Question about LG LHY-518 System
LG HT502 won't play iPod
I have an LG HT502 DVD Receiver with no user manual. The receiver has a label that says it can take input and playback from an iPod and there is an input on the front of the HT502. However, when I plug my iPod in, it does not play and there is no button for a personal Mp3 player on the remote, which has only Band, DVD, Aux and USB - no iPod button. Anyone out there have an idea on how one can use an iPod with this LG HT502, other than outputting to Auxiliary?
Thanks for any help.
SOURCE: LG Model LHT754 stuck in demo mode
Press and hold the stop button for 5 secs
Posted on Jun 04, 2008
SOURCE: Change of function-HT502Sh
press the "2" button on the remote while pressing & holding the stop button on the device, something like OP 86 will come up on the lcd display, repeat the same procedure and press "enter" afterwards, the device should restart and the problem should be solved.
cheers
Posted on Apr 22, 2008
shaggyrat
  • 1224 Answers
SOURCE: audio playback
1.bad rca jacks
2.could be connected to wrong audio lead rca jack
3.the settings in dvd player donot match the receivers example- dts or ntfs
4.make sure its regioned to your player some audio isnt on the disks
5.pc's usually have new cd formats that came out
cd's and dvd's for some reason in this age isnt being able to play fully in older equipment do to the change in cd/dvd formats which makes you go out and buy new equipment it happened to me not just 2 weeks ago bought a new dvd and found out it wouldnt play in my year old dvd deck had to go out and buy new dvd deck then disk and all my others played fine
Posted on May 12, 2008
walesarumi
  • 6993 Answers
SOURCE: The system is playing DVD but no sound
As for the sound, there are some players that has different volume controls for each speaker, so check the volume of the speaker through your remote.
Or maybe the sound I.C of the player is bad.
You might just loose the Player with a screw driver and you may probably see what's wrong with it and if you don't, couple it back and put it on, don't be surprised to see your player working properly.
My Samsung player hung such that no button functions. What I did was just to loose it and clean the inside and by the time I coupled it back, it started working perfectly up till now.
Note that this could only work if the player is not having any major fault.
I wish you the best.
Posted on Nov 06, 2009
SOURCE: compre un LG dvd receiver
HOLA PUES PARA ESCUCHAR LA USB NECESITAS PRESIONAR EL BOT
Posted on Oct 10, 2010
No owners manual.. Can get sound but no video when playing dvds
get in touch with the supplier and tell them you didn't receive an owners manual, they should get you one.
Nov 16, 2013 | Alpine IVA-NAV-10 - 7 In-Dash Navigation...
LG LHT754 stuck on dvd function and won't change input
Hold down "2" on the remote simultaneous to "stop" on the receiver. In a couple of seconds you will see something appear on the display. OPO-63? Anyway, repeat the process again when you see that. The system will reset. This will also take care of the inability to switch to AUX or Ipod.
Feb 16, 2013 | LG LH-T754 Theater System
My Onkyo TX-SR506 plays cable and CD inputs to zone 2, but DVD won't play. Everything is connected according to the manual and I assigned zone 2 output correctly. What gives?
How are your cable and cd inputs hooked up? Analog connections? Alot of receivers cannot send an audio signal from hdmi inputs to zone 2.
Feb 06, 2013 | Onkyo TX-SR506 Receiver
No audio after recording from sat. Reciever
Double-check your input cables from the receiver to the LG 389. Do you have the sat. receiver AV out connected to the front AV In on the LG DRT389? Make sure that you haven't mixed up the L and R audio connections on either side. (I've done something similar with RCA cables myself.) Next, try a different set of cables.
If that doesn't work, there may be a problem with the audio jacks on either your receiver or the 389. To check, plug the AV cables from the Sat. Receiver directly into the TV. If you have sound and video, then the input jacks on the recorder may be damaged.
Try using another input. (It looks like some models have the SCART input; you may need to set the input source in the menu under AV2 Decoder.)
The fact that you have audio output on USB and DVD's means that cables/connections between the LG289 and the TV are fine.
I hope this helps. Please add a comment with the details of which AV port you are using on the LG389 for additional assistance.
Aug 31, 2012 | LG DR389 MULTISYSTEM DVD RECORDER FOR...
How to play digital input
You need to assign a digital input (optical 1 2 or coaxial 1 2..) to a source (DVD CD etc). You can do it in setup menu > input assigment. Some receivers have preassigned inputs, check labels you your receiver next to digital input. Ex If it says "Opt1/DVD", select DVD and receiver will play a signal from optical 1 input.
Dec 18, 2011 | Denon Audio Players & Recorders
I have an Optimus STA-3500 Digital Synthesized AM/FM Stereo Receiver. If I buy an i-pod is there a place on the back of the receiver that it can be plugged into? If so, what kind of i-pod wire/cable...
It won't have "iPod" functionality but it can be played through the receiver.
Any audio device that has a headphone output can be adapted to feed an RCA cable pair for standard stereo to any audio device with a standard RCA input (except one labeled "PHONO"). Get a cable like the one described here: http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10218&cs_id=1021804&p_id=665&seq=1&format=2
and connect it into any available analog input EXCEPT one labeled "Phono".
Jul 25, 2011 | Optimus STA-3500 Receiver
I have hk3385 receiver and Ipod Touch 4G. I have the cable to connect them. Where do I hook the cable on the receiver (or do I?) and which buttons will play the Ipod music. No video, just music
The manual suggests that you use "A / V 3" (audio / video input 3) for your iPad / iPod audio input. These are the RED and WHITE jacks on the front lower right hand side of the receiver. The YELLOW jack is for composite VIDEO, and need not be connected for "audio only" programs.
Turn the volume on the iPod / iPad to MINIMUM (assuming the receiver volume is at a "normal" setting for the radio, CD, etc.). Connect the cable between the iPod / iPad and the A / V 3 RED and WHITE audio jacks. Select A / V Input 3 on the receiver. Find a song you want to listen to and select PLAY in the iPod / iPad. Slowly adjust the volume on the iPod / iPad up to a comfortable level. If there is distorted sound, adjust he receiver and iPod / iPad volumes up and down as needed. Generally, neither should be set very low or very high.
You can download the owners manual here.
I hope this helps & good luck. Please rate my reply - thanks!
Jan 20, 2011 | Harman Multimedia HK 3385 2 Channels...
I lost the remote for my LG DVD receiver model number LHT754 and i cant chance the inputs
If u are trying to change the input from dvd to usb or the other inputs. All you have to do is hold down the play button on the front of the dvd home theater system until it starts to flash then press it again and keep pressing until u find the input u are looking for. It will rotate thru all inputs even the ipod input.
Sep 26, 2010 | LG LH-T754 Theater System
Denon receiver AVR-3300: Unstable source selection
Go over here: http://denon.custhelp.com/cgi-bin/denon.cfg/php/enduser/std_alp.php?p_sid=1NlVrsDj
I have some Denon components myself and had some problems. Ask them here, and within a day you should have solution for this problem.
Probably you have to reset the device to factory settings.
Jul 22, 2009 | Denon AVR-3300 Receiver
I have a LG ht502 home theatre , black and white only
Sir avservice, I have also posted a problem about an HT502 DVD receiver + Home Theater. The sound won't come out of the speakers but only of the Plasma tv. But was working before. And the word "PROTECTION" is appearing on the display screen of the dvd receiver. But good quality picture on the plasma tv. Please help
Jul 20, 2009 | Jensen JHT-350 System
LG LHY-518 System Logo
269 people viewed this question
Top LG Audio Players & Recorders Experts
Electro Med Services...
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
