Question about Nokia 7360 Cellular Phone
No signal, this is always prompted " Contact Servise Provider"
What should i do? my nokia 7360 have no signal, sometimes it automatically shut off and then turn on after a seconds. and how can i use this as a modem or router for i can be able to connect through internet using my nokia 7360 and my PC.
I have 7360 no network found and i tried to change p.a ic, antenna switch and filters but still no network found... help me plzzz...
First Option:
Phone in the Other Sim and check the Phone Network Signal If Network Signal Problem not Solved So
Secend Option:
Your Phone Network IC Fault So Please change Network IC
And Network Signal Problem will Solved
if it is there isn't much you can do on this side of the network.
Contact your phone company.
Jan 15, 2013 | Nokia 7360 Cellular Phone
I need a restriction code for my nokia 7360 can i get this? also can i UNBLOCK a BB torch?
hi you can use codes to unlock your mobile from a particular network .it will be helpful for me to guide you the exact place if you had specified the country and the provider to which the mobile is locked .however you can get the codes from here onlinegsmunlock here they ask the imei number of the mobile .finally they will send you the unlock codes .
Sep 06, 2011 | Nokia 7360 Cellular Phone
Contact service on nokia 7360
Hi!
The first thing you do is to powercycle your phone you can do this by removing your battery when the phone is on. Then after 15 seconds insert your battery and then when nothing happens go to the place that has a strong signal. if nothing happens again try to contact your service provider because there might be a problem in your network.
Thanks!
Apr 22, 2011 | Nokia 7360 Cellular Phone
I need a nokia 7360 signal jumper diagram, pls. help me
Below is signal jumper diagram for nokia 7360 ..
Mar 22, 2011 | Nokia Cell Phones
My nokia 7360 is in weak signal so please i need your help
kindly use a sim that will be helpful in getting good range or your phone is affecting from some software problems..
Oct 16, 2010 | Nokia 7360 Cellular Phone
Nokia 7360 has a phone restricted code
Try restriction codes here http://www.theunlockspot.com/nokia-7360/rs10wp9/ you need to specify the country and network provider
Sep 28, 2010 | Nokia 2626 Mobile Phone
My nokia 7360 has no signal...how can i solve it...though i reheat the chips its still no signal...pls, help me
try replace it with a common chip. if it works then it is so. but, if not you might have other chips to reheat... hope this may help you...
Apr 26, 2010 | Nokia 7360 Cellular Phone
No signal
I think your speaker may contain some dust in it & doesn't have a signal means there may be some problem in your phone's battery.
Mar 25, 2008 | Nokia 7360 Cellular Phone
Bluetooth and mp3
i want my 7360 to a bluetooth and mp3 activation,what should do?,and also my unit sometimes shutoff automaticaly and turn on after,and contact service appeared on screen. pls help me..?
Dec 11, 2007 | Nokia 7360 Cellular Phone
7360 SIGNAL
how do i unlock my nokia 7360, its locked to vodafone ireland
Nov 14, 2007 | Nokia 1100
Nokia 7360 Cellular Phone Logo
161 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
