Question about RCA D52W19 52" Rear Projection Television
RCA D52W19 52 in When my set is Immed, turned
RCA D52W19 52 in When my set is Immed, turned on it makes a high picthed sound then after about 5-10 mins the sound goes away. The picture is good and other than this the TV works fine does any one have any suggestions or ideas as to what this may be? There is also a delayed response when turning on the TV the green indicator light will be on however no pic or no sound for about 15 - 20 seconds then the TV screeen will be on accompanied by the high pitched noise.
WHAT ISTHAT WHEN MY TV MAKE NOISES THEN STOP FOR AMINUTE ONCE THE PICTURE IS THER THEN 10 MINUTES IS CUTOFF LIKE ITS TRYING TO COME BACK ON WITH THE SAME NOISES
Posted on Aug 14, 2009
High pitch noise
Sounds like a bad capacitor. Careful, they hold a big charge long after being turned off. They are usually not too expensive. Bad ones will bulge at the top or bottom, leak.
Nov 26, 2013 | Microwave Ovens
My remington electric chainsaw 3.0 is not cutting and making a high pitch screech when i go to cut with it
Hello. Please make sure the saw brake is not set. This locks the blade so it cannot spin. If it is locked then if you try to rev the saw, the blade cannot turn and the clutch will scream. The other thing it could be is it sounds like the chain is out of the groove and the clutch is slipping BAD. UNPLUG the chainsaw. Check to make sure the chain turns freely around the cutter bar. If it does not move at all, you will need to closely examine the cutter bar to see if it has 'popped' out of the guide path. You must also make sure the chain is on the drive gear correctly.
These are 2 things to look at that can help you. Hope this helps..
Nov 04, 2012 | Remington Garden
After a power problem, tv just emits a high
hello there's a couple of things that could have happened 1. of the capacitor may have blown and 2 the convergance ic have blown which could have taken out the resistors in front of the ic
regards
shaun
Apr 03, 2010 | Sony Grand WEGA KF50XBR800 50" Rear...
The heater in my 1984 f150 makes a loud high picth whine what is it?
It may be debris that found its way down the defrost vents at the windshield to the motor. It is making contact with the spinning fan, causing the noise. It can be a piece of paper, or anything that was on the dash that could fit down inside the vent. It may self destruct and then it will be quiet, otherwise, you will need to open up the fan assembly to remove it.
Jan 02, 2010 | 1984 Ford F 150
I have a high picth squealing coming from my pulley area.
It sounds like you have a Bad Belt Tensioner. Replace that and your Belt should stop Hollerin at ya!
Jan 12, 2009 | 2003 Chevrolet Impala
Loud hissing through rear (souround sound) speakers
I have the Sony Bravia KDL-46S4100. The high-picthed hiss drives me insane. I have a work around but not a fix. Go into your TV's menu and find BACKLIGHT. Adjust it from 1-9 with the house quiet and find what frequency of the hiss is the least annoying.
Sony Bravia high pitch hiss hissing sound high frequency
Nov 22, 2008 | Audio Players & Recorders
RCA D52W19 - High Picth sqealing noise
Thats usually a sign of the flyback or HV Splitter nearing the end of their operational lifespan. However its not an exspensive fix unless done ay a repair shop then it can be a few hundred.
Apr 21, 2008 | RCA D52W19 52" Rear Projection Television
Pitch out of Tune
That is a strange issue. Not sure what could be causing this. Are you describing your issue correctly. Or do the records sound warped? If they sound warped, check to make sure that your voltage setting is set correctly for your area (115V or 220V). This is a switch located underneath your turntable platter. Just make sure you power off your unit before making the switch.
If this is not the issue, then I have no clue what you are talking about, as I've never hear about this on a 1200 turntable, and I work on them for a living.
Please be even more specific, or if you can, give us a call here @ the shop, and maybe play a record for us. Perhaps we can walk you through it over the phone. 1.877.357.7677 ext 1
- DJPROLAB
Feb 11, 2008 | Technics SL-1210 Turntable
RCA D52W19 52" Rear Projection Television Logo
210 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
