Question about Exercise & Fitness
Repco Sports Treadmill
I have a similar problem with a Repco Sports Treadmill.Runs for 3 minutes then stop with beeping sound from electronic display.Can't seem to find anyone to repair it.
Repco RP300TM wont start E1 error message
Posted on Jul 14, 2011
  • Jenny Batten Nov 17, 2011
    I have the same problem, looking for solution?
    Problem Solver:
  • 4 Answers
Hi guys, while I was waiting for some answer fron EXPERTS, I Fixed the momentum T7, if I start a normal walk with cero inclination and low speed motor does´nt move but all data in computer appears normal. So, if I order a walk with 10 percent of inclination or more up the running belt moves normal. SOLUTION: Cable Driving motor from computer to driving motor travels trough upright left body and base frame, it had been crushing for main frame making damage in the plastic proctection of this cable, so each time that cable touched main frame produced a short circuit only hapenned with cero inclination, I fixed short circuit in main cable and protected the cable it self from crush with main frame.
I hope this solution helps someone.
Carlos González J.
camagoj@une.net.co
Posted on Sep 30, 2009
Runs a few minutes and then shuts down and beeps
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Feb 17, 2016 | Landice L7 LTd Pro Sports Trainer...
My treadmill stops running after 3 minutes. It shuts down and I have to reset and start over again. After another 3 minutes, it shuts off again.
Sounds like a motor or electrical system cooling problem. Could be dirt or blocked motor. Try Computer air blast can and or a vacuum to clean out motor and electronics.
Mar 04, 2015 | Proform Crosswalk Advanced Cr 525i 525x...
My treadmill runs for 9 seconds and stops and shows E1
Might be the power supply. That's about all I can think of. It runs but gets hot very fast and shuts down
Nov 24, 2014 | Triumph Academy Sports 400T Treadmill
Treadmill not working and alarm sound when plug in
Does the display give you an error code. I'm having a similar issue but all LEDs on my display are lit with a constant beep and still have not gotten resolved. Have you tested the power source and fuse and the reset circuit breaker. I am waiting on a new reset circuit breaker part to come in and hopefully this fixes the issue. I will let you know.
your posting is a year old have you since got the treadmill fixed and what was it
Mar 29, 2014 | Bremshey RN7 Folding Treadmill
Repco rp300tm
1) reset the treadmil.2) adjust the speed sensor, see the diagram attached. 3) Run the software calibration for easy diagnostic and fix it. God bless you
    • 1
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button 31d332da-cd1c-4885-8ae4-393941ca1930.gif
Oct 18, 2013 | Proform Perspective Es Treadmill PFTL99806
Cybex 520t treadmill runs for about 2 minutes then says end and quits running?
Dear Sir:
The most likely cause of the problem is a worn treadmill belt and deck.
Most of the time its caused from NOT LUBRICANTING between the treadmill belt and deck.
This causes friction and the surfaces wear putting greater stress on the electronics. The treadmill is shutting down to protect the electronics.
Remember the treadmill is complex electronic system. sincerely.
God bless you.
ernesto cuadra
managua, nicaragua. c.a.
see the block diagram that I design for easy diagnose and troubleshooting.
Feb 15, 2012 | RTO Cybex 520T Remanufactured Treadmill
Smooth fitness treadmill beeps every two minutes
Walk on a treadmill to calculate distance.
Most electronic treadmills allow you to program for an alarm or beep when you've walked a certain distance.
Try to turn off reading your owner manual.
And check if there are some error code?.
If you do not have owner manual go to this web:
http://www.smoothfitness.com/support/product-manuals.htm
and download free.
sincerely.
Nov 22, 2011 | Exercise & Fitness
My Nordic Track T7si is stuck on one speed. None of the bottons work and the treadmill seems to be frozen in this position.
Check if some pre-settign isnt work there. To re-adjust device, check this procedure...
Remove the key from the console and UNPLUG THE POWER CORD. Next, carefully lower the Uprights (111, 112). Remove the two indicated #8 x 3/4" Screws (1). Note: A Phillips screwdriver with a shaft at least 8 in. (20 cm) long is needed.
Raise the Uprights (111, 112) to the vertical position.
Remove the three # 8 x 3/4" Screws (1) from the Motor Hood (63), and carefully pivot the Motor Hood off.
Locate the Reed Switch (65) and the Magnet (49) on the left side of the Pulley (51). Turn the Pulley until the Magnet is aligned with the Reed Switch. Make sure that the gap between the Magnet and the Reed Switch is about 1/8 in. (3 mm). If necessary, move the Reed Switch slightly using a slotted screwdriver.
Reattach the Motor Hood (not shown), making sure that the five #8 x 3/4" Screws (not shown) are inserted into the same holes from which they were removed.
Run the treadmill for a few minutes to check for a correct speed reading.
Jul 01, 2011 | Nordic Track NordicTrack T7 si Treadmill
I have a Smooth FItness 9.15 treadmill. The electronics control seem to quit working in the middle of a run-the treadmill was running, but was not responding to pressing the various keys. By pulling out...
Good Afternoon
For better assistance please feel free to contact one of our technical advisors as soon as possible regarding your question.. we are always happy to assist you! Also, a service representative can be reached via email @ service@smoothfitness.com or by calling 1-888-800-1167ext 2 Monday thru Thursday 9am -8pm EST and Fridays 9am-6pm EST. Thank you
Smooth Fitness Customer Support
780 5th Avenue, Suite 200
King of Prussia, PA 19406
1-888-800-1167 : www.smoothfitness.com
Dec 27, 2010 | Computers & Internet
Faulty Repco sports treadmill
Not really familar with this brand but if it has a safety key, check to make sure it properly inserted and making proper connection.
Jun 05, 2009 | Exercise & Fitness
Exercise & Fitness Logo
593 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
