Question about SanDisk Sansa e250 MP3 Player
Slowy fades to white
Every time I turn it slowly fades it to white..and than it does it again. I don't know how this happened. I was listening to it right before this happened. I Need help. Pluging it to the computer doesn't work. I don't know what to do.
  • 626 Answers
This will take care of it.
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Best of Luck.
Posted on Nov 17, 2007
Viewsonic va2431wm monitor, lCDd slowly fade from normal screen to white. The monitor turns on but only get white screen, no color. Open monitor, nor bad capacitors. Why no picture?
Hello, unfortunately this is usually due to hardware problem, In this specific situation it is most likely the problem with lcd panel itself (electronic on panel). Sometimes it can work after the units becomes cold (not working for some time) and you power it on again.
Anyway if you are not familiar with electronics , please visit proper service center, due to the high voltage inside.
Hope this helps.
Oct 21, 2014 | ViewSonic Va2431wm LCD Monitor
Thanks for your help. as soon as i turn on the tv there are white lines across the screen that shouldnt be there. and the entire screen slowly fades to white at the same time as sections of the tv freeze...
Tv still have audio sound after it is turn itself all white on the tv LCD screen panel?Yes.Than this problems it is the tv main tv Tuner signal board it is dying and the causes.That the board,where the tv imcomming broadcasting signal cable wire plug into it.U have some skills,like can do some basic mechanicals works like take things aparts and putting it back together again?Yes.Tries websites like, to buy a whole refurbish tv main tv Tuner signal board for the replacement.
Aug 15, 2011 | Toshiba 26AV502U 26 in. LCD HDTV
Before there is a sound when my sister listening an mp3 it slowly fade and totally no sound..i check already the audio driver and reinstall again but still no sound...i don't know what to do.
Check your keypad having any problem (if the volume up/down key present in the keypad itself). If your laptop having separate keys for volume it could have problem. Plz clean the volume down key with help of little bit of isopropyl alcohol. Press volume down key 10-20 times and check.
Jan 18, 2011 | IBM ThinkPad T30 2366 Notebook
Fadded screen
Aug 08, 2009 | Cell Phones
Screen fade to white
Firstly, May be the drivers are corrupted, reinstall the drivers again (uninstall>restart>install drivers and restart).
If it doesnt solve yet then change the slot, put it in other slot.
Apr 23, 2009 | HP Pavilion dv9000t Notebook
Screen fading slowy and then reset
it is a software problem it seems like just hard reset ur device like this if it doesnt help then pls update ur System Rom from
downlaod the software update utility from nokia and then connect the in ternet and update ur ROM thru cable supplied with phone u will get all software for backup and drivers from the nokia website
pls first hard reset like this if it helps PLS RATE ME FIXYA for help !
Master reset
1) *#7370#, then enter 12345 (This is the default security code unless the user has changed it) and then Yes. The phone then wipes all apps and phonebook contacts on the internal memory.
if it doesnt work then try this to hard reset
switching off the phone then press and hold Call key (Green key) + * key + 3 key + power button for a couple of seconds
pls let me know of the results and do rsate me well if i helped u
Apr 13, 2009 | Nokia E61 Smartphone
Car Audio Fade
sounds like you got a bad stereo. it happens. i've i had the same thing happen, but the volume went up instead of down. check all the wires and make SURE they are all hooked up right.
Jan 10, 2009 | 2000 Jaguar Vanden Plas
White Screen of Death?
Its you phone. you have to go to service center and ask to replace its fle or ribbon wire. 100% tested.. Thank you
Nov 13, 2008 | Samsung SCH-a870 Cellular Phone
Evry time i turn on it comes up with sandisk then...slowly fades out white and does this again...untill i reset
Mine does the same thing. Every time I turn it slowly fades it to white..and than it does it again. I don't know how this happened. I was listening to it right before this happened. I Need help.
Nov 17, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
