Question about BenQ 19" lcd black 1440 x 900 19 inch LCD Monitor
2-3-4- years old benq FP19G = returned to office after lunch - burned out electronic smell in air - whole section of office electrically dead' - did reset = computer fired up ok - but screen blank ?=led-not-illuminating... - no visable fuse to fix ' have tried alt-power-cable=nope = bright ideas invited - John :)
  • BenQ Master
  • 1,606 Answers
Benqs have had some quality control issues but from your description the inverter board went on you. It needs to be replaced or repaired. Expect to spend about $100 for the repair so you may want to consider just replacing the monitor.
They can be fixed. The monitor I am using right now was one of those dead ones. It took a few hours to find as the rest checked out and it turned out to be a bad ground. Unfortunately when you smell burnt electronics you are not going to get off that easy.
Posted on Jul 15, 2009
There's a slight burning smell coming from the dryer drum.
Some item may have gotten between the drum that rotates and the housing and during the rolling of the drum this item may be heating up from the friction. Check closely to see if you can find anything rubbing on the drum.
Jan 22, 2013 | Maytag PYE2300AY Electric Dryer
I have a frigidare dryer 5-6 years old. Recently, started smelling like something electrical is burning. If I hold down the start button the motor will turn the drum slowly and the burning smell returns....
Check for vent blockages! Overheating may be a serious issue and fire hazzard. A slow moving drum could mean a bad traction belt, jammed mechanical part or the motor is not spinning at a proper RPM which may indicate motor damage also. The electrical burning is a serious issue also and a fire hazzard. Dryers need periodical cleaning to remove excess lint, dust and debris. Lack of cleaning causes the dryer to work harder and run hotter. Excessive heat shortens the life of many parts such as belts, bearings, electronics, wiring, etc...
Sep 21, 2012 | Dryers
I have a 1990s JVC tv that we were wattching the other day then we smelled a smoky smell. Then horizontal lines and staticy sound started to go through the tv. We tried canned air to clean the vents a few...
That tv is very close to catching on fire. UNPLUG IMMEDIATELY. When electronic equipment is old they dont just stop working sometimes. Sometimes the electrical current starts burning the wires and the dust inside. there is a definare odor to electronics burning or shorting out. smell around the air vents in the back of the TV. youll know if wires were burning its a distinct odor
Jun 03, 2012 | JVC Televison & Video
MIcrowave emits an electrical smell while cooking. It still cooks, but has started emitting an odor recently when in use.
Is the smell ionized (the outside smell of a cold winter morning air) or more of an electronic component burning??? if it's more of an ionized smell it could be normal, (if the smell is strong) it could be a leaking high voltage cable (electric arching) bad insulator, if it's more of an electronic component burning smell, it could be a overheating component, in both cases you should have it checked by a professional technician...
Cheers!
Jun 25, 2011 | Sharp KB-6024MS Stainless Steel 1000 Watts...
Kenmore Elite Ultrawash, possibly 11 years old, 665.155962990 toxic burning smell pumps and electricity work reading reviews for new dw's inclines me to want to have a repairman try - if the...
If you have a belt on this machine, I would change it. If the tub bearings are worn, then the motor will spin the belt faster then the tub/drum can turn causing burning. Worn pump or tub bearings can also cause this smell. Make sure pump is clean and tight.
Dec 31, 2010 | Kenmore Dishwashers
Screen distorted and burning smell
Those dead resistors that the cause,u are smelling burning plastics.Try website Tvrepairworld.com to buy a whole convergence board for the replacement.The Samsung/Akai are using the same convergence board.
Jun 06, 2010 | Akai PT4250A 42" HDTV
Whirlpool Ultimate Care II washer went dead during fill cycle
Start with the capacitor. It has a funny smell when they go bad. The motor will smell bad as well when it burns up.
May 10, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Dryer shutting off too early. Faint smell of something burning?
Check the vent for clogging condition that will turn off unit and cause it to overheat. If vent goes up to roof check up there also - that is where mine was clogged with a sort of paper mache clog!!!!!
Sep 02, 2017 | Whirlpool LER4634J Electric Dryer
Burned electrical smell from the freezer compartment
I would check the defrost thermostat usually a button type switch with 2 wires on it mounted to the freezer coil. Size depends on type ; 1 type is about quarter size, 1 is about dime size, and electronic sensor (not had one burn out but the board could smell like your description but I believe these are not in the freezer section).
I have had these cook out and smell up the freezer section before. And if they go out guess what it wont defrost either. If your fan motor goes out it might smell and wont cool all over but the frost should be minimal.
Also a bad defrost heater could make a smelly situation it is usually a black rod or aluminum colored and the rubber ends can burn and make a smell.
If you find its the heater, I would replace the defrost thermostat as well. Its suppose to cut off the heater before it gets too hot.
If this helps you find your problem please rate me as high as possible if not please post back with more information as to what you did find. Thanks for using fix ya and good luck.
Mar 29, 2009 | Kenmore Refrigerators
HEAT PUMP/AIR CONDITIONER UNIT SMELLS ONLY WHEN AIR IS ON
Not sure what the smell...smells like.  My guess is dirt or dust near the heating elements.  These will cause a burning smell.  Sometimes insects even get into the act..building webs.
You will have to clean that area out...sometimes a large blower or vac can dislodge the dust.
Dec 04, 2008 | LG LS-K1830CL Cool Mini Split Air...
BenQ 19" lcd black 1440 x 900 19 inch LCD Monitor Logo
245 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
