Question about Altec Lansing VS3121 Computer Speakers
I have the same problem
Not sur ehow to fix it. either one side or the other works and i know its the control for the knob because if i touch it slightly it fixes the problem. i've been wedging little bits of paper in it for some time.if anyone can help...maybe instruction on how to open the unit...would be great
  • 398 Answers
Ok go to radio shack get a can of contact cleaner , pull the knob off and spray some cleaner in it. turn the knob back and forth a few times and your back like it was new!
Posted on Jul 15, 2009
Stitch selector knob on bernina 600, not Deco, is stuck and cannot select needle position, However the width of stitch part of the knob is working.This knob has 2 parts, needle position and width control
Your machine (Bernina 600 Record) has most likely frozen (seized) due to lack of regular maintenance. Don't panic. It can be fixed with a lot of elbow grease, good quality oil and a hairdryer. The following method has resurrected several Berninas I've picked up as "nonworking."
How can fix stuck needle bar on my Bernina 730
Wheel on right side that controls the needle up and down is very tight...
It was working now it seems to be frozen the needle part wont move
Nov 01, 2016 | Bernina Sewing Machines
Continuous clicking from an igniter in the off position. I have to slightly turn the control knob towards the hi position to stop the clicking and for the light on the control knob to go off
sounds like it was turned a little past the stop point.
Pull two knobs off and examine the back side that slides onto the shaft.
Switch them and try again.
If the problem is on the same burner, the shaft may be turned past its normal stop position.
You can try turning it until it stops in the opposite direction and force it just a tiny bit more.
That was how I fixed mine.
Nov 06, 2013 | DCS 36 in. CP-366 Gas Cooktop
Headlights stay on too long after engine is off
been working on the same issue for a week. fixed it last night after research and trouble shooting. The head lights are controlled by the head light dial/knob on your dash on the left side of your steering wheel. With the knob pushed in, if you shut down your car, the lights should automatically shut off as well. Mine didnt so what I did was i turned off my car, disconnected the positive battery terminal located inside a fist sized red box on the right side of your engine. Then I took off the dash panels to get to the actual connection on the headlight switch/dial/knob. I disconnected it and put it all back together. It fixed the problem.It worked for me, maybe theres an easier or faster way of fixing it but this worked. Good luck.
Dec 13, 2012 | 1998 Buick Riviera
I have a KUD101FL533 Kitchenaid dishwasher. The other buttons light up and the cancel button works, but when I hit "start" nothing happens. From what I have read, it may be the control panel. Do...
Hello, Christi,
What i would try first is see if perhaps the ribbon cable has come loose from the control panel the touch pad is separate from the control board and its entirely possible that its bad and not the control panel.Also i would surly want to check to door switch as well since they are more common problem than either the touch pad or control board ..to me its sounds like possibly the door switch is the problem since it thinks the door is open and wont allow it to start since the door switch thinks its open .
Please respond if you should need further assistance.
GENE
Oct 18, 2011 | KitchenAid 24 in. KUDI01IL - Multiple...
I can't fix the toutch screen it wont let me use the stylus to use the icone on the screen when it dose work you but you have to be way above or way down it will not let us do any thing with the...
Has the system been dropped recently? Also, do you commonly store it in your pocket while you are on the go? To me, it sounds like the touch screen may have a slight bend in it, which can be caused by either one of these things (or perhaps something else all together). Any time that tension is put on a touch screen, it has a chance to bend slightly. Even a very slight bend in a touch screen can cause it to work improperly. Many touch screen cellular phones have this issue, and it is becoming a common problem with many touch-screen devices. Fortunately, Nintendo is able to fix these relatively quickly. It will likely still be under warranty, and you probably won't have to pay for it. Here is the website where you can get started.
http://www.nintendo.com/consumer/repair/repair_options.jsp
May 16, 2011 | Nintendo DS Console
Brother i have just opened a wireless network but my wireless network is not working properly. Can u plz contact me for some help i shall be very thank full to you if u do this favour for me. Thanks...
Troubleshooting issues with wireless connectivity can be tricky. There are a bevy of potential causes for drops in the connection, slow-downs in throughput and sporadic signal loss. As such, it's best to take a shotgun approach, throwing a number of possible fixes at the problem and hoping one sticks.
Check if your laptop's wireless switch or button is turn on - look around the laptop in front, back or sides. Sometimes you might touch to turn off accidently and you don't know. Many laptops have the wireless light indicator, check if the wireless light is on and blinking.
Look for F1 to F12 functions keys, they are on the top row of the keypad. Look for one has an icon that looks like the wireless, which is to control the wireless connection of your laptop. It maybe F8 or F9 depends on each make of your laptop. These function keys also control the brightness, sound, touchpad etc. You will need to hold down the Fn + F8 combination keys together, in this example the Toshiba laptop's wireless setting.
  • 3
    Check Network connections; make sure the laptop connection is not 'disabled'. It should has the gray color if it's disabled. Right click on it and enable it.
  • 4
    If none of the above works, you will need to enable the Wireless Zero Configuration in services.msc (type this in from Run command), or you can see it this way: Right click My Computer -> Manage -> Services and Applications -> Services.
  • Read more: How to Fix Wireless Not Working in Laptop ' eHow.com http://www.ehow.com/how_6066601_fix-wireless-not-working-laptop.html#ixzz1LiJNokX7
  • 2
  • 3
  • 4
  • Read more: How to Fix Wireless Not Working in Laptop ' eHow.com http://www.ehow.com/how_6066601_fix-wireless-not-working-laptop.html#ixzz1LiJ8lq45
    May 07, 2011 | Computers & Internet
    The small knob that moves the slideto the left or right on the platform (the one furthest from the observer) is slightly loose, and instead of rotating in a smooth circular motion it rotates rather...
    The knob you are talking about is called the x-axis control knob. It does not directly affect the focus. What affects the focus is the slight manipulation of the stage and or slide while you are adjusting the x-axis control knob. It only takes the slightest pressure to throw the focus off very far. Theoretically you could completely remove the specimen holder and move the slide around with your fingers.
    The specimen holder may need to be replaced but without further more detailed knowledge of the mechanical problem I cannot instruct further.
    Oct 05, 2010 | Premiere Microscopes P-01310 Monocular...
    Kenmore gas range 79071323700 makes noise when any knob is turned on and the noise stays until knob is turned off. How can I fix this?
    sounds like the switch harnes is bad or you have a wire shored.
    Switch harnes is part number 316219006
    you realy need to inspect the switch harness and where the conction wires go make sure they are not touching ground.
    Make sure you unplug the machine. the harness includes all 5 switches that slide over the control knobs and are conceted all together and then one wire side goes to power and the other gose to the spark modual.
    Jan 11, 2010 | Kitchen Ranges
    Dash Control Unit Replacement
    You can save a LOT of money by fixing it yourself.
    All that is wrong with the knob are broken wires from the knob's PC board to the main PC board on the AC control.
    All you have to do is remove the AC main control, take it apart, and resolder the broken wires from the PC board with the knob on it, to the main AC pc board. There are 3 wires, any number could be broken.
    If you take it apart and solder the broken wires, this WILL fix your issue. Just make sure you put the wires back exactly where they go.
    A FIXYA rating (4 blue diamonds) would be most appreciated for my assistance.
    Mar 21, 2009 | 2002 Toyota Highlander
    Volume knob problem
    This is a problem with poor cold soldering at the bootom of the volume pot, what has to be done is slowly seperate the glued seem where both speaker halfs are "glued"LOl... yes glued together,...Use a small flat head screw driver of any sort and work the way around it and it will seperatel and then resolder the volume pots circuit board pins, then use ABS to glue it back together, dont foregt to get the blue LED power light indicator set right before pressing both sides together.... (^_^)
    Aug 21, 2008 | Altec Lansing VS2121 Computer Speakers
    Altec Lansing VS3121 Computer Speakers Logo
    80 people viewed this question
    Top Altec Lansing Audio Players & Recorders Experts
    Carlos L. Burgos
    Carlos L. Burgos
    Sharps s
    Level 1 Expert
    Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
