Stuck Transmission Lock - Mitsubishi-Forums.com
www.mitsubishi-forums.com > ... > 2G (2007+) Outlander
Feb 22, 2008 - 5 posts - 4 authors
Drives: 1997 Outlander LS, 2007 Series 3 380 SX ... Hopefully the heads up will help one/some of you out if you ... This morning I jumped into my 2007 Outlander (Aussie Spec with the CVT) and I couldn't move the gear ... I couldn't find anything in the manual about it, but a Google search brought me here.
Getting Into Reverse Gear - Mitsubishi-Forums.com
www.mitsubishi-forums.com > ... > Colt & Mirage Forum > 2003+ Colt
Mar 17, 2007 - 15 posts - 10 authors
go to another car dealer with the same model and a manual ask for a test ...QUOTE(stevansam @ Mar 19 2007, 07:34 AM) ... the dealer won't take the car back because it's not a fault of the car but a ... I also have a Renault megane and at workdrive a Ford pick-up, which both have syncho in reverse, I can't ...
Adjust Digital Transmission Range Sensor - YouTube
? 0:42
https://www.youtube.com/watch?v=FyiGxhkV-VM
Mar 27, 2010 - Uploaded by Alexander Cameron
If the DTR is not adjusted properly, you will get a no-start situation. ... when I am in drive and shift to reverse my backup lights dont work but if I put into park and not even all the way into park and go reverse they work. ... Hi I changed the solenoid
SOURCE: when in drive the neutral indicator light flashes
Check your ATF cooling system. Your transmission fluid is overheating. This might be after a hard drive. The fluid might need to be replaced too.
SOURCE: What is the recommended oil for a 2007 mitsubishi
all cars are the same when it comes to oil"use the best you can afford" or 5/40 full synthetic(when you get upto 100k then use semi 10/40)
SOURCE: 2007 Mitsubishi Endeavor won't start. I turn the
I had the same problem too..My battery was stone dead..My lights were on but their probably isnt enough cranking amps to start the truck...I would take the battery out and charge it overnight and then try to crank it in the morning...i just changed the battery and the truck started right up
SOURCE: Where is the cabin air filter & how do you replace
the cabin air filter is located behind the glove box..you have to drop the glove box to get at it
