Question about Dryers
Sears Kenmore Dryer 400 series won't start
My kenmore dryer is only 2 years old or so. For a few weeks it's taken 2 cycles to dry clothes thoroughly. Cleaned lint trap and vent to outside: no obstructions. All of a sudden it won't start. It's getting power (light comes on inside when door is open, so door switch is working), but when I set the timer it doesn't appear to make any noise. I took the back off and looked at the various thermostats and the thermal fuse (with the exception of the thermostat behind the blower), but not being an electrician, I can't tell if these parts are still working or not. They all seem fine on the outside. I removed the element and looked at it - it's dark but not 'burnt' in any way. I'd like to take a crack at fixing it myself, but the parts are rather expensive. If I replace the thermal fuse, should I replace the thermal cut off as well? Is there any way I can nail down the defective part rather than buy parts at random until I hit upon the right one? Any particular order I should replace parts? (any end to my questions? ;) ) The heating element seems like the most likely candidate, because of the prior issue with not drying on the first cycle, but that could be a thermostat issue as well, with the cycle cooling down prematurely (I guess...).
Sears kenmore 400 series dryer - model # 110.67222600
Electric (220) 3 wire - front loader
Any help is appreciated!
  • 230 Answers
Just some advice on the electrical components behind the machine. The thermal fuse (the long white fuse) should read continuity. set your meter to beep and it should beep. same goes with the thermal cut-off that's above the heating element, and same goes with the element. if it doesn't start, it's probably a thermal fuse. Good luck :) email me if you need help. appliance800@yahoo.com
Posted on Jul 15, 2009
the dr
  • 447 Answers
SOURCE: Thermal Fuse
First of all stop replacing the fuses and using the dryer it could burn down your house. The problem is the vent is clogged (not necessarily in the dryer) make sure also that the vent flex is not excessively long behind the dryer and is not kinked when the dryer is pushed back.
Posted on Nov 19, 2007
  • 131 Answers
SOURCE: Dryer runs but doesn't heat up when sttings call for heat.
You may need to do some troubleshooting. This can be done with the machine unplugged - you may have to activate the start switch, belt switch (if it has one) and the motor centrifugal switch manually.
Tip for troubleshooting 220v systems - clip one lead of a ohm meter to either L1 or L2 on the terminal block. It doesn't matter which one. According to the tech sheet (under console) follow the path for current from your clipped terminal, through the heating element, to the opposite terminal. All the readings should be less than 100 ohms, until you reach the failed part. Confirm failure by disconnecting a lead from the suspected part, and test only that part.
Live troubleshooting is sometimes slightly easier, but much more dangerous than the procedure described above. - It is definitely not recommended for beginners, or for professionals, if it can be avoided.
Posted on Mar 10, 2008
ronpar
  • 27 Answers
SOURCE: Whirlpool Duet Dryer - Working but no heat
it sounds like your heating element is gone bad. there is no heat if they burn out or get corroded
Posted on Jun 29, 2008
kachbibi1
  • 979 Answers
SOURCE: dryer doesn't dry clothes thoroughly
Turn off your breakers, then back on to insure a good reset. Then check the wiring from the receptacle, to the plug and then to the back of the dryer. You are getting some heat which tells me that one leg of power is out. I don't think it is your element, because you get some heat. Let me know how you do.
Posted on Feb 10, 2009
  • 108 Answers
SOURCE: Stopped heating. Did thorough cleaning of lint
take off the back at the heating element there are twoo wires undo at least one of them and check the contnuity [before you do this unplug the dryer] if you have a reading on you maeter it isnt the element check the thrmostat, i hope i helped.
Posted on Dec 30, 2009
410e buzzer keeps buzzing after switch is off
sears kenmore dryer when dry cycle is done buzzer keeps ...
www.shopyourway.com > Manage My Life > Questions
It can be very annoying when the buzzer to your dryer will not shut off after the ... push to start switch as soon as I close door also buzzer keeps buzzing at end of ...
My dryer end-of-cycle buzzer will only stop buzzing when I ...
I see your dryer buzzer will only go off if the door is open. ... Dryer #11079622800: End of cycle buzzer won't stop buzzing after cycle is complete. ... sears kenmore dryerwhen dry cycle is done buzzer keeps buzzing. will not turn off unless you ...
Why won't the buzzer shut off on my Kenmore 80 Series ...
The buzzer won't stop buzzing after the load is complete. ... The buzzer won't stopbuzzing unless you open the door or turn on the timer and the dryer will start ...
Keep Your Dryer Quiet - Instructables
Dec 14, 2015 | Dryers
Kenmore 400 series gas dryer doesnt dry clothes
Replace timer, if you are sure that it is not working.
Do an internet search for kenmore driver parts and get dozens of hits.
Aug 03, 2014 | Kenmore Dryers
Why isn't My Kenmore Heavy Duty 70 Series Soft Heat Extra Capacity Electric Dryer drying clothes on any one cycle?
One possibility: Air flow! Make sure that the lint trap is cleaned before each cycle. You likely need to thoroughly clean out the vent piping out the back of the machine- a buildup of lint in here can also restrict airflow.
Sep 04, 2012 | Kenmore 659 Electric Dryer
We have a Kenmore 400 Series dryer. It heats up but our clothes is not getting dry. We have to cycle it twice to get our clothes dry on high heat. Any idea why it would take 2 cycles to dry?
This was the out vent of my dryer... If it gets this bad... open up the dryer housing and clean inside too. Also make sure the intake is free of lint.
Aug 23, 2010 | Kenmore 74602 Gas Dryer
My kenmore 70 series dryer will not heat upa nd
bad ignitor
or bad solonoids on your gas vale
check your lint filter
and exhaust outside to be clear of cloggs with good airflow while running
Oct 05, 2009 | Kenmore 73952 Gas Dryer
Dryer Gets Too Hot!
Could be the heat switch on the motor or a grounded heat element
May 20, 2009 | Kenmore 400 6942 Dryer
2 to 3 cycles to fully dry clothes
if the clothes are warm after the cycle then you need to make sure the vent to the outside of the house is not plugged if they are not warm then it is in the heating circuit of the dryer wether it be the element or a fuse will have to be tested. to dry clothes it takes heat and air flow if you dont have one of the two they will not dry correctly
May 18, 2009 | Kenmore Elite Oasis 6808 Electric Dryer
Dryer cuts off before clothes are dry.
Might be the thermal protector in the motor that is shutting down the dryer, if motor overheats this is what will happen. Make sure there is no lint build up around the motor, if not the motor is bad. does the dryer start right away after shutting off or do you have to wait? If you have to wait the motor is bad.
Jan 13, 2009 | Kenmore Elite HE4 Electric Dryer
Clothes don't dry but dryer gets hot
ck vent to outside starting and dryer back to verify vent issue try drying a load with hose disconnected
Nov 24, 2008 | Kenmore 60172 Electric Commercial Dryer
Dryer f51 error
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Good news for Oasis F-51 sufferers! Sears will replace the electronic control board (the F51 prob) for free, in warranty or not. Serial #s for the bad board are: CS48 - CS52 or CT01-CT49. Call Sears at 800-847-9083.
You hv to rate me ‘very helpful’, or the call won’t get thru!!
Nov 04, 2007 | Kenmore 67082 Electric Dryer
Dryers Logo
654 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
