Question about KitchenAid KHMS155L Microwave Oven
Magnetron noisy model khms155l what is involved in replacing a magnetron on this model.
    President:
  • KitchenAid Master
  • 1,922 Answers
Are you for certain its the mag....most times its the laminations in the xfmr and need to be tightened, but the way their constructed today usually you need to live with it or replace offending unit...they are expensive
Posted on Jul 27, 2009
The oven has trouble ligting,and make,s a boom sound when lighting
Magnetron
If the microwave is loud or noisy only when cooking, the magnetron tube might be defective. The magnetron uses high voltage, high current DC power to generate the microwave frequency that cooks the food. Under normal circumstances the magnetron is nearly silent. However if it is damaged or nearly burned out it can begin emitting high pitched or growling noises. It's not normally dangerous to use a microwave oven when it makes these noises, but they are an indication that the magnetron is almost dead and will need to be replaced.
Enter your model number to see parts for your microwave.
Help me find my model number
Exhaust Fan Motor
If the microwave is loud when running the fan motor might be
Stirrer Motor
If the microwave is loud or noisy the stirrer motor might be worn out. The stirrer is a metal blade which slowly turns around, deflecting the microwave energy in a random pattern inside the microwave oven. As the motor nears the end of its useful life it begins to make grinding noises. The microwave will not heat food evenly without this stirrer, the motor should be replaced.
Turntable Motor
If the microwave is loud or noisy the turntable motor might be worn out. This is a common problem and relatively easy to replace.
Apr 02, 2013 | Microwave Ovens
Coleman EB15A - Buzzing noise from transformer area, no heat or fan
see this causes and proceed. God bless you
Magnetron If the microwave is loud or noisy only when cooking, the magnetron tube might be defective. The magnetron uses high voltage, high current DC power to generate the microwave frequency that cooks the food. Under normal circumstances the magnetron is nearly silent. However if it is damaged or nearly burned out it can begin emitting high pitched or growling noises. It's not normally dangerous to use a microwave oven when it makes these noises, but they are an indication that the magnetron is almost dead and will need to be replaced.
Exhaust Fan Motor If the microwave is loud when running the fan motor might be
Stirrer Motor If the microwave is loud or noisy the stirrer motor might be worn out. The stirrer is a metal blade which slowly turns around, deflecting the microwave energy in a random pattern inside the microwave oven. As the motor nears the end of its useful life it begins to make grinding noises. The microwave will not heat food evenly without this stirrer, the motor should be replaced.
Turntable Motor If the microwave is loud or noisy the turntable motor might be worn out. This is a common problem and relatively easy to replace.
Oct 18, 2012 | Microwave Ovens
Microwave made a loud grinding noise while heating a cup of coffee for 1 minute,now everything is shut off. We checked the curcit breakers all ok, and there is power going to it!
see this causes and fix it. God bless you
Oct 15, 2012 | Microwave Ovens
GE Microwave (JVM1860CD001) control board buzzes.
Oct 10, 2012 | GE Microwave Ovens
My microwave heats up for 3 seconds and then shuts off
Since you didn't mention the model number, I have to be kind of general.
This may be due to the internal cooling fan's not working or a "noisy magnetron".
For more on noisy magnetrons, see this FixYa solution even if your brand and model number is different.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
Sep 29, 2011 | Thermador MBBS Microwave Oven
Kenmore microwave model 721.80409400 is noisy while operating like a loud 60 cycle HUM or BUZZ otherwise works OK
Sorry to read about your problem, I hope this helps you out.
you may have a magnetron issue, or these other issues
  1. Shorted HV diode, magnetron.
  2. Burnt carbonized food in or above oven chamber.
  3. Shorted winding in HV transformer.
  4. Frayed insulation on HV wiring.
Microwaves must be serviced by technicians due to the inherent dangers involved in repairing these appliances. Internal capacitors can retain a lethal electrical charge even though the unit is completely unplugged. A microwave radiation leakage test must be performed on the unit following any internal component repair.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 02, 2011 | Kenmore 80402 Microwave Oven
No heating
The magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 on high resistance range for short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Nov 28, 2010 | KitchenAid KHMS155L Microwave Oven
Power is on but, not heating
Check the diode with either an AVO model 8 on high resistance range for short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Nov 02, 2010 | KitchenAid KHMS155L Microwave Oven
Everything seems work ok, but not heating up
this sounds like the magnetron. depending on how old it is as to whether or not it is worth repairs. can be more money than a new one. hope this helps.
Oct 13, 2009 | KitchenAid KHMS155L Microwave Oven
Microwave will not heat food and is noisy
Sounds like the magnetron has failed. This is the component that produces the microwaves that heats the food.
The cost of the magnetron is about 95% of the cost of a microwave oven. Most people don't, for this reason, replace the magnetron, they replace the whole oven which is probably what you will end up doing.
There is a possibility that the circuit that provides power to the magnetron is faulty and you need to take it apart, find the proper electrical leads and test them with a volt meter. To do this you have to remove it from its mounting and take it apart. It is a fairly lengthy process however.
Benjamin
Apr 28, 2009 | Microwave Ovens
KitchenAid KHMS155L Microwave Oven Logo
144 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Stu Ungar
Darial Jr Lasaria
Darial Jr Lasaria
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
