Question about Canon imageRUNNER C3200 Copier
Color copying gray turns out magenta. this happens when copying from glass only , printing from workstation it's ok..
  • george saucedo
    george saucedo Jul 16, 2009
    this was done...its still doing it...I was told this is natural when copying from a process gray...???
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 118 Answers
Try to run auto gradation adjust press * with head then go to adjustment/cleaning and follow the instruction or check the optical mirrors for dust contamination if is dirty you can remove 2 screws and remove the glass then wipe all the mirror with lint free paper or cloth( do this first before running the gradation adjustments)
Posted on Jul 15, 2009
  • Ronnie Gregorio Jul 16, 2009
    hi joss,
    before making copy try to adjust color balance manually by going to control panel special features.you can adjust the 4 colors individually from light to dark and vv
Bizhub C654e Color Copy Only show Cyan or Magenta Lines
So you have tried all the calibration tests? It sounds as if the alignment is off. If that isn't the case, you can try setting the copier back to default settings. I think in this make the reset button will be a tiny indented hole on the back.
Elisa Jed ' http://stores.abmcopier.com/canon-color-pre-owned/
Apr 13, 2014 | Office Equipment & Supplies
I have a new bizhub C224 when I print color is OK but when I copy color there is magenta lines or cyan lines and only in copy and the demo page is ok too
Problem with the scanner (Thing that move as it scans has the bright light and mirrors on it. Or the CCD that is the black device under the big glass on the right, get a tech out to clean and or replace
Dec 26, 2013 | Konica Minolta Bizhub C224 Color Copier...
Making Only megenta color copies no other color
When the blue color ink is finished it may print magenta instead of blue. And it is clear that black,yellow,red colors are there.
Jun 18, 2010 | Ricoh Aficio CL3500N Laser Printer
Dull colors on 8550 phaser printer
Looks like you don't use the Magenta ink that much, on this machine because it is so hot all the time after a while the magenta can get a strange brown colour and the cyan can get like a aqua marine colour. All you can do is purge the magenta by printing magenta sample pages or just wait until it goes away.
Also you could try the following Tek Colour correction (but It probably won't work). See below
TekColor
Description
Automatic Applies the best color correction to each graphic element: text, artwork, and photographs Office Color sRGB Display: Approximates the colors on a computer display.
sRGB Vivid: Produces brighter, more saturated colors than sRGB Display. Press Match SWOP Press: Matches specifications for Web Offset Publications.
Euroscale: Matches Fogra glossy paper specification.
Commercial: Approximates U.S. commercial press target.
SNAP Press: Matches specifications for Newsprint Advertising Production. None Applies no color correction. Use with other color management tools, such as International Color Consortium (ICC) profiles, ColorSync, or the PANTONE Color Chart for the printer. Black & White Converts all colors to shades of gray
From the workstation, select the color correction in a supported driver.
Microsoft Windows 98 SE / ME / 2000 / XP/ Server 2003 / NT 4.x Operating Systems (OS):
NOTE: Some of the color corrections are grouped under Office Color or Press Match.
  1. Within an application, click [File] from the toolbar, and then select [Print] from the menu. The Print window will be displayed.
  2. Click on the [Properties] button located on the top, right of the window. The Properties window will be displayed.
  3. Click on the [TekColor] tab.
  4. Select the required color correction.
Feb 20, 2009 | Xerox Phaser 8550DP Printer
Printing color copies
check to see which cartridge you put in, photo magenta cartridges DO NOT work in the MP830. sounds silly but we see it all the time.
check to see if the short vertical black bar next to the magenta pattern looks ok, not brown or gray or streaky. if it is you may need a professional head flush, take the whole printer in for service.
Jun 01, 2008 | Canon PIXMA MP830 All-In-One InkJet...
THE MAGENTA COLOR PRINT CLOUDY
My first suggestion would be to change the copy/[rint cartridge.
After that, I would suspect the magenta developer housing is a problem.
That would require a service call to resolve.
Jan 08, 2008 | Xerox DocuColor 12 Printer
MFC-9840 prints vertical stripe ~2" from right edge on all color printouts
The first thing i would try to do is clean the corona wire on the drum unit. It might also be a faulty magenta cartridge.
Dec 07, 2007 | Brother MFC-9420CN All-In-One Laser...
No Magenta Color Printing, Xerox Docucolor 1632
Are the properties set correctly in the print driver.
You can turn certain colors up or down.
Does is copy magenta?
If so I would suspect the driver or the settings within the driver.
If it does not copy magenta, then I suspect a developer housing issue.
Printing only then suspect a driver issue.
Oct 22, 2007 | Xerox DocuColor 1632 Laser Printer
Canon imageRUNNER C3200 Copier Logo
85 people viewed this question
old marine
old marine
