Question about Magellan RoadMate 2000 GPS Receiver
Magellan 2000 map stuck on same Wy map, can't get to change.
My Mag Roadmate 2000 is stuck on a hwy in Wyoming from a week ago and won't change. I have pushed all buttons. I have opened and removed the battery and memory chip hoping it would not be able to remain on Wy. I do not know what to try next.
  • Ben Dover May 11, 2010
    do you still need help with the gps.
I had the same problem. Push and hold the on/off button in for about 30 seconds and the gps may reset itself. It worked on my Magellan 2000.
Posted on Sep 21, 2009
Change my magellan roadmate from canada to usa
This model does not have map coverage of Canada. This model was designed for us only in the US. The models in that series with Canada maps were the RoadMate 1212, 1412, and 1430.
Oct 12, 2014 | Magellan Roadmate 1200 Car GPS Receiver
Free map update fpr magellan roadmate 2000
There is no longer any map updates or accessories available for the Roadmate 2000.
Magellan has obsoleted this unit and no longer has support for it or any accessories.
I talked to them online as well as on the phone.
So basically when you get the message on your Magellan Roadmate 2000 that you maps are out of date and your unit no longer functions correctly because of this, there is no fix and the unit is now a useless paper weight.
And there are no sites online that has any software to upgrade maps for this unit.
So keep your plugs because they work on other units, but take a baseball bat and hit a home run with your roadmate 2000.
Thats all its worth now.
Oct 31, 2012 | Magellan GPS
Magellan RoadMate 1440 files
sorry but you have requested from the wrong web site
Jun 26, 2012 | Magellan RoadMate 1440 Car GPS Receiver
The gps is a magellan RoadMate 2000. It does not get a satellite signal and it has been reset and left outside to try and get a signal and still will not get one.This just started about a week ago. Thank...
hi foxylady0415,
try and run the update and make sure its fully charged and try again...you can get the update HERE
download and follow the directions exactly, and make sure the batery is either fully charged or the gps is plugged in to a good charger.
let me know if you need further help
Bill
Standing Member of G.O.T.
Oct 21, 2010 | Magellan RoadMate 2000 GPS Receiver
Can you download an update for a magellan roadmate 1430?
Yes you can: Enter your info here http://www.magellangps.com/support/
English Manual: http://docs.google.com/viewer?url=http%3A%2F%2Fwww.magellangps.com%2Fassets%2Fmanuals%2Froadmate_1430_manual_en.pdf
Magellan® RoadMate® 1430 Software Update Version 3.12: http://www.magellangps.com/support/chooser.asp?prodid=2056&supportid=806
2009 Spring Map Update: http://www.magellangps.com/products/map.asp?tab=0&PRODID=2194
As for connecting it to the computer, you'll need the usb cable that came with it. Then you'll want to do this:
Follow these steps to connect your Magellan RoadMate to your PC.
  1. Turn ON your Magellan RoadMate.
  2. Touch "Map" to display the map screen.
  3. Connect your GPS to your PC using the USB cable.
Oct 19, 2009 | GPS
Once region is set how do I change it on the megellan roadmate 1212?
By default, the Magellan RoadMate has the region setting for the lower 48 United States. When the receiver is turned on for the first time it may ask you to assign regions. Select the map region you want to use by tapping on the item from the list.
If you are travelling in other regions you will need to change the map region by using the following steps.
1 From the Main Menu, tap on the right arrow to access the second page of the Main Menu.
2 Tap on User Options.
3 Tap on Region.
4 Tap on the map region desired.
The Region option will display the map regions that are available for the Magellan RoadMate you are using.
Also if you want you can download the user manual from this website
visit website
or
download
Hope this helps
thanks
Oct 01, 2009 | Magellan RoadMateā„¢ 1212 Car GPS Receiver
How can I get the code to unlock the European map Magellan Roadmate 760
You will need to pay Magellan for the authorization code, they are the only one that can provide you with an EU code for your Magellan 760 RoadMate. Sometimes Auto Nav 2000 Plus, Inc can also assist. They have direct connection with Magellan to assist issues with Magellan products. Good Luck
Aug 04, 2009 | Magellan Roadmate 760 GPS Receiver
Magellan roadmate 700 no maps found How do i fix this?
the road maps for this model are on An SD Card.
If you don,t have the SD Card with the maps on, your roadmate won,t find them.
You can also contact:- Magellan for mapping updates.
I believe they do not supply the roadmaps with this item, which @ $1. 200 is a bit of a rip-off however good and accurate they are.
Jun 12, 2009 | Tomtom GO 720 GPS Receiver
Your best bet is to contact Magellan directly. Their website is not the easiest place I've ever navigated. I did not see a specific listing for the Roadmate 2000, but when I queried them about upgrades for your unit, the response was Roadmate 2000/2200T. Manuals are available, but again nothing was noted about supporting the 2000.
I've provided their phone # is below. Good luck.
800-707-9971
Feb 29, 2008 | Magellan RoadMate 2000 GPS Receiver
Magellan RoadMate 2000 GPS Receiver Logo
160 people viewed this question
Top Magellan GPS Experts
Jungle Ghost
Jungle Ghost
Are you a Magellan GPS Expert? Answer questions, earn points and help others
