Question about Maytag MAH6700AWW Neptune Front-Load Washer
My washer won't stop filling with water i changed out the water valve and still have the same problem. even when the washer goes in to a drain cycle it still fills with water.... thanks for your help
The machine states NF and the hoses are ok and not kinked, the water fills and just fills, sometimes it runs out as it's filling.
Posted on Aug 29, 2009
  • 234 Answers
Have you tried looking at the pressure switch? sometimes you can blow through the house that's attached to it and it will clearn things up. give it a try. good luck :)
Posted on Jul 15, 2009
  • Ned Halaweh
    Ned Halaweh Jul 15, 2009
    have you tried looking at the pressure switch? sometimes you can blow through the house that's attached to it and it will clearn things up. give it a try. good luck :)
Cold water won't stop before rinse cycle
if it fails to stop running only at the rinse part of the cycle it is probably in the timer as the solenoid valve has to cut the water off when the washer fills for the wash cycle too. fills for wash cycle and cuts off water, washes and drains, refills for rinse cycle and water just keeps running? does this every time you run it? that's in the timer. bad solenoid (water inlet valve) would keep running even on wash fill up. hope this helps.
Feb 25, 2014 | LG WM2688H Front Load Washer
Whirlpool washer model lsr8233eqo
So when the cycle first starts, it will fill and agitate and spin. But then on the rinse cycle it stops?
Feb 03, 2013 | Whirlpool Washing Machines
My maytag mtw5600tq1 washer won't hold water. Its
Its sounds like you have a siphon going on, this happens when the drain hose it too low during fill and as the water enters the unit it exits through the drain hose. To stop this the drain hose needs to be higher than the tub itself, meaning: raise the drain hose behind the washer to about control panel area. This will or should stop the siphon effect and allow the water to remain in the tub. If the drain hose is low this siphon will start again.
I hope this helps
Aug 26, 2011 | Maytag Washing Machines
Hi...my washer goes through cycles and then stops at "light" . It won't go through rinse and spin. Help
Make sure your cold water tape is turned on and the screen in the water valve is not plugged up, it may be trying to fill with cold water and cant get any, try filling the washer with cold water on a "wash" cycle to confirm it it fills with "cold" then just the rince cycle ion the timer may be faulty and would need to be replaced
Aug 25, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
My washer goes through the cycle but the cold
This sounds like your water fill valve is bad and will need to be replaced.
Feb 01, 2010 | Maytag LAT2300 Top Load Washer
Washer stops after aggatating and wont drain
My Kenmore 70Series washer goes through the wash cycle then just stops when it is to drain and then spin.
Jun 10, 2009 | Whirlpool Washing Machines
Washer fills up than starts draining while in wash cycle
Hello , here is the fix-your drain hose is placed to low in the drain line in the wall, it can not be placed in water or it will siphon the water out of your washer into the drain pipe and it wont stop until it hits air. try pulling your drain hose up and out of the drain and get a zip tie or cable and tie it to one of the water valves by the drain pipe placing the end of the drain hose about 5-6 inches inside the drain pipe. Let me know if you have any other questions and good luck it will work.
Phil
Jan 28, 2009 | Frigidaire FLEB8200DS Top Load Stacked...
Washer Dryer - drum is filled with water even when switched off and door can still open!
Try the valves inside the back where the water hoses connect to the machine they should default to the closed position when water is not required
Oct 31, 2008 | De Dietrich LZ9619 Front Load Washer /...
Won,t drain on rinse cycle
There could be several causes for this, but probably a bad timer. One test for this...when it stops...is to turn it off...and turn the timer slightly clockwise...to the middle of the rinse cycle...and turn it back on. Does it run then?? Try advancing it to the spin cycle after the rinse. If it runs okay after you manually advance the knob...the timer is probably defective.
Jan 13, 2008 | GE WNCD2050AWC Top Load Washer
Maytag MAH6700AWW Neptune Front-Load Washer Logo
186 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
