Question about Harmon Kardon Harman Kardon Avr335 Receiver Remote For Avr230 Avr 230
I'm unable to change inputs. I don't have the remote...
Using the front panel (on DVD, or CD): I press "Digital Select" scroll to 'Coax 3'. Press "Set" button. Then Devices starts flashing the 'L' & 'R' indicating the Left & Right speakers. Then after about 3 seconds it reverts back to 'Analog' for the input. How Can I change the input?! Please help. Sincerely; Alex
2 Suggested Answers
SOURCE: Sound is really quiet with inputs
Hello. Please be sure that you are plugging your iPod into the tape in, or play, and not into the record out, or record. If you have these reversed, you will greatly lower the signal level going to the amplifier.
Dave
Posted on Oct 08, 2012
How to remove closed caption on the screen?
If you have a digital Set-Top Box with digital cable service: Using Navigatorâ„¢: Press SETTINGS on your remote. Using the left/right arrow buttons, scroll to Quick Settings. Using the up/down arrow buttons, scroll to Closed Captioning. Press SELECT on your remote. Using the up/down arrow buttons, scroll to highlight On, On with Mute or Off. Press SELECT on your remote
Nov 30, 2016 | Televison & Video
I have the panasonic SC-HT400 receiver which I've connected to a bluray DVD player using an digital coaxial cable mainly because I have no other outputs on the blue ray dvd. As you know the Ht 400 does...
Press the SFC MODE switches at the same time to enter the "settings".
Change these settings to suit the connections you have made to the three digital input terminals, COAX, OPT1 and OPT2, so that the correct source is selected when you turn [INPUT SELECTOR].
The factory settings are: CD: COAX
DVD: OPT 2
TV: OPT 1
If you are allowed change them all to Coaxial. That should solve the sound problem.
Jun 30, 2017 | Panasonic Audio Players & Recorders
Assinging coaxial 1 to dvd
hi.
Do the following to assign COAXIAL 1 to dvd.
1. Press the DVD button on frond panel ( will display the current setting).
2. Press and hold DVD button for 3 seconds ( will display the selections ).
3. Press DVD button rapidly and select COAX 1 ( will sect COAXIAL 1 as DVD input).
ok
Feb 18, 2011 | Onkyo TX-DS484 Receiver
Unable to assign optical and digital inputs to other inputs
It won't let you assign the same input twice. Check to see that DVD is not already assigned to any other In(x) function.
From the manual:
• You cannot select a specific item more than once.
• You cannot assign the same input source to both “IN (2)” and
“IN (3)”. For example, you assign “CD” to “IN (2)”, “–––”
appears in “IN (3)”.
Mar 16, 2010 | Yamaha RX-V363 Receiver
I have a philips I got from a hotel but i cant program the channel to 3 to hook up a dvd player even with a universal remote what do i do?
Channel 3 is probably locked out... here is how to fix it....
1) Press the Menu button on the remote or press both Volume buttons on the front of the TV to access the TV's internal menu's
2) Scroll to highlight INSTALL using down arrow on the remote or Channel - on the front of the TV.
3) Press the Right Arrow on the remote or Volume + on the front of the TV to access the INSTALL menu.
4) Scroll to highlight Channel Edit using down arrow on the remote or Channel - on the front of the TV.
5) Press the Right Arrow on the remote or Volume + on the front of the TV to access the Channel Edit menu.
6) Use the Left or Right Arrow on the remote or Volume + / - on the front of the TV until you get to Channel 3.
7) Use the Down Arrow on the remote or Channel - button on the front of the TV to select SKIPPED.
8) Press the Right Arrow on the remote or Volume + on the front of the TV to select OFF.
9) When finished press Exit on the remote or press the power button on the TV and then power the TV back on.
You should now be able to use channel 3.
Good Luck....
Jan 15, 2010 | Philips 20PT6441 20" TV
Copying video to dvd
1st, does it come with a driver...if it doesn't, just make sure it is installed properly in your PC, then you just need to install a dvd writing software in your PC e.g. NERO Pro (v7 or later)...then, all will fit in...
Jul 23, 2008 | Samsung DVD-R130 DVD Recorder
JVC RX-9010V - Setting up Digital Inputs
Just to the left of the volume is a "settings" button. Press it and cycle through the options until you reach "Digital Coax," then use the "Control" up and down buttons to change the assigned source.
Jul 02, 2008 | JVC RX-9010V Receiver
No sound using digital coaxial connections
Couple of possibilities:
Press Audio Select on front of unit until "Analog" changes to "coax/opt"
or
When you select the component connected to the MULTI CH INPUT jacks as the input source (see page 38), this unit automatically
turns off the digital sound field processor, and you cannot select sound field programs.
May 16, 2008 | Yamaha HTR-6080
Durabrand DCF2003
All you need is to press the input select button on the remote to change between the tv and the video inputs.
May 23, 2007 | Durabrand DWT1905 TV
Harmon Kardon Harman Kardon Avr335 Receiver Remote For Avr230 Avr 230 Logo
44 people viewed this question
Top Harmon Kardon Audio Players & Recorders Experts
Steve
 Grubhead
Grubhead
john h
Are you a Harmon Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
