Question about Radio Communications
My palomar 150's relay will key as soon as you turn on the power. Plus, it has 6lq6 tubes in the final?? Aren't they supposed to be 8950's?
  • Richard McDonnell Aug 18, 2013
    I just restored one that came with 6LQ6 tubes. This Amp is kind of tricky to operate. Place the "Operate/STBY/Receive amp off' switch" in the STBY position. Nothing should happen until the On - Off switch is turned on. If you are using it as a base amp or mobile make sure the green wire is not grounded. I hope this helps. You can contact me at docdenny@cox.net
    Problem Solver:
  • 14 Answers
Nope, 6LQ6's are the tube used in most all Palomar CB linears. Most tube type linears of that class have one 6LQ6 driving two or three 6LQ6's. As far as the T/R relay keying as power is supplied, you have an electrolytic capacitor shorted in the Carrier Operated Relay. My advice: get a pro to fix it, as there is 800 to 900 volts DC at a quarter of an amp on the B+ circuit, which is more than enough to kill you if you make a mistake. Too many Hams and CBer's have died that way, I do not want you to have the same accident. Find a reputable repair guy, then pay the price. It's safer that way. Good Luck,
Longshorts.
Posted on Jul 24, 2009
1991 f 150 no crank has new starter and relay
make sure the wires on the starter are clean and are on there tigh so you are getting a good connection
Jul 19, 2013 | 1997 Toyota Tacoma
No power to my fuel pump 1989 ford f 150 dual tank
Your reset switch may have tripped,My 1985 f-150 is located where the passengers left foot would be but up under the dash slightly where the floor heat tubes are.mine has a white button on it.this happened to me and i reset it and it has not happened again.
Feb 11, 2013 | 1989 Ford F 150
Need to know how to hook a palomar 450 HD to a connex 3300hp
If its in a car or truck use heavy gauge wire to power it. I use a 3ft jumper between the radio and amp. Should use a grounded antenna system. Not a "MAG MOUNT" type. Those can "feed back" rf to your radio and cause problems. If using in the house, a large power supply will be needed.I own a palomar elite 400 hd.It uses every bit of my 30amp power supply. Your hd amp should like the hp radio.
Dec 04, 2012 | Palomar Redman Cb Stop Hd 450-fet Hd 10...
Hi, I have a 96 dodge neon. Im going to start from the very beginning. For about a week my car was having a hard time getting acceleration, then it slowly started to "putter" and shut off, only...
Hi, your symptoms indicate a bad auto shutdown relay or a bad ground to the relay coil. A way to test my theory is to run a jumper wire from the battery positive terminal to the dark green wire with an orange stripe on the positive coil terminal. If this allows the car to run normally, try swapping the relay and removing the jumper. If that doesn't work, I would check to see if there is a ground signal at the computer, pin 67. This is the pin that is supposed to turn the relay on by sending ground to the relay coil. Do not remove the connector to check for the ground signal--you have to probe the back of the connector at pin 67 with the key turned on--this is a dark blue wire with a yellow stripe. You will need an ohmmeter to check for ground by touching the other probe to chassis ground. The meter should read less than one ohm with the key on. Please let me know if you have questions, and thanks for using FixYa.
Jul 21, 2011 | 1996 Dodge Neon
D/A Raider Ham Tube Linear Amplifier, tube filaments overheat
This is not a transformer problem, it would blow fuses if transformer shorts out. It is hard to say, what could cause the problem without looking at the unit. But, you mentioned new power cord with grounding. That looks suspicious to me. Tyr to diconect grouding wire, and see if that helps.
Dec 05, 2009 | Televison & Video
Tunring up a cobra 150 gtl/dx
Um... What?? This is hooked to a switch? CB radio by FCC regulations is only supposed to have a max of 4 watts total output. If you can flip it to 7 watts dead key, you are doing really good. It won't do much more then that. It sounds like its set up to run on a linear amplifier, which cannot have more then 3 watts dead key transmitting into it.
Dead key, and modulation are different. You may have a meter that only reads dead key, and won't see the modulation. This radio is probably swinging close to 15-20 watts. you need a meter that can read PEP, Peak envelope power. Cheap meters only read AVG, or average power, witch will only show your dead key.
7 watts dead key is really good for that radio.especially since stock only has 4 watts. you cannot get any higher then that without changing finals.
at 3 watt dead key, or 7 watt dead key, your modulation wattage is still swinging much higher.
Also, you will get more swing with a lower dead key any way, which is better if you want it to be loud.
Leave it alone. its probably set just right.
May 12, 2009 | Cobra 150 GTL DX Base CB Radio
Palomar 150watt bi-linear amplifier for c.b. radio-won't transmit
3W to 150? Now you got 1 W in and 1W out and a snapped resistor. I would look at the driver and or final, either something heated up bad and cooked the resistor or you might have a break in the pcb.
Good Luck, Tom
Jan 02, 2009 | Radio Communications
Radio Communications Logo
224 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
