Garden Logo
A
Anonymous Posted on Jan 09, 2016
2014 New Holland T495. 10 below zero today & tractor starts fine, then shuts itself off. When I restart, why doesn't it move & then shuts down again?
Bill Boyd
Level 3:
Top Expert:
  • Garden Master 53,816 Answers
  • Posted on Jan 09, 2016
Bill Boyd
Garden Master
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11925401
Points
172802
10 below is very cold so there may be sensors in the tractor that is preventing damage from icing
could be the fuel is freezing, coolant frozen, oil to thick to lubricate properly
I have a nh ts125a and the pto symbol and the ! Is on pto works fine the parking brake light is also on the brake is disengaged
Ford New Holland TS135a TS125a TS110a repair manual
www.slideshare.net/.../ford-new-holland-ts135a-ts125a-ts110a-repair-ma...
Feb 8, 2014 - New Holland TS100A TS110A TS115A TS125A TS135A Repair ManualComplete Factory Service Repair Manual New Holland Fuel Injection ...
My New Holland TC-30 tractor runs fine but when we start it, the fuel & water gauges slowly go up and finally peg, staying pegged until we shut it off.
First thing ALWAYS is to check the grounds. It's a bad ground connection on the gauges at the sending units.
Simplicity zero turn electrical problems
charge the battery not hooked up to the mower let it sit overnight and try again the battery might just be died they only last a couple years put a volt meter on the battery when off then start it and watch the battery voltage should be around 14 volts running the pto clutch draws the most thats why it shuts off first the ign doesn't take any the carb needs very little
Apr 22, 2012 • Garden
Crafstman riding mower cutting off now won't start at all
The two most likely suspects for the symptom you describe are:
a) Ignition coil failure under high heat.
OR
b) Decompression failure due to normal wear.
For a positive diagnosis try the following:
For scenario a)
Run the engine until it shuts itself down. As quickly as possible, check for spark using a spark tester (availabe at local auto parts store). If no spark when hot, allow to cool down and test again. If good spark when cold and no spark when hot, change the ignition coil.
Proper part number (assuming your machine is still all original) Briggs & Stratton part #492341.
For scenario b)
Run the engine until it shuts itself down. Try to restart but pay close attention to the speed of the spinning starter. Next, remove the spark plug and spin the engine over (WITH SPARK PLUG WIRE WELL OUT OF THE WAY!!) If the engine spins super fast and free you can discount the theory of a bad battery and you will need to adjust the valve lash.
Determine which is the case and reply to this post. I will gladly give a detailed explanation of the valve lash adjustment procedure in another post.
Hope this helps!
6helpful
3answers
Craftsman zero turn - blades won't engage
The PTO switch contacts to operate the clutch that starts the blades is defective. I have replaced mine and the new one just failed again. Sears must know this is a defect problem but so far they are quiet about the problem
Top Garden Experts
Jay Finke
Jay Finke
john h
