Question about GE (PSS26MSRSS) Side by Side Refrigerator
The freezer is heating up at the botton in the back of the freezer it has heat and is red. The ice is melting and nothing is staying cold. Buts it only the freezer nothing else.
  • GE Master
  • 1,606 Answers
The red is the defrost heater , defrosting the evaporator coils . There is also a thermostat which cuts the heater off when it gets to 140 degrees (max) behind the freezer wall . The main control board will (should) terminate the defrost cycle in about 32 min. Only the frozen food keeps the freezer cold during this time .
Posted on Jul 15, 2009
Freezer side not cold enough, similar temperature as Refrigerator side
It could be many things. My first guess would be the defrost. The coil that gets cold in your freezer builds ice on it and the only way to get the ice off is to run a heater near the coil long enough for the ice to melt. All freezers have something built in to defrost and domestic are typically just an electric heater on a timer. When your freezer stops working again, you may want to pull open the panel of your freezer and see if your coil (a heat exchanger that probably looks a lot like your car radiator) is covered in ice. If it is, it could be the timer or the actual heater that is bad.
Nov 12, 2013 | Refrigerators
The freezer department is making snow and the vents blocked with ice. now the refrigerator compartment is warm. i have the freezer temp on cold and the refrigerator between normal and colder. what should i...
If the freezer is cold the compressor is Ok. Now if its a two door fridge . Open both the doors while the fridge is On. Press the lower door switch ( the lower light should turn off and you should hear the fan humming sound come on ). While holding the door switch pressed close the freezer door, you should see cold air come out of the slits in the back of the lower compartment. If not icicles have blocked the passages due to the non working of the heating coil.The heating cycle is controlled by the timer switch located near the compressor at the back. Unplug the fridge and remove the timer switch.Note the color of the wires and mark on the old switch. Replace and it will work.Only frost free fridges have heating cycle.
The cold air passage in a modern fridge is made out of thermocole . It will take you more than 24 hours of defrosting to remove the ice. I had to use a hair dryer to melt the ice even after 30 hours. Thermocole is a fantastic insulator.If you want to avoid melting the insulator blow air into the vent from the refrigerator compartment using a vacuum cleaner in blower mode ( reverse mode ). After a few minutes of blowing,hot air will come from the vacuum cleaner which should do the trick
Jun 26, 2011 | Kenmore Top Freezer Refrigerator
I heard a hissing while I was looking in the refrigerator, and I realized that it was coming from the freezer. I looked in the back of the freezer compartment, and I saw a red coil through the vents at the...
Hi and welcome to FixYa. I am Kelly. Relax :) You just witnessed part of the NORMAL automatic defrost cycle. There is a heating element in a glass tube that melts ice off of the evaporator until either a thermistor or 60 Deg F defrost thermostat cycle and terminate the defrost cycle. Just so you know automatic defrosting cycle intervals are anywhere from every 6 hours up to 16 hours and 35 minutes depending on the model. The hissing sound you heard was melting ice dripping on to the hot glass tube of the heating element so the water was boiling on the glass tube. It is nothing to worry about unless the defrost cycle never terminates. (i.e the unit never starts back up)
Thanks for choosing FixYa,
Kelly
Nov 15, 2010 | Refrigerators
Uplug to clean now it is staying warm
Hi!!
If you have ice build up on the evaporator (located in the freezer) unplug fridge and melt ice using a heat gun or hair dryer to speed up the process. Taking the back cover will also help. (If you don't feel comfortable doing it, don't do it.)
And don't worry, it is very common to change temp. settings when cleaning fridge. Check settings and restart unit.
Don't forget to rate this answer, GOOD LUCK
Apr 16, 2010 | Kenmore 57029 Side by Side Refrigerator
Frosts up wont get cold MCBR1000S
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 17, 2009 | Magic Chef CTB1821AR Top Freezer...
Fridge not cooling
Aug 10, 2009 | Refrigerators
Freezer and Refrigerator Heating up
chances are the evaporator coils (behind the back freezer wall) are icing up and must be thawed out. this is from too much moisture freezing to the coils (door left open in hot weather, drain plugged, or fridge filled before letting it chill for a day empty and on). take back wall off and use warm water or a hair dryer (only until ice melts- do not overheat metal) to melt the ice. soak up excess water from under fridge, too. also check to see if the fan is working.
Jul 20, 2009 | GE PFS22SBSSS Stainless Steel French Door...
My freezer is not staying cold.
may you be having problem with compresser.and for more info contact http://tinyurl.com/m7ghqz
Jun 19, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
My freezer won't stay cold enough to keep food frozen.
I had this problem about a year ago with mine. You need to replace the heating element located at the bottom of the freezer. It's behind a plate that you can remove after loosening a couple of screws. This heating element defrosts the freezer. When it goes bad it allows ice to form over the coils and then the freezer actually warms up. It's around $30 and an easy fix. You just need to unplug a couple of wires and put the new one in.
Dec 22, 2008 | Hotpoint HSS25GFP Side by Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
141 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
