Question about NetGear DG834G Router
Netgear vpn824 v2 won't reset; wired works; wireless not
We have a Netgear vpn824 v2 wireless router. We've tried resetting it several times, won't reset (pushed the button in the recessed hole, held it, etc.). The computer directly plugged into it works. Wireless connections do not. Any ideas or recommendations of things to try? Thank you.
  • midnightb440 Jul 15, 2009
    Thank you for this info - unfortunately it didn't help. We are unable to log in to it for some reason - using our setup user name and password, as well as the admin/password or admin/blank.
    I thought I did - where do I do this? I rated it as being accurate info - which I know it was - but that it was not helpful because of the situation - can't remember the words they use.
  • 13,433 Answers
you have already rated him don't worry about it.
So you have tried holding down the reset button for 30 seconds?
When you then look for wireless networks with a computer in your house, does the netgear come up? Are you able to connect to it? what happens? do you receive a error message?
Posted on Jul 15, 2009
    President:
  • 1,383 Answers
Accessm your router with following link
http://192.168.1.1 or
http://192.168.0.1
then enter user name as "admin" and password as blank or "password"
then go to wi fi security enabled wireless.
  • kishor
    kishor Jul 15, 2009
    sir please rate my solution as thanks for try becaue it is rghit technical info.
    Thanks
  • kishor
    kishor Jul 15, 2009
    sir you rate me as inapropiate not help ful .Can you please look into it i give you right technical solution .
Have to reset wireless access point several times a day
Make sure it's not getting too hot. That is usually the problem.
Mar 21, 2014 | NetGear R6300 WiFi Router
My Netgear WPN824 wireless router stopped working. With the exception of the internet LED (which doesn't come on at all), all of the lights are blue and doing sort of a slow, pulsating blink. No m
The RESET button is for resetting the wireless section of the router and does not effect the Internet connection.
It looks like the wireless access is faulty especially when you cannot reset and configure the wireless settings.
Try powering off the Netgear for 10 mins the connect the power again.
If you still cannot RESET the Netgear then it is faulty and you need a new wireless router.
Mar 07, 2013 | NetGear RangeMax WPN824 Wireless Router...
My Netgear Router keeps kicking all wireless devices off the network
Upgrade your firmware for router (apps).
I hope, it helps.
Feel free to get instant Netgear router help at http://www.vtechsquad.com/wireless-router-support/ to fix any issues with your Netgear or any other router.
Jan 22, 2013 | NetGear Computers & Internet
Could not make router to work, Netgear modem adding router.
i suppose you have to connect modem to router's "source" socket and modem to socket "in wall" then reset and reconfig router and you should be ok
Nov 10, 2009 | NetGear WGR614 Wireless Router
NO connection to internet
Power off your router wait a couple of minutes turn it back on and try again. If its been several years you might want to look in to buying a new router.
Mar 08, 2017 | NetGear DM602 ADSL-Modem
How to do a complete reset of netgear wpn824 v2 have pressed reset button and nothing have used holding reset button with unit on for 20 sec then off 20 sec then on again for 20 sec with out releasing...
Well it seems that you have uploaded the firmware on the router using wireless connection. The firmware on the router has corrupted and now does not seem to be recoverable.
Dude if it is under warranty then get it replaced. To log a complaint with NETGEAR go to this site:
http://my.netgear.com
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Jul 05, 2009 | NetGear DG834G Router
Can no longer pick up router signal
Does the wireless light still lit on the router? You can try changing the channel on the router (1 6 or 11) ans moving the antenna. If those things did not work upgrade the firmware of the router and reset to factory default. Do not forget to save the configuration file before you reset to factory default.
Jun 30, 2009 | NetGear WGR614 Wireless Router
Problem with wireless from Netgear wgt624 v2.
Do you have 2 router? a wireless one and one thats not?
If thats the case, try just plugging in the wireless. if your connection is automatic it will detect the connection and give you an internet connection
If its not you must configure the IP manually.
But you must only USE ONE ROUTER..
Mar 28, 2009 | NetGear WGT624 Wireless Router
Password
On most model Netgear wireless routers there is a reset button on the back of the router which reset the router back to the default factory settings. The location of this button is printed on the label.
Power off the router, press and hold the reset button (you need a sharp pen), power on the router, wait several seconds and release the reset button. You can now configure the wireless router again using the default admin login.
Jan 06, 2009 | NetGear WGR614 Wireless Router
NetGear Wireless Router not working
No need to worry about this issue,,,,
turn off ur router for 2 minutes..wait for 1 minute..turn on the router and wait for other 2 minutes..now it should work..
If still its not working means..there will be a reset button in the router..press the reset button and hold it for 60 secs..turn off ur router and turn it on..wait for 1 minute..
try to connect thru wireless..it will work
Jul 03, 2008 | NetGear WGR614 Wireless Router
NetGear DG834G Router Logo
720 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
