Question about Kenmore 12.8 cu. ft. / 362 liter Chest Freezer 13312
I have a 20.8 cu. Montgomery Ward chest freezer that needs the insulated liner for the door. The one on mine is cracked beyond repair. Is there any place to buy one?
  • Ronda Hardy Oct 09, 2013
    I have a Montgomery Ward 18.5 cu ft freezer thats lid liner is broken beyond repair, where do I find a replacement part, it still works very well
  • Anonymous Mar 25, 2014
    door disconnected from body for temporary storage freezer now out of storage and reconnection now taking place
  • Kenmore Master
  • 1,606 Answers
Find the model number which is usually on the back , and call appliance part places .
Posted on Jul 15, 2009
Is there a reset button on montgomery ward 8838
If it is not getting cold I would first check the t-stat to see if it is operational only after seeing if there is power to the t-stat. If it is good then you most likely have a compressor problem. Check the overload on the compressor under the black cover on the side of the compressor if power is getting through that and still not running then comp is shot.
good luck
Apr 07, 2014 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Have montgomery ward chest freezer 15.8 cu. ft. model #85058 and need enter door panel. It is cracked around edge.
Sorry to read about your problem, I hope this helps you out.
you cannot find replacement parts for you unit, unless they are used. you can get a replacement compressor or probes.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 03, 2011 | Freezers
We have a 20 cu ft GE chest freezer that will only cool to 20 degrees. What can I check to determine how to fix it?
Please check : - Your door ( gasket /seals, small air leaks) - Refrigerant level - Temperature sensor for failed
Regards,
Dec 04, 2010 | GE 19.7 cu. ft. / 558 liter Chest Freezer...
The ice cream gets to hard and we have to take the big cartons out for 2 hrs before we can scoop it. (How can we bring the tempreture up about 10 or 15 deg.?)We can't find any controls on it. We have no...
Hi, I think you have tell wrong model . Please try find out the temperature controller. Your freezer should able to adjust temperature from 0 - 18 Deg. F
Chest freezer of caravell has 2 model i.e :
1. Caravell SST-5213.7 cu ft Chest Freezer With Solid Sliding Doors
  • Durable white powder coated, baked on enamel finish
  • Solid sliding top doors
  • Cord and plug included
  • Self-contained refrigeration system
  • Temp. range 0 to -18 degrees F
  • 13.7 cu ft capacity
  • Heavy duty casters included
  • Dual drain plugs for easy cleaning
  • Environmentally friendly CFC-free R-134a refrigerant and insulation
  • 115V, 4.5 Amps
  • 51 1/2"W X 25 3/4"D x 34 3/4"H
  • One year parts, 90 days labor warranty plus 3 year compressor warranty
  • & 2. Caravell GST-5213.7 cu ft Chest Freezer With Glass Sliding Doors
  • 115V, 4.5 Amps
  • Regards, jay
    Nov 30, 2010 | Caravell 13.7 cu. ft. / 388 liter Chest...
    Philco Freezer - replace/repair seal & plastic around top
    Good day,
    Unlikely you would be able to repair if the inner liner is coming apart.
    A local appliance parts house may be able to supply universal gasket to fit to the machine but again, if the inner liner is bad it could prove to be fruitless.
    Oddly enough, if you visit supermarkets you will see chest type freezers with no top at all.
    Seems like a terrible loss, but it's not.
    Cold air falls, hot air rises. When the freezer generates cold air it doesn't spill out the top. It settles into the bottom of the freezer, and stays there. Likewise, warm air rises and has no interest in going into the freezer cavity.
    Bottom line. Very little loss.
    If appearance doesn't matter, and you can get it close, you should be able to continue to use it.
    Your choice, but I thought you would like to know the physics involved here and how it does or doesn't affect you.
    Mar 28, 2010 | Kenmore 12.8 cu. ft. / 362 liter Chest...
    A manual for a montgomery ward compact freezer
    I doubt it since montgomery ward was bought out by maytag a long time ago, and now maytag got bought out by whirlpool.
    Are you having a problem with your freezer? the manual wont tell you anything about troubleshooting
    Mar 24, 2010 | Freezers
    Chest freezer lid repair
    if your freezer has the sping etc in each of the hinges, then yes take them off. If your freezer has a torshon bar type spring, DO NOT take the hinges off, as you will not get it back together
    i have always replaced liners with the door attached. The lid of the freezer is going to bow out of shape when you remove all the screws and take the old lining off, so you need to replace the lining and leave the screws loose so you can realine the door bit by bit.
    it is a bastard of a job, and i wish you all the best.
    May 01, 2009 | Kenmore 12.8 cu. ft. / 362 liter Chest...
    Frigidaire Chest Freezer Door Insulation smells like fish
    might sound stupid but take the cover off the compressor electrics and make sure no plastic is overheating.
    Oct 08, 2008 | Frigidaire 5 cu. ft. / 142 liter Chest...
    Kenmore 12 Chest Freezer - Needs New Lid
    searspartsdirect.com
    All you need is the model number
    It gives you a list of all parts you can buy to replace what's broken, as for the frost try placing a sheet of plastic over the insulation, under the the plastic cover to keep moisture and humidity out of the insulation.
    Apr 25, 2008 | Kenmore 12.8 cu. ft. / 362 liter Chest...
    Door liner on chest freezer broke due to ice build-up
    if you can't find a replacement, use a piece of flat vinyl siding that goes on houses. You can heat it and bend it as needed, or cut it and screw the pieces to a balsa wood frame for lightweight support. Glue or epoxy probably won't work as the cold temps make them brittle but external caulking may be ok to hold the pieces together. Be sure to sand all edges and corners as the cut plastic can be sharp. If you can disassemble the unit and place the door face down, you can fill the cavity with insulating foam to help stabilize it.
    Nov 27, 2007 | GE 25.1 cu. ft. / 711 liter Chest Freezer...
    Kenmore 12.8 cu. ft. / 362 liter Chest Freezer 13312 Logo
    838 people viewed this question
    Top Kenmore Freezers Experts
    Charles T Nevin
    Charles T Nevin
    AJMAL KHAN
    christian nielsen
    Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
