Question about LG 42PB4D 42 in. Plasma HDTV
Digital tuner tv works fine in analog, but in digital it breaks up.
  • Fuzzwegians Apr 11, 2008
    Same problem here.
    I also have a digital set-top box, and if I connect the same antenna to this and run it via HDMI to the TV the picture is fine, so I suspect the problem lies with the digital tuner in the TV itself.
    TV ran fine for three months, and only now is acting up. Digital TV is unwatchable on the TV currently. Will be checking with the shop and post what I find out.
    Any help would be greatly appreciated!
  • 67 Answers
If the signal breaks up and the picture looks like small squares with audio coming in and out its 99% of the time signal / reception how old is your ariel it may not be suitable for digital.
Posted on Nov 20, 2007
2 Suggested Answers
  • 8457 Answers
SOURCE: analog to digital convertion
Yes,LCD tv have digital tuner inside.Just buy a digital antena.Plug it in the antena analog whole.Go to menu setup go down to ch.rescan should have all free air channels.
Posted on Jan 16, 2010
Please can anyone help i cant tune my tv it wont pick up any channels when i auto tune it it says weak or no signal but i plugged aerial and tuned another tv and its fine
Are you trying to get over the air channels? IF you are does your TV have the digital tuner on analog? TV went digital and if you have an analog tuner will need either e new TV or converter box.
Jul 01, 2015 | Samsung 65" F9000 Series 4K Ultra HD Smart...
No TV broadcast picture. Is this a tuner problem?
yes it does seem to be a tuner problem , I also wonder what happens when you use the auto channel finder and tuner usually found in the set up section of the menu ? As well as was your TV working before and receiving input via the antennae but has now stopped working in this regard ? I also noted that attaching an analog to digital converter box worked fine , so your TV is capable of receiving a signal via that method , dose the converter box use your antennae input jack or a video jack to send the converted signal into your TV ? if it is using your antennae jack then it may not be a tuner problem .
Jul 19, 2014 | Sony Grand Wega Kdf-50we655 50-inch Lcd...
How to switch from analog to digital
The LED LCD TV's came out in 2009. It already has a built in digital HD tuner.
Allen wants to know how to switch the TV between the built in analog tuner and built in digital tuner.
Switching between the two tuners is done by means of the "TV mode" switch on the remote control.
You will NOT be able to select analog channels if have NOT done analog tunning.
If you need to do a retuning then hit the "menu" button select "setup" then "plug and play" enter the default pin number 0000. When you are selecting the channel source to memorize make sure you select "digital and analog". This will then cause the TV to tune and memorize both the analog and digital channels.
For details refer to page 8 of the user manual.
Feb 24, 2014 | Computers & Internet
TV tuner card will not display digital TV
And, unfortunately, it never will. TV tuners cards are almost exclusively an analog connection. You would need to convert the signal to analog using a secondary device, such as any of these:
It will work pretty easily...set your TV tuner card to the appropriate channel as detailed in the converter's manual and you should be fine.
You could also see if your cable provider's box has any analog outputs (yellow red white or screw-on coax).
Mar 08, 2011 | Gateway GM5442 PC Desktop
Trying to set up Digital Labs 19''LCD TV/DVD combo and only gets limited cable channels (old tv on same cable gets lot more). Have completed auto scan and pick cable as reciever however only gets limited...
The remote control that came with my Digital Labs tv/dvd combo worked for about 2 seconds and never really worked correctly. Now, I'm trying to find a universal remote that will be compatible. Please help.
Dec 26, 2009 | Televison & Video
Digital or analog tuner
Your set has a NTSC tuner for the over air broadcasts. You will need a converter box if you wish to use an antenna. If you have cable or satellite, you are fine.
Sep 01, 2009 | RCA F19420 19" TV
Cannot get tuner to work - dvd works fine
Analog TV broadcasting is done now. Unless your TV has a digital tuner already built in, you'll need a converter box to get any channels now. The DVD player part will still work, as you've already discovered. If your TV does have a digital tuner, try going through the setup and scan for channels.
Jun 16, 2009 | Televison & Video
HP pc with built-in tv tuner
Have 9, 5 and 13 turned entirely digital as yet, so as to leave you without their signal?
From what you say, the tv tuner in your HP receives analog signals better than or instead of digital signals the stations you can receive may be analog while 9, 5, and 13 may have dispensed with their analog transmitters.
They don't have to until June, since the changeover was delayed from the original February cutoff date by Act of Congress. It is actually easier to receive a digital signal than an equally powered analog equivalent so the fact that your system worked so well with analog signals bodes well for the efficiency of your indoor antenna arrangement, though you may have to replace the possibly analog receiver in your pc with a usb digital thumbdrive like model to continue after the changeover is final.
Here's a tip...if the receiver in your pc resembles a square aluminum tin can, mounted on a PCI card in one of your slots, it is very likely analog and not digital.
Usually these receivers (or actually TUNERS) are heavily sheilded while digital receivers do not require the same amount of sheilding to avoid interference with other components, which is the concept of the big square tin can, that a digital tuner does not require.
Mar 27, 2009 | Computers & Internet
Vizio P50HDTV10A 50 in. HDTV Plasma HDTV Tuner out
The HDTV tuner is out. Analog tuner, and video inputs work fine.
TV Model P50HDTV10A
Screen Size 50 in.
TV Manufactured Date Jan 1, 2007
Alternate Part Type SIGNAL BOARD
Part Number 3850-0042-0150(3A)
Alternate Part Number 0171-2272-2163
Jan 08, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
LG 42PB4D 42 in. Plasma HDTV Logo
240 people viewed this question
Computer Repairing
Computer Repairing
