole? there is no water coming out of it, but when we take it out of the window we get soaked from water somewhere inside the unitl
All window air conditioners will remove moisture from the air if there is any. Most window air conditioners collect this moisture in the bottom pan of the air conditioner and attempt to evaporate the moisture. The evaporation process works as follows: First, the water drips down off of the cold evaporator coils on the front of the unit. Then the water collects in the bottom of the air conditioner base, the "pan." If the air conditioner is installed properly it will be tilted slightly back.
The water then collects near the back of the unit. On some units, the fan blade used to cool the rear condensing coils will have a rim on the outside of the fins of the blade. This rim, or "slinger," will come close to touching the inside of the air conditioner pan when the fan is spinning. As the water collects in the pan and reaches the depth necessary for the fan ring to touch it, the ring will lift some of the water up and the fan will blow it at the condensing coils. Because the coils are warm, they will evaporate the moisture to the outside.
While this is happening it is normal to hear water splashing and sloshing around. As long as there is no water leaking inside the room that is being cooled there is no cause for concern.
Never drill into the bottom of and air conditioning unit to "let the water out."
Jul 22, 2011 | Sharp AF-M609X Air Conditioner
Our air conditioner starts dripping water inside the unit inside the house.
water dripping is to be expected, dont worry about it. But it sounds like its not tipped to the outside enough. Also check inside under the cover, if leaves and debris get stuck in there it will change the direction of the water flow.
Mar 04, 2011 | Coleman Heating & Cooling
What would cause a rooftop a/c unit to leak water inside the trailer only when the unit is running?
There is a drain to run the water outside and it is plugged...this units produces water when running as it dehumidifies the air...
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Aug 07, 2010 | Dometic Rooftop RV Air Conditioner
Carpet wet under window air con.
The air conditioner needs to be "tilted" or "pitched" to the rear. By this I mean the back (outside) should be slightly lower than the front (inside). This will allow the water to run toward the back of the unit, and drip on the ground instead of inside the house - on the floor. The A/C unit must not be level or tilted into the room (front even with or lower than the rear).
This water is the result of condensation that is created when the warm room air is drawn through the much cooler coil & fins inside the unit and is completely normal. The more humid the air inside is, the more condensation will form, and drain away.
Jul 15, 2010 | Maytag M7X05F2B Air Conditioner
I have a GE Btu 5000 and you can hear water inside of it. How do i fix it?
You're supposed to hear water inside it. That shows that it is removing the humidity from the air. If it is leaking into the room, tile the outermost end down about 1/2" lower than the inside end.
Jul 07, 2010 | GE Quiet-Aire Ductless Split System Air...
Air conditioner tary is full of water & won't cool, emptied once & it started to cool, but tray filled up again & it stopped cooling, what to do?? ??
I'm assuming the air conditioner is a window intallation. Some Air conditioners need water in the botton in order to maintain the condensator coil cool, other have a hole to drain the water. Check inside your equipment, I mean inside, open it and remember all the steps for reassemble. It is more likely inside is stuffed with dust. If its the case, use patiente, toothbrush and hose and carefull not use too much water pressure and mantain electronics and motor DRY!!!
Jun 28, 2009 | Heating & Cooling
Sunbeam air conditioner
It is normal for water to collect in the lower base of an air conditioner. See the section entitled: "There is water sloshing around inside." If water leaks out the front it is usually because the unit is tilted forward in the window frame. All air conditioners should be installed so they tilt slightly back to allow for proper removal of the condensation collected.
There is water sloshing around inside All window air conditioners will remove moisture from the air if there is any. Most window air conditioners collect this moisture in the bottom pan of the air conditioner and attempt to evaporate the moisture. The evaporation process works as follows: First, the water drips down off of the cold evaporator coils on the front of the unit. Then the water collects in the bottom of the air conditioner base, the "pan." If the air conditioner is installed properly it will be tilted slightly back.
if this helps please give me a fix ya
Jul 14, 2008 | Sunbeam Heating & Cooling
The water isn't go out
Dear miguel_5
Check the position of the ac if it is tilted too much on the inside then that could be one reason for water not flowing out other reason could be due to dust particles blocking inside.
Feb 07, 2008 | Friedrich QuietMaster Deluxe RS12L10 Air...
Heating & Cooling Logo
225 people viewed this question
Top Hampton Bay Heating & Cooling Experts
Tim Whalen
AJMAL KHAN
Are you a Hampton Bay Heating and Cooling Expert? Answer questions, earn points and help others
