Question about Yamaha YST-SW160 Subwoofer
Yamaha nx sw300
Picture but no sound at all...if I connect a different nx sw300 subwoofer box(where the sound electronics are) it works fine. So where can I get the subwoofer box repaired?
  • Timothy123 Dec 20, 2007
    I have a DVX-C300SW but the sub woofer and the left hand rear speaker don't work. The others all work fine. I have soldered the ends of the wires and have connected them correctly. Could it be a cable problem (the cable connecting the DVD player to the sub woofer)? It is a replacement cable. Help!
Ditto, i've got all 5 speakers without the Subwoofer. The subwoofer hasn't worked from day one, but I delayed replacing the unit for too long and don't have the warranty, I looked at all soldered connections and none of them have come un-soldered and all connectors are properly connected, can't think of anything but broken component that would cause it from here, nor can I think of a quick fix
Posted on Jul 04, 2008
LFE or Subwoofer
Connect the Subwoofer connection on the receiver to the LFE connection on the subwoofer.
The normal connection on the subwoofer is for connecting a full range signal, from which the sub extracts bass via its internal crossover.
Dec 05, 2013 | Audio Players & Recorders
Yamaha ns-sw300 no sound no power
The first thing id look at is the fuse you have to open this up to look at this.Look inside the fuse and see if theres a rod like thing going from end to end.If there isnt thats your problem or if you see a fog kinda thing in there or if the walls of the fuse is black like a burn would represent.Most likely this is your problem but it could be more further of a problem than i anticipate.
Mar 15, 2013 | Mackie SWA1801 Subwoofer
How to connect yamaha subwoofer nx-sw300 to technics av receiver sa-dx750
that sub was made to work just with the yamaha system, and has amplification for all the channels and a special connector. there is no adapter for use with a regular system
Mar 05, 2013 | Audio Players & Recorders
I have a yamaha nx sw150 subwoofer that i want to connect to a pioneer receiver vsx 1020 that has no system connector that the original yamaha receiver had,is it possible to connect the subwwofer to this...
Parts from all-in-one packages like this aren't inended to be pieced out to other applications. Proprietary connections are a huge clue and disincentive.
http://www2.yamaha.co.jp/manual/pdf/av/english/sys/NX-P150_e.pdf
A look at other Fixya queries gives this answer:
http://www.fixya.com/support/t4959365-yamaha_sub_woofer_model_nx_sw150
"I have this sub. The system connector jack needs a 12V DC signal to turn on. If you don't have a suitable Yamaha receiver with this connection, use any 12 V DC adapter with a 1/8 in mono plug (the tip should be positive)."
I imagine the subwoofer could be opened up and whatever circuitry is enabled by the Control signal could simply be jumpered "true" so it is always ON. That would mean the amp would be drawing power at all times, though.
Jul 31, 2011 | Yamaha Audio Players & Recorders
I have a Niles SW300 subwoofer that continues to blow fuses. I have replaced the fuse, but when it the power is plugged back in the fuse immediately blows.
ok, temporary cheap fix... (i mean in a ******* engineering kinda way ;-) . . . )
since your primary receiver has a sub-out RCA plug, you can hop into the local pawn shop, buy a cheap receiver and an RCA line splitter, and connect the primary sub-out to the CD or any input EXCEPT phono (resistance is different on the phono rca's). remove the plate from the sub and run the speaker wire from the "pawn stereo" directly to the speaker. replace plate on sub to keep box sealed, and adjust receivers to desired level of bass & volume.
You have spent $50 and now have a decent sounding system again.
Mar 27, 2011 | Audio Players & Recorders
Where can i find a dvd/reciver for the nx-sw300 home theater system/
Here's one with a subwoofer only for $120 delivered Buy It Now. You'd have an extra sub.
http://cgi.ebay.com/Yamaha-DVX-C310SW-5-CD-DVD-Changer-Subwoofer-ONLY-/170602173289?pt=Home_Theater_in_a_Box&hash=item27b8ae9369
Other possible model numbers to search for that may eventually appear ...
DVX-C310
DVR-C310
Mar 06, 2011 | Yamaha YST-SW160 Subwoofer
Wharfedale 10inch cude subwoofer that has a feedback hum when con
Hiya, try a different input cable (from amp to sub) if you have make sure that is ok.
Failing that if there is an earth in the plug, try to disconnect that (earth loop) - unlikely but hey electronics.... anything possible :)
If still there with new cable, earth off etc, then the Yamaha could have a problem but find that difficult to swallow...
Let me know if helps, see any other possibilty
Best of luck
Jul 14, 2009 | Wharfedale PowerCube PC-10 Subwoofer
Yamaha NX-SW300 sub woofer
Yes, that type of connector is often used for a VGA signal for a computer monitor. But in this case it is an all-in-one connector Yamaha used in order to simplify the hookup of this home theatre system. Unfortunately, the subwoofer is only usable with the DVR-S300 receiver/DVD player.
Apr 03, 2008 | Yamaha YST-SW160 Subwoofer
Connecting a Yamaha VX7 Subwoofer on my Yamaha HTR 5730 AV Receiver
Hello srqwrk,
You can connect the VX7 to the 5730 using an RCA Y cable like the one shown in the picture below. You get your one connection for the receiver and 2 for the VX7. These are available at any electronics store. Remember that the cable should be long enough to go from the receiver to where subwoofer will be placed.
Hope this helps. Let me know.
cancerags
Nov 26, 2007 | Yamaha HTR-5730 Receiver
Sound problems through subwoofer
check all speakers wires andcheck test mode. every thing ok, may be input wiring problem ,check every thing after that internalcircuit may be problem..
Oct 08, 2007 | Audio Players & Recorders
Yamaha YST-SW160 Subwoofer Logo
1,261 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
