Question about HP Compaq nx9600 Notebook
Arc occurs when plugging in the power supply
My compaq presario laptop will not power on or charge the battery, when I plug it in an arc occurs at the connection. is the the DC connector shorting out? if so, where do I get one to replace it?
    Scholar:
  • 35 Answers
Does the green light come on when it is plugged in? Take a look at this post on the HP forums http://forums11.itrc.hp.com/service/forums/questionanswer.do?admit=109447626+1247634351946+28353475&threadId=66918 . In case the link doesn't work, I am including it at the end of my response. From the looks of it, if it is still under warranty you need to go and have Compaq do something about it. This appears slightly common amongst those notebooks (common enough to quickly find more cases of the same problem in a google search). If you are under warranty, this guy describes a delicate fix for it.
[from HP forums] "I recently acquired a second hand Presario 1200 (model 12XL300) from a frustrated owner who could no longer get it to turn on, just had the green light when the power pack was plugged in. After completely disassembling the computer and removing and inspecting the mother board, It was evident the problem was the power jack attachment to the board.
In a previous thread, a poster had described this point as a cold solder joint and had temporarily fixed it by re soldering. The problem is that it's more like a no solder joint. The circuit board area that should receive solder to mate to the rear lug on the jack is covered with the green protective coating to prevent solder adhering. The only exposure is the edge of the hole which only allows a few thousandths of an inch exposure to solder.
The jack is then straining against this minute connection every time the power supply is plugged in. As the joint fails, less and less power is able to be transmitted through it until none can be.
The fix I made was to use a dental pick the chip off the coating to the bare copper around the lug. This is pretty delicate work and the copper can be easily damaged. Then I re soldered, again delicate work since direct heat to the board can delaminate it. Next I put a drop of super glue between the jack body and the board to try to eliminate any flexing when the power is plugged in.
The computer works flawlessly now. In my opinion, this is decidedly a manufacturing defect that should have been caught by inspection of the boards prior to assembly, or certainly after the solder process as very little solder was adhering to the joint. These boards are manufactured in large batches, and there must be many that have failed in warranty or are in the process of failing. Again, in my opinion, it's inconceivable that HP/Compaq is unaware of this defect." -D Stansbery
Posted on Jul 15, 2009
  • 107 Answers
It is likely that the dc connector is bad. I would find a new one on ebay and then locate a good technician that can solder to put it in. Motherboard will have to be taken out of the computer to do this so make sure you use a good "LAPTOP" technician as this can be a bit difficult
Compaq presario 7pl290 will not power on
Make sure that the battery is charged or plug in the power supply.
Jan 17, 2013 | Compaq Presario 700 470024-192 Notebook
My compaq presario c795tu battery is not charging
Unplug the power supply, take a stiff tooth brush and clean the battery terminals in the laptop plus the battery, re-install the battery and plug the charger in, If that fails you need to find out if the charging circuits are putting out the proper voltage before you replace the battery.
Mar 04, 2012 | HP Compaq Presario CQ40-330TU
My laptop HP PRESARIO V1000 won't start without charger plug in. When push on, the charge led blinking for eight times then nothing happen. it start normally when I turn on with charger plug in, after...
It sounds like the Battery is Dead or not charging. You might try a local pc shop and see if they have any laptop batteries for you laptop. Or have them test to see if the battery is charging.
Dec 11, 2010 | Compaq Presario M2000 V1000 V2000 V3000...
Compaq presario v6000 laptop plugged in but not chargin
YOU NEED TO RECALIBRATE YOUR BATTERY. FIRST UNPLUG THE POWER CORD AND LET YOUR BATTERY RUN ALL THE WAY DOWN TO 5%. THEN PLUG YOUR POWER CORD BACK UP AND LET IT RE-CHARGE THE COMPUTER. SOMETIMES WHEN YOU FREQUENTLY UNPLUG YOUR AC ADAPTER YOUR BATTERY FORGETS HOW MUCH POWER IS ACTUALLY AVAILABLE IN CONJUNCTION TO WHAT THE BATTERY METER IS SHOWING. RECALIBRATING THE BATTERY WILL RE-SET THE METER WITH THE BATTERY.
Apr 06, 2009 | Compaq Presario Notebook
Compaq Presario M2000 DEAD
My power plug that goes in the computer gets hot enough to melt the plastic ring on the end of the plug. so i am going to get a new power board and try that.
Jul 27, 2008 | Compaq Presario M2000 Notebook
My compaq evo stopped working. For about two weeks I had a buzzing where I place the power cord. At that time periodically the whole thing would shut down. Also now it will not start at all and the...
Allen -
It sounds as though you may have either blown the power supply, or burned the power circuit on the motherboard. That buzzing sound usually indicates an electric arc, where electricity passes through open air from one contact to another; In this case, it was probably caused by a loose or broken solder connection on the laptop's power jack.
If you can get your hands on an identical or equivalent power supply, test it with your laptop. If it works, then the power supply just needs to be replaced.
If not, try taking the battery out of your laptop, and plugging it in again. Sometimes, when a power supply burns up, the battery will discharge, rendering it inoperable.
Hope this helps!
-thinstatic
Jun 13, 2008 | HP Compaq Evo Notebook N600c
No power
Hi there!
Where you saw the Arcing, check closer to see wether the components are not loose on the board. You may only have to resolder the joints and problem solved. If the arcing takes place towards the tube, then you have a more serious fault. Thus involving High Tension, so I would not advise trying to repair that area if you are not familiar with TV repairs. Please unplug set before commencing any work. Regards and good luck, JUS004
Mar 31, 2008 | Sony KV-32S26 32" TV
Compaq Presario 1200 won't charge battery
dear N9YK
you can follow this
If you have a loose connection where you plug in the power on your laptop, or it works intermittently, you could have a bad dc jack. Symptoms
  • Move the power plug and the laptop loses connection
  • Broken or cracked dc jack
  • Laptop won't charge but worked on battery
  • Power LED and battery LED flicker when the adapter tip is moved
  • Battery won't charge
  • Sparks come out the back of the laptop
Why does this happen?
  • Flaw in manufacturer designs
  • Use of universal or non-original ac adapter
  • Lots of plugging and unplugging of the ac adapter
  • Tripping on or pulling the ac adapter cord
or you can check your dc amper in your adaptor
oke
thx
cropp
Mar 16, 2008 | Compaq Presario 1200 Notebook
Notebook smells like burning plastic.
If the new Targus charger is really rated correctly for your laptop, your battery isn?t charging and you smell the burning plastic coming from the laptop when you plug it in that is a fairly dangerous situation and you shouldn?t plug it back in anymore. The power from the charger runs through a PCB board which distributes power to other components in your laptop. I suspect one of the components (probably a capacitor) had a catastrophic failure and is the cause of the smell and the lack of battery charging. Once again assuming that the Targus is the correct one for your laptop current you probably have a laptop damaged beyond home or economical repair.
Dec 02, 2006 | Compaq Presario 700 470024-192 Notebook
HP Compaq nx9600 Notebook Logo
165 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
