Question about Sony Grand WEGA KF60XBR800 60" Rear Projection Television
How too remove the lamp?
How to take the lamp out and replace it
    President:
  • 788 Answers
You can download the manual from the following link and the lamp instructions are on pages 13-16.
It is a very large file, about 10 megs.
http://www.docs.sony.com/release/KF60XBR800.PDF
It is fairly straight forward and is located under the right front cover.
The only issue is that Sony uses an allen wrench instead of a screw head.
You can also get the lamp from the following site.
Their site is http://www.andrewselectronics.com/welcome.aspx
And their phone number is a 24-Hour Order Desk: (800) 274-4666
I recommend the phone order so you can talk to the person about price and availability.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
Please Note: If you cannot rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
If you need further assistance please comment to this post and I will try to help you further.
Posted on Jul 16, 2009
HOW DO I REPLACE THE LAMP
Hello
To replace lamp in JVC projection TV follow the steps below.
[1]. Order a compatible replacement lamp from JVC. Order a replacement lamp from JVC's Accessory Store or a local authorized parts distributor to ensure that you obtain a compatible replacement lamp. To order a replacement lamp, you must have the lamp type and lamp code of your JVC projection TV, which can be found on the rear of the television.
[2]. Turn off the television and allow the bulb to cool. For safety reasons, turn off and unplug your television before accessing any of its internal components. Wait at least 20 minutes before attempting to replace the lamp so that it has time to cool down. If the back of the television is not warm or hot to the touch, it is safe to begin removing the lamp
[3]. Unscrew and remove the lamp door. The lamp door on JVC projection TVs is located on the rear left of the television and is shaped like a square. Several warnings related to the lamp will be printed on the door. Use a Phillips-head or flathead screwdriver to remove the large screw, then remove the door
[4]. Unscrew and remove the lamp assembly unit. After you have removed the lamp door, you will see the lamp assembly unit. Use a Phillips-head screwdriver to remove the two screws. One screw is on the top right corner of the unit and the second screw is on the bottom left corner of the unit. Detach the lamp assembly unit from the compartment by lifting the handle and pulling the unit away from the television
[5]. Install the replacement lamp and secure the lamp door. Hold the replacement lamp assembly unit by the handle and insert it straight into the compartment. Reinsert and tighten the two screws onto the lamp assembly unit with a screwdriver. Place the lamp door back onto the television and tighten the screw to secure it to the television
[6]. Reset the television's lamp timer. Press "Menu" on the television's remote, then scroll to and select "Lamp Timer Reset." Press "OK" to rest the timer. A prompt will appear notifying you that the timer has successfully been reset
May 18, 2011 | JVC HD-61Z786 61" Rear Projection HDTV
Tag light is not working. is there a fuse that will get the light turned back on?
The fuse labeled REAR PARK LP 15A in the right instrument panel fuse box powers the rear park lamps, and the tag lamps. If your rear park lamps are working then you most likely need to replace the tag lamps (bulbs). Use the following procedure to replace the lamps.
To Remove:
  1. Remove the two mounting screws from the license plate lamp.
  2. Remove the license plate lamp from the rear bumper fascia.
  3. Remove the license plate lamp socket by turning it counterclockwise.
To Install:
  1. Install the license plate lamp socket by turning it clockwise.
  2. Position the license plate lamp to the rear bumper fascia.
  3. Install the license plate lamp mounting screws.
Feb 17, 2011 | 2004 Chevrolet Impala
How to replace a bulb for kd rangehood
This is for a smeg KD series, it depens on the model which lights are used.
LIGHTS REPLACEMENT:
Before performing any cleaning and/or
maintenance operation, disconnect the hood
from the mains supply.
According to the model, the hood can be equipped
with different kind of lighting such as incandescent,
halogen and neon lamps.
a) Incandescent lamps: E14 – 40W 230V lamps.
To replace them, remove the transparent fixture
from the control panel, unscrew the lamp and
screw in the new one.
b) Halogen lamps: G4, 20W - 12V lamps . To
replace the lamp, use a screwdriver to remove
the glass-supporting ring. Then remove the old
lamp and insert the new one.
Put the glass back, securing it with the ring.
c) Biax neon lamps: G23 11W lamp. Once the
fixture has been removed, remove the biax lamp
from its seat and support.
Put a new lamp in, performing the same
operations backwards.
d) Neon lamp: 15/18W neon tube. To reach the
neon tube, unscrew the glass framework screws.
Rotate the tube 90 degrees and remove the neon
lamp. Install the new neon tube and put the glass
framework back.
Hope this helps
Apr 13, 2010 | Kitchen Ranges
How do you replace the tail light bulbs on a 2006 Pontiac Vibe
Tail Lamp: Service and Repair
TAIL LAMP REPLACEMENT
REMOVAL PROCEDURE
1. Open the rear compartment lid.
2. Remove the rear compartment trim panel (4).
3. Disconnect the tail lamp electrical connectors.
4. Remove the following components from the vehicle:
- The 3 nuts (3)
- The tail lamp (7)
5. Remove the following from the tail lamp:
- The stop lamp socket (2)
- The turn signal lamp socket (5)
6. Remove the following from the lamp sockets, if necessary:
- The stop lamp bulb (1)
- The turn signal lamp bulb (6)
INSTALLATION PROCEDURE
1. Install the following to the lamp sockets, if removed:
2. Install the following to the tail lamp:
3. Install the tail lamp (7) to the vehicle. Secure the tail lamp (7) with the 3 nuts (3).
NOTE: Refer to Fastener Notice in Service Precautions.
Tighten the tail lamp nuts to 10 N.m (89 lb in).
4. Connect the tail lamp electrical connectors.
5. Install the rear compartment trim panel (4) to the vehicle.
6. Close the rear compartment lid.
Oct 30, 2009 | 2003 Pontiac Vibe
How do i replace the lamp
remove the lamp door on the bottom, remove the lamp (2 or 3 screws), replace with new lamp, replace door, reset lamp timer (menu-settings-reset lamp timer-yes).
Oct 27, 2009 | Sanyo PLC XU35 Multimedia Projector
remove the lamp door, remove the old lamp (2 or 3 screws), replace with new lamp, replace door, reset lamp timer (menu-settings-reset lamp timer-yes).
Oct 15, 2009 | Sanyo PLC-XP55 Multimedia Projector
Lost the manual - I am replacing the bulb
remove the lamp door, remove the lamp (2 or 3 screws), replace with new lamp, replace door, reset lamp timer (menu-settings-reset lamp timer-yes).
Oct 08, 2009 | Sanyo PLC XU35 Multimedia Projector
Right rear signal light needs replacing
you need to remove the lamp assembly to replace the bulb. here is the procedure:
Rear Lamp Assembly —Sable Four Door Removal and Installation
  1. Remove the luggage compartment scuff plate.
  1. Pull back the luggage compartment carpet.
  1. Disconnect the rear lamp assembly electrical connector.
  1. Remove the nuts.
  1. Remove the rear lamp assembly.
    1. Pull the lamp assembly away from the body.
    1. Disconnect the rear lamp assembly bulb connectors.
  1. s1h~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: To prevent water from entering the luggage compartment, make sure the rubber grommet is fully seated.
    To install, reverse the removal procedure.
Jun 25, 2009 | 2001 Mercury Sable
NEED TO REPLACE A TAIL LIGHT BULB IN A 2005 CHEVROLET IMPALA
and Repair Notes TAIL LAMP REPLACEMENT REMOVAL PROCEDURE Open the rear compartment. Remove wingnut and pull back the rear compartment trim panel from the tail lamp. Remove the wingnuts from the tail lamp. Remove the tail lamp from the rear body panel. Disconnect the electrical connector from the tail lamp. Remove the tail lamp socket, turning counterclockwise. Remove the bulb from the tail lamp socket. Remove the sidemarker lamp socket, turning counterclockwise. Remove the bulb from the sidemarker lamp socket. INSTALLATION PROCEDURE Install the bulb to the tail lamp socket. Install the bulb to the sidemarker lamp socket. Install the sidemarker lamp socket, turning clockwise. Install the tail lamp socket, turning clockwise. Connect the electrical connector to the tail lamp. Install the tail lamp to the rear body panel. Install the wingnuts to the tail lamp. Pull back the rear compartment trim panel to the tail lamp and install the wingnut. Close the rear compartment.
Jun 08, 2009 | 2005 Chevrolet Impala
Replacement lamp
Remove the front cover from the TV set. This is held by a snap on. Pull the front cover outwards until the quick snap on disengages.
Remove the screw securing the lamp cover with a Phillips head screw driver
Remove the two screws that hold the lamp in place. Remove the lamp unit by holding the lamp handle, then pulling outwards.
Exercise caution when removing the lamp unit to avoid injury to your fingers
Replace with the new lamp.
Place the removed lamp into the empty box of the replacement lamp. Do not touch the front glass of the new lamp or its
receptacle. This may shorten the life of the lamp and reduce the picture quality.
• Push the lamp unit back to its original position.
• Tighten the screws firmly on the lamp unit. If they are loose, the TV may not operate correctly. Install the front cover. There is also a video on youtube just do a search on how to install a projection lamp. Hope this is helpful
Aug 22, 2008 | Hitachi 50V715 50" Rear Projection...
Sony Grand WEGA KF60XBR800 60" Rear Projection Television Logo
142 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
