Question about FrancisFrancis! X5 Espresso Machine
Frothing arm doesn't work
After 2 trips back to the Francis Francis repair center for an unrelated problem, now the frothing arm completely stopped working after weeks of getting consistantly weaker. I've considered that it might be a blockage of dried milk and tried soaking the arm in soapy hot water, which didn't work. I also tried clearing the hole in the bottom and side of the nozzle, which also had no effect.
  • 2 more comments
  • Anonymous Dec 05, 2007
    hi - i had the same issue with the froth arm you mention. What you need to do is unscrew the nozzle part at the end. Its tricky to get off, you might need needle nose pliers to unscrew. This nozzle part is probably jammed with dried milk. I used a sewing needle to poke a hole through the nozzle. To test it make sure you can blow air through it, in the direction of the machine>metal hose.
  • Tursipops Oct 08, 2008
    Thanks! I'm going to try that tonight.
  • king_zoe
    king_zoe Dec 18, 2012
    I got the nozzle off and tried blowing through it and nothing, I'm boiling it and will make sure it's not clogged, I hope this works....
  • king_zoe
    king_zoe Jan 09, 2013
    wala and that solved the problem, now I'm having trouble with the water coming out of the top of the machine to make the coffee
Same problem here but thanks to the person above I fixed it. Unscrew the nozzle, poke a needle through and bingo, all fixed
Posted on Oct 08, 2008
Francis Francis X1. Why does it work sometimes and sometimes heater trips GFCI?
take it to an appliance repair shop to have it checked out
the trip is working but if you ignore the problem you may get electrocuted
Dec 25, 2015 | Coffee Makers & Espresso Machines
1998 Crown Victora Wipers at Hi and Lo speeds work; so does intermittent wipers. However, a clicking sound from behind the glove box starts and the wipers will stop and go or retract and not come back up...
Could be the motor, or the actuator arms binding. You will have to remove the cowl cover and observe the arms in action. make sure the connector grommets are present and in good condition. If so , probably motor is overheating and tripping circuit breaker.
Mar 09, 2015 | 1998 Ford Crown Victoria
X2 francis francis trips breaker when plugged in?
Tripping the breaker is usually a bad heating element. You have to check each heating element to determine which element is bad (2 on and X2). Use an ohms meter and check the 2 elements on each boiler for a reading of between 12 and 16 ohms. If no reading that is the bad element. Its in an aluminum boiler so lubricate the end of the bolts(threads) before you try to remove them or they might break.
Apr 27, 2011 | FrancisFrancis! X1 - Stainless Steel...
Replace the frothing arm
Easiest way, unscrew the silver wand from the brass part. If you are changing the whole assembly, remove the 2 screws in the top panel to gain access to the boiler.
Apr 09, 2010 | Gaggia Classic Espresso Machine
Aeroccino deosn't make froth
Our aeroccino worked fine for 2 years and suddenly it didn't made foam anymore. We tried the "inverting trick" without much success. We contacted Nespresso and they suggested switching from regular fresh milk (we used 2%) to UHT milk (harder to find in US) and to use it cold and freshly opened. So we tried that and it works.
Hope this solution works for you too
Aug 08, 2009 | Nespresso Aeroccino Automatic Milk Frother
That replacement Saeco-Francis-Francis element
I picked up my Saeco element for my X1 repair at this location in Ricmond, British Columbia, Canada. They carry the part in stock.
The part was 48 CDN dollars.
Sep 01, 2008 | FrancisFrancis! X5 Espresso Machine
Milk not frothing
Remove the black plastic outer sleeve of the Frothing Wand (some models have a metal outer sleeve). If done correctly, the “sleeve” has been removed, but the inner wand with red or black washer, is still connected to the machine.
2) The part of the sleeve assembly that you have removed is comprised of 2 pieces, the frothing sleeve and the center piece. The center piece can be seen if you look into the top of the wand.
3) Using a pencil (eraser end), or similar shaped object, push down on the center piece until an audible “click” is heard. The “click” means that the centerpiece is back into the proper position. When in the proper position, the center piece visibly sticks out the bottom of the sleeve about ¼-inch. It looks like a bird beak.
4) Now put the sleeve back on the machine and your machine should be ready to froth again.
As for the milk island, translaltion from the italian solution using google and drying all the parts works
Aug 29, 2008 | Saeco Talea Giro Espresso Machine
Francis Francis..why do you turn off the power???
Generally in the case that a FF machine is tripping the GFI it is because the heating element within the boiler is coming in direct contact with the water. By this I mean that the coating on the element has deteriorated or the element itself split apart. This is usually do to a lack of cleaning or descaling. It is the machines defense to trip the breaker to avoid any further issues. As far as I know there is no way to repair this problem except sending it in to a repair center.
Hope this helps
Jun 26, 2008 | FrancisFrancis! X1 - Stainless Steel...
Francis Francis! x1 leaking
Well, to state the obvious, you should call Francis! Francis! at 1-877-854-4141 and ship it to them for repair. It's unlikely you can perform a fix yourself. Have you tried opening the machine up? I got PDFs of diagrams and part lists, which I obtained by calling them at the number quoted above. Good luck! Stephen
Dec 13, 2007 | FrancisFrancis! X1 - Stainless Steel...
Top shelf not cleaning
kenp, did the repairman check the screen where the chopper is located? If this screen becomes clogged with gunk, water will be restricted going to the center arm and you will either have slow or no roatation. He would of had to remove the lower spray arm, filter and accumulator assy. to get to this. I had one the other day with the exact same problem and the chopper screen was plugged completely. If your dishwasher is not working right, you have 1 year warranty, parts and labor. You have a case for them to come back. back
Feb 27, 2007 | KitchenAid 24 in. KUDI02FRSS Stainless...
FrancisFrancis! X5 Espresso Machine Logo
310 people viewed this question
Top FrancisFrancis! Coffee Makers & Espresso Machines Experts
Level 1 Expert
Joe Lalumia aka...
Joe Lalumia aka...
Are you a FrancisFrancis! Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
