Panasonic TC-L32X2 32-Inch 720p LCD HDTV with iPod Dock from Logo
Cindy Edison Posted on Jan 09, 2016
Sound issue on one channel only
I am trying to watch a local channel for football. I can hear background noise but when commentators come on I get nothing. The other TV in the house is fine. Some commercials are good some are not. The other channels are fine too
2 Related Answers
Anonymous
  • 14553 Answers
  • Posted on Sep 04, 2012
SOURCE: Interment or no volume on certain channels.
make sure set not set to sap mode as this can blank audio on certain channels
xavyko
  • 9 Answers
  • Posted on Nov 06, 2013
SOURCE: TV drops sound only on one channel, during network shows
the SAP is activated
1helpful
2answers
Background noise on football is louder than announcers
Often the root of such a common problem is the sound mixing at the transmission end - too many people today believe louder is better, though I am not sure if it is a fashion or a disease.
The set up of the tv or radio often doesn't help matters due to the average sound reproduction of such being biased to enhance midrange frequencies and up - the sort of typical crowd/applause noises that doesn't give commentators much of a chance.
Listening via hifi would give a chance to adjust the filters especially if there is a graphic equaliser.
Lcd tv music is too loud to hear voices
hi i don't know if this will work go into the menu on the tv look for noise reduction turn it off or check your sound settings hope it helps
regards
shaun
When we watch football, we can't hear the refs on the field. Also during halftime we can't hear the music. Some random things get cut out.
do you have a center channel speaker hooked up? Most voices come through the center channel. I would imagine the surround processor would put the refs on the center channel.
When i watch dvds,the background noise is loud
Go to your set up menu, navigate to speaker set up and check your sound levels to front, center, and rear channels. Adjust as needed to fit the room. My Sony has a test tone option which sends a signal (at levels selected) to each speaker to check sound level and if speaker is connected and in right place.
DVD movie background sound too loud to comfortably watch!
on some dvd players and surround sound systems have a thing called DRC (dynamic range compression) you can us that and it will help it a little. i have come across the same problem but im after a digital on to run with plex or vlc on a mac. im having to route it through protools to use a compressor on there, but thats eating my resources.
I recently bought a Sony STR -DG820 and hooked up everything using HDMI cables and I am having touble with the sound. I can hear on some channels, but not others. The channels that are having the audio...
hello to ensure your`re having good sound. hook up in other way not using hdmi cables,the background noise usually indicating a good carrier frecuency but no clear check good cables,not pinched,broken or if it has radio the air antenna or fm....if you got good sound now use the hdmi cables and take a close look in the connector if all pins are good at each end saludos
14helpful
2answers
Direct TV DVR sound/no picture or pict. no sound
My Direct TV has no sound or picture but does show channel info at the top. Any help is appreciated.
95helpful
9answers
Background sound too loud
Thank you, everyone! I thought maybe I was losing my mind. I can hardly watch a lot of the TV shows anymore due to the inappropriate use of music -- either it's too loud or there's just too darned much of it. Come on, TV producers! You are supposed to get better with time, not worse! Thank goodness I'm not alone.
Distorted and low volume voices - Mr French
hi, first u will have to determine if the center output is bad or the cntr speaker is bad, to do so do not disable the center, simply remove the speaker wires and check if there is noise, if not means speaker is bad, if still noisy then output is bad,u will then need a technician to get the job done.. letr me know..
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
