Question about Mitsubishi WD-52525 52" Rear Projection HDTV
GREEN BLINKING TIMMER LIGHT WILL NOT GO OIUT ON A 52525
  • Mitsubishi Master
  • 8,617 Answers
Thats caused by the capacitors on the DM pwb. You can get the V26 Chassis DLP DM repair kit at the following link which contains the replacement capacitors and the Instructions on CD.
http://www.tvrepairworld.com/
Posted on Jul 15, 2009
Blinking green light
If you own the model WD-52525 it and the sets made around the same time are all junk----falling apart as we speak and nothing seems to help make a good repair on them.
Blinking green light is called "blinking light of death" and I did not coin that phrase but it is accurate. The green light up front that blinks is the Digital unit in the set trying to boot up----one of the many nasty problems this set can have.
Not fixable in the home and in my view not economical to repair for any reason---if you want to see some of the other issues this set has Google the model number with "problems" and be prepared to read for a while.
May 01, 2012 | Mitsubishi WD-52525 52" Rear Projection...
Blinking Green Light on Mitsubishi DLP 52525
the circut that detects the bulb has been also failing in these sets
and the conversion chip that controls the picture , and the transformers are not putting out the full power they are supposed to.
this set will need to be tested to determine the exact cause or causes
Oct 18, 2008 | Mitsubishi WD-52525 52" Rear Projection...
My mitsubishi tv wont come on and green timmer light blinks fast
Try the blinking light repair kit from http://www.tvrepairkits.com/xcart/home.php?cat=2658 . This kit has fuses and capacitors that are designed for your TV.
I hope this helps.
Apr 24, 2010 | Televison & Video
Blinking timmer light mitsubishi 1080
Video instructions for repairing Mitsubishi WS-55859 HDTV:
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
You can find the parts (capacators) at Radio Shack for appx. $2/each.
Jan 18, 2009 | Mitsubishi WS-55859 55" Rear Projection...
Green status light keeps blinking after lamp replacement
continuous blinking green light indicates that the capacitors have failed on the DM pwb. You need the V26 DLP DM repair kit which is available at the following link under their repair category.
http://servicemanuals.vstore.ca/
Sep 07, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Replace the 1000uf capacitors on the DM board. thats whats causiong the problem. If you need further help go to this link they have your service manual available for emailing after purchase and that will entitle you for free tech support and one of their techs can fix those sets in his sleep he will walk you through the repair which parts are only about 20 dollars to fix the problem.
May 07, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mit 52525 from blinking green light to still green light.
bad capacitors 1000uf on the PWB, FMT and DM boards will cause those symptoms. All capacitors 9 in all need to be replaced
May 06, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Constant green blinking timer light
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
http://hdtvoice.com/voice/showthread.php?t=32186
Suspect the DM PCB part # 934C116002
Jan 07, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 Status Light --- blinking red constantly.
possible that over night your set took a power surge ,possible power supply fault.
Sep 12, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
205 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
