Question about Nintendo DS Lite
The bottom screen appears to have a liquid inside of it , bubbles too - was it dropped in water or just dropped ?
  • 130 Answers
ITS BEEN MAGNETISED...TRY GETTIN 2 MAGNETS AND HOLD OVER SCREEN WHILE PUSHIN TOWARDS ONE ANOTHER TO DEMAGNETISE
Posted on Jul 15, 2009
Pilot light has a propane gas smell, but when i turn on the flame i dont smell it? What is causing this?
Put some washing up liquid in a bowl of water make some bubbles apply this to to bottom connection of the pilot line joint .it will bubble up if there is a leak .
Jan 12, 2017 | Heating & Cooling
Smeg DI 409CA Dishwasher - Doesn't wash properly, tablet doesn't desolve and cycle lasted all night
The first thing is have a look at the instruction manual from HERE
If the dishwasher is not washing properly then please follow these steps:
  1. Check the water temperature. Should be 125 to 140 F.
  2. Check pump re-circulation., Listen, see if it sounds like it is spraying the water around with enough pressure.
  3. Check water level when the fill cycle has completed. Should be just under the heating element. If not, possibly need to replace the water inlet valve.
  4. Check the spray arm and pump cover for splits or leaks.
  5. Check to make sure dishwasher is draining after each cycle. There should only be a little water in the bottom of the tub.
  6. Make sure the dishes are loaded properly, or dishwasher is not overloaded.
  7. Possibly try a different detergent. Some liquid-gels will bubble and a pump cannot pump bubbles.
As you said that the water builds up at the bottom see If it comes out 'foamy' then liquid dish soap is getting introduced into the dishwasher. Liquid dish soap is different than automatic dishwasher detergent. liquid dish soap needs to be COMPLETELY rinsed from anything that has been pre-soaked prior to putting in the dishwasher. after a couple of regular cycles the foam will go away. Nowadays liquid dish soap is also 'concentrated' or 'ultra concentrated' which doesn't help.
If further this does not solve your problem the the only solution is to get it repaired.
Goodluck..
Feb 23, 2008 | Dishwashers
93 GMC Safari overheating. This happened spontaneously. Runs hot very quickly when I drive it. There is antifreeze in both radiator and overflow res, overflow res fills up more after driving a bit. ...
It would appear your thermostat is stuck in the closed position , find where it is on your engine, drain coolant and remove thermostat housing and stat, replace housing(liquid gasket OK) and coolant. now run engine, turn heater controls to hot leaving filler cap off, top up any water to max and replace cap now warm up to temp until fan comes on. if all ok replace thermostat with a new one and new gasket, you could also flush the sytem out at the same time with a hose pipe by loosening one of coolent pipes and flush radiator.
Nov 04, 2013 | 1993 GMC Safari
Screen leaking sticky liquid
Yes...the liquid is toxic. LCD solution can be highly toxic and ought not be touched. I would definitely put it somewhere where your cats can't get close to it, and bring it to a repair shop.
Jun 04, 2012 | Dell Latitude D630 Laptop Computer PC...
My inspiron mini 1018 notebook's keyboard is not working properly. The left shift key appears to be stuck and I really having a hard time using the whole keyboard. I remember having spilled a few drops...
When water spills into a notebook, you should fully disassemble the notebook & thoroughly inspect its inside. Look for any traces of liquid on the circuit boards & on other components. On circuit boards, liquid damage appears in the form of whitish traces. These needs to be wiped off. This can be done using a tooth brush moistened with few drops of hand sanitizer liquid.
Check all internal connectors & make sure that no liquid seeped into them. Dry them if needed.
When you are done, re-assemble back the notebook.
If the liquid fell on the keyboard & you found out that the keyboard is no longer working, then you might have to replace the keyboard.
May 23, 2011 | Dell Inspiron Mini 1012 Netbook...
How To Fix A Laptop Sony Vaio With Water Damage & not turn up
When this happens, you should fully disassemble the laptop & thoroughly inspect its inside. Look for any traces of liquid on the circuit boards & on other components. On circuit boards, liquid damage appears in the form of whitish traces. These needs to be wiped off. This can be done using a tooth brush moistened with few drops of hand sanitizer liquid.
When you are done, re-assemble back the laptop.
If the liquid fell on the keyboard & you found out that the keyboard is no longer working, then you will have to replace the keyboard.
Jan 02, 2011 | Computers & Internet
Cleaner is floating on top of pool
First, remove all of the air from the cleaner head and stop all air from entering the pool2_bing.gif through the return lines. Also, if the head and hose are covered with bubbles, give the hose a good tug. This will release the air bubbles and allow the pool cleaner to settle son the bottom of the pool. Also, the cleaner head may actually be being lifted off the bottom of the pool by the hose or the pressure in the return lines. Make sure that the hose stays untangled and the pressure from the return lines is not too low (not enought pressure to power) or too high (too much pressure that cause the unit to lift off the floor).
Apr 20, 2010 | Hayward Navigator Pool Cleaner
02 grand prix temp rises over 210 then drops back down. heater
dear friend-there is a couple of things you can do to find the problem,when the engine is cold remove the radiator cap start the engine then look inside to see if the water is circulating,all so look for bubbles in the water,if there is bubbles,you might have a blown head gasket,if there is circulation the water pump is ok,then get the engine up to working temp,then feel both the top and bottom radiator they should be the same temp,if not then the termostat is at fault
Nov 04, 2009 | 2002 Pontiac Grand Prix
WHERE TO GET A RELPACEMENT SCREEN
Why not remove the screen assy and see if you can clean it?
Remove the speaker grill assy and remove the screws along the bottom edge of the screen assy. Pull the screen assy up and off and lay it on a clean sheet with the outside of the screen assy face down. Remove the screws that fasten the screen bracket assys in place and remove the screen brackets.
Your TV actually has either 2 or 3 screens. You can carefully lift them off the screen frame. Separate them and clean them using a solution of luke warm water and a few drops of dish washing liquid on a soft cloth towel. Wipe immediately with a dry towel. ( be sure to note the order the screens are in and keep the smae side of each screen as it was originally. By the way, replacing the screens is expensive. The 2 that do the work, the lenticular screen and the fresnel lens can cost up to $300 a piece, the third, a clear, protective screen can cost $100-150.
michtech
Feb 18, 2009 | RCA P52926 52" Rear Projection Television
Continuous rinsing
Put 2 tablespoons of oil into the water at the bottom of the dishwasher it will help break up the suds. Sprinkle as well ordinary table salt liberally across the suds to disperse them. Try to drain the unit as much as possible, soaking up any residual water or suds with a dry towel. Let the machine fill again, and repeat the process if necessary. Good luck !
May 25, 2006 | Hotpoint 23 in. BF41 Built-in Dishwasher
Nintendo DS Lite Logo
96 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
