When i set my camera to the settings i want, as soon as i turn it off or it goes on standby i loose all of my settings and have to re-select them all. Is there a way to prevent this?
It is by design. I guess Sanyo cut corners in some places and all of the Xacti cameras AFAIK have that problem, they DO NOT save custom settings. so you have to redo your settings every time to turn it on
Was this helpful?
Yes
No
Popular Solutions for Sanyo Xacti VPC-HD1000 Flash
I have the identical issue:
I accidently used the wrong charge chord to plug in my camera dock. I...
(More)
I accidently used the wrong charge chord to plug in my camera dock. I noticed that the red "charging" light came on and started blinking instead of staying on. I unplugged the 9v charge chord and plugged in the correct 3.5v charge chord and now my camera wont turn on at all. Whether I plug the correct chord into the docking station or the camera itself, the camera will not power on. My concern is that I either fried the battery, the camera, or both. I would assume that sanyo engineered in a reset or something. Is there a way to reset the camera.
battery pack is low after 02 minutes.I have 02 battery packs with the same problem.I Just buyed a...
(More)
battery pack is low after 02 minutes.I have 02 battery packs with the same problem.I Just buyed a new charger and the probloem still happens
I have 2 spare batteries
with my sanyo hd1000. Now they are all empty whithin a very very...
(More)
with my sanyo hd1000. Now they are all empty whithin a very very short
period (like 2 minutes) while I could shoot more than one hour with
each battery last month. When I check the current it's defenetly full
with sufficient power but the camera
detects it as an empty battery. I assume it has something to do with an
external charger I have bought and used recently. Is it possible to
"reset" the camera or "reset" the batteries in some way or another like
draining all power before charging with camera again???
Help needed please!!!! I am from Brazil and nobody here can fix it and help me
I have 4 spare batteries with my sanyo hd1010. Now they are all empty whithin a very very short...
(More)
I have 4 spare batteries with my sanyo hd1010. Now they are all empty whithin a very very short period (like 2 minutes) while I could shoot more than one hour with each battery last month. When I check the current it's defenetly full with sufficient power but the camera detects it as an empty battery. I assume it has something to do with an external charger I have bought and used recently. Is it possible to "reset" the camera or "reset" the batteries in some way or another like draining all power before charging with camera again???
