Question about Canon imageRUNNER 3300 All-In-One Laser Printer
Already we connected the ir3300 machine through network.now we want a weakly printing log for every weak.how can i do this?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 89 Answers
You can try turning on DepID management. This will not separate photocopying and printing but it will allow you to record how much has been printed for each job/client. Make sure you have Job Accounting turned on in the print preferences/properties (can't remember which) if using this method. Then remember to print the total off each week and clear the totals on the machine.
Alternatively if you want detailed logs (e.g. info on each item printed, can't do this for photocopying I'm afraid) then print charging software such as PaperCut could be useful for you. I currently use the free version of that software (free for 5 users or less). This will provide detailed logs down to every job, what kind of paper was used, b&w/colour and will allow different costs/prices to be set for different size paper, b&w and colour etc. You install PaperCut on the server and share the printer from your server and install the client on each machine.
Posted on Jul 17, 2009
How to connect this ir3300 xerox machine to computer plz tell me sir i request u
you need to have a driver installed on each P.C
http://www.usa.canon.com/cusa/support/office/b_w_imagerunner_copiers/imagerunner_2200_2220i_2220n_2800_3300_3300i_3300e_3300en_3320i_3320n/imagerunner_3300#DriversAndSoftware
You need an ethernet network of computers
You need to set up the ip addess and subnet mask in the printer via its setup menu . At the very least a ethernet network Switch with static ip addesses for each device , or A router with DHCP server to dynamically assign ip addresses.
you need an rj45 socket on the ir3300 which it should have 802.3 ethernet 10/100 tbase ethernet according to ir3300 specs if it is missing you need a network card to be added to ir3300 by Xerox / Cannon
Sep 05, 2015 | Xerox Office Equipment & Supplies
How can I better the print quality of Cannon IR3300
How many copies drum made?Maybe you have to change it.Clean the optic mirrors platten glass,transfer roller...
Jul 31, 2014 | Canon 2 Ir3300 Ir3300i B/w Copier/ Network...
I have to enter my password several times to get my kindle to log on. I always have to log on..the signal seems to be weak adjacent to the router. authentication failed is a normal response on my kindle....
your kindle device should be able to connect the network automatically , if this is not happening try adding the network manually.
1.First, make sure you are within range of the network you want to add, and that you know the network name and password (if required).
2.From the Home screen, tap Menu and select Settings.
3.Select Wi-Fi Networks to display a list of detected Wi-Fi networks.
4.Tap Join to enter network details.
5.Use the onscreen keyboard to enter the name of the Wi-Fi network that you want to add.
6.Once the Network Name has been entered, tap the Password box and enter Wi-Fi password / Network Key using the onscreen keyboard (if required).
Tip: Tap the 123 key to enter numbers or symbols. Tap the ABC key to return to the regular keyboard. Tap the Shift key (up arrow) to enter uppercase characters. Your password may include non-English letters (accents, umlauts etc.). To view accent options, press and hold a letter down, and accent options appear.
7.Tap Connect
Does all your wireless devices have weak signal issues?If so , Then problem may be with the wireless router.Try changing the wireless channel on the router by logging into the router interface page.
Authentication failed is the message u ll normally get when u enter the password incorrectly.
Aug 07, 2013 | Belkin (F5D7230-4) Router (587009)
Hpj4680 will not print after adding wep pw
Cant you use WPA2, wep is very weak and should never be used if you have the option to use WPA.
If you have used WPA2 security ( you choose the password )
and the printer is asking for a wep key ( the router generates a long key , you dont choose it).
That will be the reason you can't connect, if the printer cant be changed to WPA, you only have the option to log on to the router and change security to WEP, which i would not recommend
Jul 22, 2010 | HP J4680 Office Jet All-In-One Printer
My nokia n70 phone weak of signal
hi im josh in cebu phils.friend may i help you? your problem is weak signal. friend when the phone is weak signal there maybe a problem in hardware of the phone. the frequency reciever is weak im sure.but you can boost its functions throught entering the setting and go to network settings and select manual search.your phone frequency will search the network connections around so the hardware will be force to boost.once it will show the network providers around you select the network you are using and it will be setted to the network in more/ higher frquencyh signal. thats all friend hope i helped you.good luck/
Feb 28, 2009 | Nokia N70 Cellular Phone
My ir3300 xerox machine not print out.please solve thins problem.
How are you trying to print? You need N boot rom. Press Counter Check. Do you see IR3300(IR2200N) or IR3300(IR2200). If you see the N then you should be able to print with it. If not, you can't.
In Service Mode (to get into this press Additional Functions (button with * on it) > 2 then 8 > Additional Functions) go to Copier > Display > Version. What do you see for BOOT-ROM (does it have a N at the end?). For PS/PCL what do you see?
If your BOOT-ROM is N and you don't have a number for PS/PCL then call a technician to install networked system software.
If BOOT-ROM is not N, buy a Network Multi-PDL Kit C1 and get a technician to install it and load N system software.
If BOOT-ROM is N and you have number for PS/PCL check your IP settings. Make sure that DHCP is turned off. Set up your printer using an IP port with the static IP address assigned to the copier.
Use PCL5e or PS drivers, don't use PCL6.
Jan 23, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
I need to install a network & print cards to my IR3300 copier. I does have a FAX card but not printer or network. Where can I buy these and how do I configure them once installed?
you need 2 thing the network board and the print boot rom N chip. not to hard to put it but you will need a canon tech with system software to flash the machine with the new items in it.. if you still want to buy it try 1 931 269 6601 southeastern wholesale they usually have some
Dec 16, 2008 | Canon (6981A002AA) for imagerunner 2200,...
Computer will not connect to wireless router
Check the wireless network card
try to reinstall the driver
Jul 27, 2008 | Computers & Internet
Canon imageRUNNER 3300 All-In-One Laser Printer Logo
113 people viewed this question
old marine
old marine
