Question about Nokia N95 Cellular Phone
Installations i have installed many games and themes now i want to delete them. so i went to installion folder and deleted them. but in MENU>INSTALLATIONS>APP MANAGER> option>vew log in veiw log every thing is shown can any1 tell me how to delete this view log
Help with deleting games
click on them one at a time and uninstall
Dec 17, 2014 | Sony Ericsson K810i Blue Smartphone
I installed a theme and then the phone just froze, tried restarting but the screen just went white
hi, the reason is that the theme you have installed is not compactable with the phone and equally it is possible that the phone memory is full.
solutions:
1. delete some things from your phone so as to make space for the new theme you just downloaded.
2. this i think is the best option for you, try switch off your phone and re-start it...then delete that theme from your phone.
cheers
Mar 04, 2011 | Nokia E50
How to uninstall themes nokia x6 16gb
Hi there,Well you need to figure out where u installed them from(which folder),usually the ''recieved files'' folder,and delete them from there..the theme of the phone will automatically reset after this..
Please Rate me full :)
Feb 01, 2011 | Nokia X6 16GB Cell Phone
Setup cannot find Enterprise.WW\EnterWW.cab. Browse to a valid installation source and then click OK. I am installing MS Office 07 and midway through the install this is coming up. Any answers to this...
Hi There,
When it asks for the "valid installation source", direct it to the installation CD drive where the MS Cd is. There's a good chance it will heal itself that way and move right on ahead.
Regards,
Marcus
Sep 24, 2010 | Microsoft Office Professional 2007 Full...
How do I remove or delete built in themes in my Nokia 6300? I'm not a fan of themes, so I'd like to remove them to make room for images and or other files. Thanks in advance.
Its very simple to delete the themes there two ways you can delete the themes.First method is straight forward its like you have uninstall the one which you don't want.
Method 1:
1)Go to menu
2)Then settings
3)Then data manager
4)then application manager.
Scroll down and choose the themes which you don't want and uninstall it.Please be sure in selecting the correct theme.because this a common area where all application you installed will be present.so choose the theme you want and uninstall it.If still the
theme is there reinstall the same theme and
uninstall it properly
2)Method 2:
Connect you mobile in data transfer mode with the computer with the help of USB,its same like PC-suite connection but you have to choose data transfer mode in the mobile.
Now go to My computer and you can see a extra drive in your computer that is your phone
Hard drive
Go the private folder and 10207114 folder and then fo to import folder. following location in that drive
In the import folder you can see all the themes installed.select it and delete the themes which you don't like to have...
Note 2:second method is used when the phone is unwilling to delete some themes when you try to delete using first method.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
thank you for using fixya have a nice day:-)
Aug 01, 2010 | Nokia 6300 Cellular Phone
The themes i install,arent there in the app manager,so cant b deleted,and keep dissapearing from the theme menu...solve this for now!
I don't know if you do already, but you should install the themes to the phone memory. They will then show up in the app manager where they can be removed.
If not, the solution below will solve your problem.
1. Connect your nokia to a computer via USB cable
2. Select 'Mass Storage' on phone
3. Browse to phone / memory card
4. Show hidden file and folders
5. Themes are installed in the 'Private' folder, here you can delete them manually.
Feb 07, 2010 | Nokia N81 Smartphone
Satellite A55-S106 screen went blank
try going in your bios durring a reboot by pressing F2 set to default and save and exit. what i would do being that you had a virus is save all my info, and do a new installion. freddiemccly@yahoo.com that should fix and re install whats been deleted, cause virus .
Jun 03, 2009 | Toshiba Satellite A55-S1063 Notebook
DElete Theme
Install same theme,Ur mobile Phone will be Asked to Replace Previous.Replaced Ur Previous.This Time That Theme will be Shown in Application Manager.Then Remove Ur Theme in Application Manager,then Delete that Theme From Ur Source File
May 04, 2009 | Nokia N85 Cellular Phone
R4 CARD FOR DS LITE
just delete games and reload those cards do that all the time, make sure you drag the games into the themes folder.open system folder you will find the themes /games folder in there.enjoy
Dec 30, 2008 | Nintendo DS Lite Console
I think my video card wont dump its cache
Have you tried un-installing and re-installing the game? EA has posted instructions for doing so on their support website. I've pasted the website link and instructions for doing so below. I've had to un-install and re-install at least six times myself, and have seen exactly the error that you have described occur twice. I hate this game for the crashes that occur regularly. My system plays Crysis fine, with no crashes, but crashes regularly from 2142. I wish that for once and for all EA would fix this game. It is the best battle simulation in the world, IMHO.
http://support.ea.com/cgi-bin/ea.cfg/php/enduser/std_alp.php?p_cv=2.719&p_pv=2.3040&p_prods=7%2C3040&p_cats=566%2C719&p_hidden_prods=&p_sid=CPOWU_Ti&p_lva=&p_li=&p_accessibility=0&p_redirect=&p_page=1&prod_lvl1=7&prod_lvl2=3040&prod_lvl3=0&cat_lvl1=566&cat_lvl2=719&p_search_text=&p_new_search=1
Answer Use the supplied Uninstall shortcut from the Start menu that came with Battlefield 2142 or use the Add or Remove Programs to remove the software. If you encounter difficulty in removing the game, carefully do so manually as follows:
To delete the configuration files and local copy of your account:
  1. Click the Start button on the Windows Taskbar.
  2. Select My Documents.
  3. Right-click the Battlefield 2142 folder and select Delete.
To delete the game files (in the default location):
  2. Select My Computer.
  3. Double-click the C:drive.
  4. Double-click the Program Files folder.
  5. Double-click the EA GAMES folder.
  6. Right-click the Battlefield 2142 folder and select Delete.
  7. Go to the following folder: C:\Program Files\InstallShield Installation Information (If you cannot find this folder you may have to go to Tools > Folder Settings and click the setting to SHOW hidden folders.)
  8. Right-click the folder named {ED50ECE9-EC54-4C05-B5ED-EE4741A9F2EC} and select Delete.
  9. Close all open windows.
  10. Right-click the Recycle Bin and select Empty Recycle Bin.
To edit the registry and remove Battlefield 2142:
  2. Select Run.
  3. Type regedit in the text field and click OK.
  4. Click File and select Export.
  5. Name the file Backup and make sure the Export Range is set to All.
  6. Click Save; you will now be returned to the Registry Editor window.
  7. Click the plus (+) sign next to HKEY_LOCAL_MACHINE.
  8. Click the plus (+) sign next to Software.
  9. Click the plus (+) sign next to EA GAMES.
  10. Right-click the Battlefield 2142 folder and select Delete.
  11. Back under Software, click the plus (+) sign next to Electronic Arts.
  12. Click the plus (+) sign next to EA GAMES.
  13. Right-click the Battlefield 2142 folder and select Delete.
  14. Just above EA GAMES, you will see a folder named EA CORE. Click the plus (+) sign next to EA CORE.
  15. Click the plus (+) sign next to INSTALLED GAMES.
  16. Click the plus (+) sign next to EA GAMES.
  17. Right-click and select Delete on any Battlefield 2142 folders.
  18. Click the plus (+) sign next to Microsoft.
  19. Click the plus (+) sign next to Windows.
  20. Click the plus (+) sign next to CurrentVersion.
  21. Click the plus (+) sign next to Uninstall.
  22. Right-click the key named {ED50ECE9-EC54-4C05-B5ED-EE4741A9F2EC} and select Delete.
  23. A Confirm Key Delete window will appear, choose Yes.
  24. Close the WindowsRegistry Editor.
Battlefield 2142 should now be completely removed from your system.
Dec 21, 2007 | ATI RADEON X1650 Xt, (256 MB) Graphic...
Nokia N95 Cellular Phone Logo
78 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
