Toshiba Style Bay DVD-RAM Drive Kit  DVD Drive
Problem for Toshiba Style Bay DVD-RAM Drive Kit (PA3219U1DV1) DVD...
HI i have a matshita dvd-ram uj-85js ata cd/dvd
By kckaza on Jul 15, 2009
HI i have a matshita dvd-ram uj-85js ata cd/dvd drive and suddenly its having trouble recognising blank dvd's when i run nero and disk info tools i am getting hardware error and when i try burn the with a dvd i am getting there is no disk loaded in the drive when there is, yet it is reading already burnt dvd data disks just fine. What can i do to solve this problem.
Comments:
Jul 20, 2009
- I tried running a cleaner and i also tried using vertabim disks and the problem is still there. Though now when some data dvd's are being read and explorer opens with the layout minute latr the drive will try read the disk and ill get a not responding message in explorer. Yet on another pc the same disks are having no problem
Jul 20, 2009
- herers a more indepth look at my problem since i didnt post to muc info before. im having problems with the matshita dvd-am cd/dvd burner. At first it stopped detecting blank dvd's now it seems to be havign trouble reading data dvd's well, Alot of the time 95% it either reads them as blank or if it can read the layout it freezes trying to read any of the data in explorer. the brands of disk im using are tdk and vertabim which are working fine on my other pc's burner. Ive checked the driver and is reported that it isnt corrput and it working properlyive also checked for firmware updates and ive used disk tools on nero and most dvd's im getting an unknown disk media and hardware error.(tdk gold dvd-r) I also ran a disc lens cleaner twice through and still no luck. I dont get any error msg from windows though either the disk is coming up as blank/freezez when explorer opens and starts scanning the disk or after scanning for a little bit the drive automatically ejects the dvd. the drive is empty or the media format is unreadable was the reported error coming back to me and the birmomg software nero says the disks are unkown or there is none inserted when i run disk info tools. Just to double check ive deleted and reinstalled the driver, and i tried booting into safemode to see if it was a software conflict and no such luck there. im getting Hardware error when i use disk info tools in nero when i try to burn i get these errors: Error Code: 1003 (or 1004) (from nero when i try to burn) CDB: 53 00 00 00 00 00 1F 9A 40 00 00
Jul 20, 2009
- CDB: 53 00 00 00 00 00 1F 9A 40 00 00 00 SenseKey:03 ASC:57 ASCQ:00 error processing message 0xc0000013 (didnt copy and paste all of last bit in previous entry)
Solution #1
posted on Jul 15, 2009
Not Helpful)
videoman7
Rank: Guru
Rating: 88%, 39 votes
kckaza -
Get a lens cleaning disc and run it following the instructions. You likely have dust or dirt on the lens which is making it difficult to read the blank DVDs. This is aq common problem that has a simple solution (They run about $10).
Michael
Was this helpful?
Yes
No
Popular Solutions for Toshiba Style Bay DVD-RAM
Questions and Unsolved Problems for Toshiba Style Bay DVD-RAM
Do you recommend Toshiba Style Bay DVD-RAM Drive Kit (PA3219U1DV1) DVD Drive?
Answer
Answer
I'm using lenovo y500 series 4EQ laptop/vista home basic.however my DVD drive (matshita... (More)
Answer
On the Matshita dvd ram uj-861 model I am recieving an error message code 39, it is not recognized... (More)
Answer
I have the same drive but it will read and write CD's and it seems ok with some makes of DVD-/+RW... (More)
Answer
my dvds do not play and when i put a dvd in a error come up also.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top DVD Drives Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
