Question about 2wire Wireless-G 802.11g ADSL Gateway
I have 2WIRE wireless router i have 2 pc's Pentium 4 and 1 stays connected without problems but when i try to connect the other 1 both die on internet connection i'm using a 2WIRE wireless adapter for both computers
  • 358 Answers
Ensure that you are using a crossover cable to connect the two routers together, if thats not what you are presently using, then make sure that you are allocating different static I.P Addresses to both of them.
But if what you are saying is that you are trying to connect the separately, and not together to the network, and its not working like the first one, then I suggest that you return it to the point of purchase, if you still have the warranty card, before its too late.
Hope this helps.
Posted on Jul 15, 2009
I am connecting my new d-link 150 to my 2wire 169 modem. I have printed out the manual and am on p. 10 where the instructions to connect to another router are listed. Sadly, at this point there is no...
the output/ethernet cable from the 2wire comnnects to the WAN port of the router...you should have 4 ports together and one alone...that is the wan port...your computer(s) connect tom the ports numbered 1-4...
start with everything off...start the 2wire...wait 1-2 mins...then star tthe router...wait 1 min...then start the PC...
Feb 14, 2011 | D-Link Wireless N 150 Home Router 4Port...
While changing the name,its not in wireless router.
!.switch off the wireless router.
2.first change the name of the PC.(don't connect to wireless)its normal name changing.
3.Restart the PC.
4.Now enable the DHCP on bothside.
Dec 22, 2009 | 2wire 1000hg DSL Modem & 802.11g Wireless...
How to connect to XboxLive via 1800HG 2WIRE+Linksys adaptor?
The easiest way to connect to Xbox Live without using your pc is to buy a
wireless network adapter for your Xbox.
You would then go into the system settings on the Xbox and configure the settings for your wireless network.
http://www.xbox.com/en-US/hardware/x/xbox360wirelessnetadapter/
Xbox 360 - direct to internet - No PC.
Jul 31, 2009 | 2wire 1800HG Router (RG1800HG00)
2wire 3800HGB-B interference
I would increase the wireless power inside the modem. This will boost the signal allowing it to stay connected more often.
- open IE
- browse to gateway.2wire.net
- homenetwork icon
- wireless settings
- enter your system password
- If your on channel 1 or 11 the power will only be able to go to 4.
- Change to a wireless channel between 2 and 10
- Increase the power to 10
- Save
Mar 24, 2009 | 2wire HomePortal 100W (1000-400026-000)...
Can't access 2wire network using netgear adapter
I was also having trouble with my Netgear wireless n USB adapter connecting to my new at@t 2WIRE gateway. The problem was that the netgear software wouldn't allow my computer to stay connected to my 2WIRE gateway and the software wouldn't allow Windows when restarting my computer. I have Windows XP and after hours with at@t support there was no resolution and they gave me Netgear's suport number to call 1-888-638-4327. After 10 min. the problem was fixed. They had me click start icon at bottom left corner then all programs, then highlight "start up" and if you see anything like netgear adapter or netgear start up wizard right click on it and click delete. That was it! rebooted my computer and it connected automatically!!! I'm not very computer knowledgable but I hope this helped
Feb 02, 2009 | 2wire (1000-100016-002) Wireless Adapter
Just bought a 2Wire Gateway, router/modem.
Try contacting your internet provider for set up instructions.its probably a configuration problem.RICHARDM69
Dec 01, 2008 | 2wire (1000-400108-001) Router
2wire router
Turn everything off. Router, PC etc. all OFF. Then start the PC, wait 2 mins. Then plug in the power to the router. Then the cable into the PC. Then check fireware [Zone Alarm etc] to see if it is recognised as receiving data. Click on IE or Firefox.
If this fails, do it again Have a coffee break. Remember the cable connects to the broadband and it flows in and out without the dreadful instruction CDs given you.
Jul 08, 2008 | 2wire (1000-400108-001) Router
2wire dropping xp pc
hello!
you may try this and see if this help solve your problem
Step 1try to connect your computer directly to the modem and check if you will also experience problem
Step 2: Shutdown the computer.
Step 3: reset the router while power on then Unplug the router’s power cable.
Step 4: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 5: Plug in the Broadband modem’s power cable and wait for its lights to appear
stable.
Step 6: Plug in the router's power cable once the modem’s lights appear stable.
Step 7: Power on the computer on and configure router settings if neede
Step 8:test the Internet connection.
if this still didnot work, maybe you need to upgrade the firmware of your router
May 01, 2008 | 2wire (1000-100052-000) 802.11g/b Wireless...
2wire 2700 HG - Many problems and can't reset it!
you need to set up the 2 wire using an RJ45 ethernet cable and not wirelessly initially, and you need to set your ethernet lan adapter to obtain an ip address automatically and then type the default 192.168.1.254 in your browser to get in the settings and then set or enable dhcp, and also enable wireless as by default it is dissabled and check the the adsl light is lit
Some 2wire routers normally come with WPA-PSK security already set up with the passkey on a sticker on the side of the router, so that may be why it stays set when you reset it.
Check that your wireles adapter is using the same type of security when you enter the passkey when wirelessly connecting.
Nov 21, 2007 | 2wire 2700HG-B Router (2700HGB)
2Wire router
if your wireless connection is not working even if the wireless light is lit up on ur 2wire modem/router....try to delete the 2wire network from the prefered list...go to network connection, right click on wireless netwrok connection, go to properties and click on wireless network..select the 2wire netwrok on the prefered list and remove..reconnect to the network by clicking on view available wireless netwrok and select the 2wire network again...if its asking for a WEP key or password take a look at the bottom on the modem a 10 digits number enclosed in brachets..thats the network or wep key. access 192.168.1.254 and click on home network, got to wireless settings---edit settings...change ur wireless channel to 10 adn power settings to 10, save ur changes=)...ohh and by the way make sure that the wifi switch of ur laptop is turned on=)
Jun 01, 2007 | 2wire 2700HG-B Router (2700HGB)
Open Questions:
See all 2wire Wireless-G 802.11g ADSL Gateway Questions
2wire Wireless-G 802.11g ADSL Gateway Logo
276 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
