Question about PPI PC650C Coaxial Car Speaker
I need to know who is better for my cherokee sport 1999 ..!!!
Hi i have a doubt about 2 models of speakers for mi car.. who is better ? PC650c from ppi or MB QUART FSA-216 ????
thanks
attn.
leonardo lugo
  • 655 Answers
Hello leonardoe,
The MB Quart's are component speakers and the PPI's are coaxials. In an "apples to oranges" comparison, the MB Quarts win. Most component systems in the same price range as a coaxial will have better sound imaging simply because you can mount the tweeters up high for better high frequency dispersion. Some also allow you to make adjustments to the crossover, which is built-in and fixed on the coaxial.
But component systems are more difficult to install. If your vehicle doesn't already have the wiring for separate tweeters, you have to install it. Likewise, the mounting of separate tweeters adds to the installation complexity.
Hope this helps.
Posted on Jul 16, 2009
1999 Cherokee Sport has four speakers, two front and two rear. All speakers work except the one in the fronr driver side door. I swapped this speaker to the other side and it works fine there. ...
To eliminate wiring issue take good speaker and hook it up directly to the left front output - if it does not work then that amp is blown. Period.
Aug 14, 2017 | 1999 Jeep Cherokee
1999 jeep cherokee sport it wont start cranks but wont fire
Figures...I'd use 2&3 as b&c Open reading means that with the meter set to ohms and turned on, the meter should read the same connected to the terminals as it did before you connected it.
Oct 29, 2009 | 1999 Jeep Cherokee
Where can I find a fuse chart for 1999 Jeep Cherokee Sport?
Welcome to fixya. Here are some you may have to get the amp charts from jeep. If you need anything else go to www.collisionrepairadvice.com
Locations Notes 8w-12-2 78230026
Jul 26, 2009 | 1999 Jeep Cherokee
1999 cherokee sport 4.0L engine is same as any 97-01 4.0L?
USE THE INTAKE AND EXHUT MONIFUL FROM THE 1999 IS OK
Apr 17, 2009 | Jeep Cherokee Cars & Trucks
I know you would charge a fee, but would you have access to a radio unlock code for a Chrysler 1999 Jeep Cherokee Sport if VIN # provided?
okay you need to go to radio code .com thats radiocode.com they might charge you but you will need the vin num make and model kk
Jan 29, 2009 | Car Audio & Video
Are the Window regulators for the Cherokee Sport and the Grand
Check with a local scrap yard... they would know best. As far as I know, unless there is a difference in door shape, regulator should be the same. Name differences generally denote trim packages, and don't affect hard parts that much.
Dec 21, 2008 | 1999 Jeep Cherokee
Need to change my thermostat on my 1999 Jeep Cherokee Sport 4WD
I do not know a link to a diagram, but I can certainly tell you how to find the thermostat! Looking at the front of the engine, there is a large water hose at the top of the motor that goes to the left, and attaches to the radiator. Not the radiator end, but the other end attaches to the thermostat cover. It has 2 bolts to take out and the little thing between that, and the motor about 2" around that kind of looks like a spinning top, is the thermostat. It is easy to change. Make sure you get ALL the old gasket off and that both bolts go through the new one, and you should be in business!
Dec 21, 2008 | 1999 Jeep Cherokee 4WD
99 Grand Cherokee blown speakers
You have to remove the door panels and as for the price-your better off buying aftermarket speakers.
Oct 03, 2008 | 1999 Jeep Grand Cherokee
99 cherokee radio problem
Either the radio's output ICs are fried or speaker/wires needs to be checked.
Incidentally, there are some higher end versions that has an Infinity Amplifier (P/N: 56038407AD) powering the speakers and not the radio (alone). If so, this amp needs a trigger on from the head unit to work and therefore, the trigger wire/connection must be checked. Otherwise, it may likewise require an internal check.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 12, 2008 | 1999 Jeep Cherokee
PPI PC650C Coaxial Car Speaker Logo
63 people viewed this question
Top PPI Car Audio & Video Experts
Jose Velazquez
Jose Velazquez
hoyzee1
Are you a PPI Car Audio and Video Expert? Answer questions, earn points and help others
