Question about Garden
Mower starts fine but stalls immediately upon
Ryobi rt190 riding mower starts fine but stalls immediately upon letting foot off of brake pedal. no strain on engine or driveline, no movement, just cuts off as if kill switch activated.
    Scholar:
  • 173 Answers
Check the switch connected to the brake curcuit.
As you suspect, that is more than likely the problem.
Good luck.
Posted on Jul 24, 2009
2010 Troy built 42 inch riding mower with auto transmission : mower has to have brake pedal depressed to start. It starts fine - let of the brake pedal and the motor stalls out . What is wrong ???
Most of these machines have similar saftey systems.
If you apply the parking brake the engine should continue to run.
If the brake is released and the operator is not in the drivers seat then the motor will stop.
If the operator is in the seat and the seat presence switch is working properly the motor will continue to run as the brake is released.
If the weight of the operator is low (skinny little kid) then the seat presence switch will not activate the motor will stop.
If the switch is defective no matter how heafty the operator is the motor will stop.
There are other components in the electrical system that the switch connects to that could also be the problem
Start with the switch
Hope this helps?
Apr 11, 2016 | Troy Garden
Poulan riding mower stalls when I release the clutch
there is other safety switches on the pedal and on the pto
Apr 03, 2012 | Garden
Engine runs but stalls when engaged
This sounds like a micro switch, or relay issue, it is not stalling it is being switched off, if there are some relays on the back of the bulk head replace them, they are just a push fit.
Feb 26, 2012 | Garden
The mower will stall when I lift my foot off the brake.
If you have a gear transmission,you have some safety switches. One under the seat. One on the clutch -brake pedal. These switches work together to prevent accidental injury. One may have disconnected or a wire frayed. If one switch has failed it will shut the mower off.
Apr 23, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Craftsman hydrostatic strains but won't go forward or reverse
There is a brake lever attached to your transaxle, that when activated, pushes dowel pins which serve as brake pistons, against a brake pad which presses against a disk from your transaxle...whew. Much like a disk break on your car.
The pistons, or dowel pins may be sticking, causing you to be "riding your brake". A little disassembly and some good ole WD-40 might loosen up the bind.
Aug 25, 2009 | Garden
Simplicity mower stalls when brake released
There is another safety switch connected to the parking/service brake. Check that one too. Sounds like its the one.
Jun 22, 2009 | Garden
Engine stalls when clutch/brake pedal is released
Under the seat, there is a operator presence switch, if this switch fails, the mower will shut off when the brake is released, or put in any gear.
Apr 21, 2009 | Garden
Garden Logo
262 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
