Question about Hoover SteamVac F6019-900 SpinScrub Wet/Dry Vacuum
The rollers don't spin at all. Any ideas?
The rollers don't spin at all. Any ideas? Can I repair this myself?
    New Friend:
    Problem Solver:
  • 12 Answers
Easy fix just replace the belt and the brushroll.
Posted on Dec 02, 2012
    Problem Solver:
  • 19 Answers
Sounds like u need to put on a new belt owners manual sould show u how its a easy fix
Posted on Jul 15, 2009
My dyson dc25 brush bar will spin for a few seconds and then stops. What can I do to repair myself? The brush bar is not jammed, it spins freely by hand.
if it spins freely no resistance you probably need a belt..
http://www.vacuum-direct.com/dyson-dc25-drive-belt.aspx
if the belt is ok then the gears may have striped ck amazon for a head assembly complete.
Jan 28, 2018 | Dyson Vacuums
Why does the beater brush belt keep breaking?
The belt on this model series will break if the roller stops spinning or spins with high amount of resistance. Remove the brush roller and check that it will spin freely, if it does not it would need repair or replacement.
Jan 21, 2014 | Tornado CK 14/1 QD Vacuum
Bissell Proheat brushes don't turn. Belts fine.
Make sure the brushes are not seized or restricted
Aug 27, 2017 | Bissell 8920 ProHeat 2XTM Upright Vacuum
Bottom wheel won't turn and belt is on
When a Dyson DC07 roller brush does not spin, it can only be caused by one of two problems.
The Dyson DC07 uprights use a clutch mechanism to control the brush spinning when you change the floor / carpet switch. When the brush doesn't spin, it's caused either by the clutch or roller brush gone bad. Most other uprights use a belt to spin the roller brush, and if something is stuck in the roller brush it will cause the belt to break. Dyson vacuums however will make that awful grinding noise rather then breaking the belt.
I'll be happy to walk you through step by step on how to diagnosis this problem and find out which one of these two parts is bad on your vacuum.
Step 1. Make sure the vacuum is unplugged. Then turn the vacuum upside down so that the brushes are facing up. It's easiest if you put the head of the vacuum on top of a bench, or counter top. This is how the vacuum should look:
Step 2. You see on the bottom of the vacuum 3 plastic screws that are usually the same color as the vacuum cleaner. If you're vacuum is purple, the screws will also be purple. Use a flat head screwdriver, and turn each of the 3 screws a half of a turn, counter clockwise to loosen then. After each screw has been turned (you don't need to remove the completely, just a half of a turn is all), simply pull upwards on the bottom plate to remove it.
Step 3. You should now be able to see the roller brush exposed. You'll now need to remove the roller brush. This will take some patience, and some work in order to get this brush out of the vacuum. There is a special tool that has been designed to help you get the brush out easier. I would try getting the brush out first before buying this special tool. The easiest way is to use a flat head screw driver and pry the belt up while pulling up and out on the brush. With some patience and some maneuvering, you'll be able to get the brush out of the vacuum. Here's where you should put the flat head screw driver on the brush:
Step 4. Once you get the brush out of the vacuum cleaner, it's time to test it. Use your finger tips to hold just the end caps on the very end of the roller brush. While holding just the end caps, use your thumbs to try and spin the roller brush. Does the brush spin freely? It should rotate completely several times on each spin. If the brush doesn't spin, or you feel some kind of resistance to the brush spinning, then this indicates that your roller brush has gone bad. Here's a picture of how to test the brush:
If the roller brush went bad, then you'll need to purchase a new one. Here's a direct link to the roller brush your machine uses on our website GoVacuum.com:
http://www.govacuum.com/dysondc07.html
If the brush however was able to spin freely, and it spun multiple times on each spin, this indicates a little more serious problem of the clutch itself has gone bad. The clutch replacement repair is a much longer, more challenging repair to do. There is a very helpful video on how to replace the clutch below so that you may follow step by step instructions on how to change it. It was really helpful for me the first time I did this repair.
If you need to replace the clutch, here's a direct link to the clutch your Dyson DC07 uses on our website:
http://www.govacuum.com/dydcclasfore.html
Here's the video on how to replace the clutch:
When the brush stops spinning it can only be one of these two problems. This clutch mechanism was so problematic that Dyson removed it on the second series of the DC07 models. I hope that this repair was helpful in diagnosing your problem. If you have any questions about the diagnosing, or the clutch change, please feel free to use the Clarification Request form here on the Fixya repair page. If this was helpful you, please be sure to rate my repair as helpful by clicking the thumbs up icons.
Thank you,
Chris J.
GoVacuum
Apr 04, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Change the belt
Hi There,
Here's how you can replace the belt on your Eureka SmartVac 4870. I have taken pictures of the repair to help you better with this.
Here's what you'll need in order to complete this repair:
- Eureka Style R Extended Life Replacement Belt, Part 61110
- Eureka SmartVac Model 4870 Roller Brush Assembly, Part 61520 (Only if the brush no longer spins, or the brushes are worn out)
- Phillips head screw driver
Step 1. Turn the vacuum upside down so that the brush roller is facing upwards. Unscrew the three screws that I've highlighted in red.
Step 2. Remove the bottom plate after unscrew the three red highlighted screws. Once you remove the bottom plate, you'll have full access to the roller brush and belt area. Remove the roller brush by pulling straight up on the roller brush itself. Discard old belt, and test roller brush to ensure that it spins freely by holding the very end of each side, also called the bearing caps with just your finger tips. Try spinning the brush with your thumbs. The brush should spin several times around with each spin. If you notice the brush doesn't spin at all, or if you feel some resistance when you spin the brush, this means that your bearings are either gone, or will be soon. It may be time to consider a new roller brush at this time.
Step 3. Remove the new Eureka Style R belt from the packaging, and wrap one end around the the metal pin, on the opposite side of the roller brush. This pin is actually the motor shaft that spins the belt, which spins the brush.
Step 4. Wrap the other end of the belt through the side of the roller brush that has the pulley, and use the roller brush to stretch the brush roll back into the agitator housing. Make sure the end caps fit in the housing correctly by making sure there are no gaps between the roller brush housing and the end caps of the roller brush.
Step 5. After reinstalling the roller brush back into the housing with the belt attached, pull the belt forwards towards the brush. The brush should spin when you do this. Make sure that the belt is not pinched underneath of the roller brush or this will cause the belt to break immediately when you turn the vacuum back on.
Step 6. Reinstall the bottom plate, making sure that the little notches on the front end of the bottom plate tucked underneath of the reverse notches on the bottom housing of the vacuum cleaner. Tighten all 3 screws back into the bottom plate. Make sure the vacuum is set to carpet mode, and turn the vacuum on.
If you have any questions about this repair, or if you notice that the roller brush stops when the brushes hit the carpeting, please just use the clarification request form here on the Fixya repair page. I will then be happy to walk you through a little more advanced repair of replacing the clutch in the Eureka SmartVac that controls the rug/floor switch. Most of the time though the belt will be all the vacuum needs.
I hope that this was helpful information to you. If this helped you, please be so kind and rate the repair as helpful by clicking on the thumbs up icons in the top corner of this repair.
Thank you very much,
Chris J.
GoVacuum
Apr 04, 2010 | Eureka Smartvac 4870 Bagged Upright Vacuum
My hoover has no suction at the nozzle, though it has strong suction at the hose. This problem started after I replaced the vacuum bag for the first time.
there is a blockage behind the roller brush remove the roller plate and the roller and check the inlet hose for a blockage also remove the bag and chek the inlet to the bag for some type of obstruction. Don the Vacuum Doctor Alb, N.M.
Nov 01, 2009 | Hoover Tempo Widepath Upright Vacuum -...
Brush roller on windtunnel won't spin
It sounds like you need to replace the actuator arm or the cable to it. Look for Hoover part 43143046 for a start. I've got a similar problem.
Mar 21, 2009 | Vacuums
In Carpet setting, the vacuum brush does not spin
I put 3 turns of electrical tape around the area of the beater bar that meets the vacuum belt. This solved the problem short of replacing the beater bar.
Jan 18, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
Roller bar does not spin
It has a restart button that fixed the problem - I took it to a repair shop and they solved it.
Apr 18, 2008 | Kenmore 23612 Progressive PowerMate Bagged...
Hoover SteamVac F6019-900 SpinScrub Wet/Dry Vacuum Logo
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
