Question about Pentax Optio T10 Digital Camera
Flash stops working
Just saw your email. I wa overseas and the camera was just 1 month old. Had to send it to another country and it was 'not fixable' so they send me a new camera one month later. Fortunately I had a second camera with me (learned from experience). The Pentax has been fine for the last two years, except the battery hold-down clip is broken. Seems a common problem. Will contact Pentax to have it fixed.
    Problem Solver:
  • 14 Answers
The flash bulb may be broken. Try contacting Pentax to get it fixed.
Posted on Jul 15, 2009
Video screen flashes on then off/display driver/fixable?
I had same problem 1 month ago in the end realised that CPU is ded.
had to change from 2 duo e8500 to 1.8Ghz core :(
Feb 16, 2014 | Computers & Internet
My flash has stopped working on my D60. It is engaging, and everything is turned on, but no flash. A detachable flash works. Is it possible that it has burned out? And is it fixable?
Hi, It's possible it's the flash tube and that its burnt out. Since an external flash works it doesn't sound like it's the circuitry which is a good thing. The flash tube being burnt out is fixable however it's a fix that needs to be done by a professional. If your camera is still under warranty you can send it into Nikon for repair. If it's not under warranty you can still send it into warranty or you can find someone in your area who specializes in camera repair (as that would likely be faster then sending it to Nikon). If you have anymore problems feel free to message me and I can help you out =)
May 17, 2011 | Nikon D60 Digital Camera
The laser stopped working on Hitachi 12'dual compund mitr saw,are there batteries that can be replaced or does the unit need to go to a tech? The laser only worked for a month and the saw is only 3 months...
The laser modules in saws are usually powered by induction from the spinning saw blade. Since your saw is only three months old hopefully you either registered it with Hitachi when you bought it or you still have your receipt as this type of failure would be covered under warranty. Call Hitachi, they may send the part to you if you are comfortable with doing the repair or they will tell you where the nearest Authorized Service Center is for warranty work. Hitachi's number is: 800-706-7337 or 770-925-1774.
Jan 27, 2011 | Hitachi C12FDH 15 Amp 12Inch Dual Bevel...
HOW TO SEND FAX INTERNATIONALLY
Sending a fax to another county is easy - almost as easy as sending a fax to someone in your own country. The only difference is the phone number that you'll dial.
When sending a fax from one U.S. city to another, you dial a 1, then the area code, then the seven-digit phone number. When sending a fax from the U.S. to another country, you usually dial 011, then the country code, then a city code (which is like an area code), then the phone number. (The phone number isn't necessarily seven digits.) Check out the web site www.HowToCall.info, which will give you the specific country and city codes for the place that you're trying to send a fax to.
Other than figuring out the phone number, faxing internationally is identical to faxing domestically. Fax machines in other countries use the same protocols as ones in the United States, so you should have no difficulty communicating with a foreign fax machine. Older fax machines and noisy overseas phone lines may cause the transmission to take a bit longer than you're used to, but it should get there.
The first time you send a fax to another country, it might be a good idea to listen in as the fax machine dials. On some fax machines, you can press the "Dial" button to hear the dial tone, and dial the number manually. Listen for the ring and fax tone, then press the Start button to send the fax. You might want to do this the first time you send a fax overseas, just to make sure it's working as expected.
Oct 06, 2010 | Office Equipment & Supplies
What are the differences in Nikon 'overseas' models as US models?
It depends. Nikon USA has a strong tendency to not honor warranties originating in other countries. If you feel you don't need the warranty, go for it.
There shouldn't be any differences in the batteries themselves. The chargers, of course, are adapted to the local voltage and outlet configuration.
May 16, 2010 | Cameras
Flash stopped working
If you cannot find a solution to your problem you may want to email fixityourself@gmail.com. He has good advice and good used parts at a fair price.
Jan 19, 2008 | Sony Cyber-Shot DSC-T33 Digital Camera
Sony t20 vibration problem
Sounds like the T20 lens mechanism problem. Certain serial numbers for overseas cameras are also recalled so check with that countries Sony website.
Dec 26, 2007 | Sony Cyber-shot DSC-T20 Digital Camera
Fill flash/ flash setting for backlit
Set up the flash
When ready to shoot point camera to a dark area[the ground?] and press the release HALF WAY- holding it there point camera at subject and shoot.
Oct 03, 2007 | Nikon COOLPIX S200 Digital Camera
Pentax Optio T10 Digital Camera Logo
79 people viewed this question
Top Pentax Cameras Experts
mohamed salim shaikh
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
