SOURCE: change ringer from lo to hi
Do you know the model #? If so, you can get the owners manual from the the uniden website. Here is a link to the page so you can look for your specific model number. Just click on your model number and it will load the pdf format of the owners manual.
http://www.uniden.com/index/manuals_results.cfm?cat=1
SOURCE: CHANGE RINGER FROM HI TO LO
SOURCE: ringer on
Here is a link to the Tru8885 manual:
http://www.uniden.com/pdf/TRU8885om.pdf
Rollin CBs
Dean
SOURCE: Uniden 5.8GHz can't turn ringer on
You should be able to go to the handset and do that. Hit the button above the caller id until you can hear it.
SOURCE: how do you adjust volume on base ringer on uniden dxa15588-2
Setting the Main Base Ringer Volume
The main base has three ringer volume settings: high, low, and off. You can change
the ringer volume while in standby mode or while an incoming call is ringing.
1) Press the ringer key.
You hear the ringer at the current volume level
([ ] High, [ ] Low, [ ] off) (if you set the
main base ringer volume to off, “Ringer off” is
announced) and it is displayed on the main base.
2) Press the ringer key repeatedly until the desired ringer
option appears.
3) The system displays the new ringer volume.
