Question about Pioneer GM-X962 Car Audio Amplifier
Electrical problem no rear lights or dasboard lights
I have a 92 Chevy Astro when I switch on the lights No lights in dash and rear light
    Scholar:
  • 198 Answers
Check out the electrical wiring once and the power connections.As your car is slightly old, the wires may have weared of....
Posted on Jan 06, 2008
Took out factory stereo in my 1994 chevy astro van ext now i don't have tail lights, dash lights or horn
you will have to look at an electrical diagram, but there is probably a jumper built into the stock radio that will have to be put back in.
Mar 23, 2014 | 1994 Chevrolet Astro
BATTERY, ABS, & BATTERY LIGHTS ON DASHBOARD WON'T GO OFF 2000 CHEVY ASTRO
Either the alternator is not charging(is the drive belt still on the pulleys?) or the ignition switch(electrical part) is bad.
Oct 02, 2013 | 2000 Chevrolet Astro
1995 chevy astro van dash lights and interior lights don't work. bulbs aren't blown I checked. I also checked fuses.
the CGR LTR/DM fuse powers the dome / instrument lights. did you check voltage going into and out of dimmer switch.
Sep 22, 2011 | Chevrolet Astro Cars & Trucks
I need a wireing diagram to see what color is what. i am hooking it up to a 92 s-10
the best way and easy way to do it is go to walmart and get a wiring harness that works wit 92 chevy. makes life simple and looks professional. cost about 8 bucks. but here is the wiring diagram
Constant 12V+ Orange Switched 12V+ Yellow Ground Black Illumination Gray Dimmer Brown Antenna Right Front Front Speakers 4" x 6" Dash Left Front (+) Tan Left Front (-) Gray Right Front (+) Light Green Right Front (-) Dark Green Rear Speakers 4" x 10" Rear Corners Left Rear (+) Brown Left Rear (-) Yellow Right Rear (+) Dark Blue Right Rear (-) Light Blue
Apr 06, 2011 | Panasonic CQ-C3100U CD Player
I need the wiring diagram for a 92 chevy astro van dealing with the charging system and the starter switchmy alternator works fine and the batteryis good and the starter switch is new and all the wires...
This is gonna sound stupid but when you turn the key to the on position engine not running does the battery light come on? If not check the bulb in the dash as it acts as a fuseable link in the system.
Feb 23, 2010 | 1992 Chevrolet Astro Extended
1994 chevy silverado tail lights and dash lights have gone out where is the fuse located? which fuse?
on a panel at the side of the dash or under the dash at the emergency brake. TAIL LIGHT OR REAR LIGHT FUSE
Dec 18, 2009 | 1994 Chevrolet Astro
Stereo wiring diagram for 1991 chevy camaro
1991-92 Chevrolet Camaro Stereo Wiring Constant 12V+ Orange Switched 12V+ Yellow Ground Black Illumination Gray Dimmer Brown Antenna Trigger Pink Antenna Right Front Front Speakers 4" x 6" Dash Left Front (+) Tan Left Front (-) Gray Right Front (+) Light Green Right Front (-) Dark Green Rear Speakers 6" x 9" Side Panels Left Rear (+) Brown Left Rear (-) Yellow Right Rear (+) Dark Blue Right Rear (-) Light Blue
hope this helps
Jul 04, 2009 | 1991 Chevrolet Camaro
No Brake Lights 1993 Chevy Astro Van
Check the ground wire & leads, if not try the multi-function switch in the column
May 29, 2009 | 1993 Chevrolet Astro
91-chevy astro van tail/running dash lights won't work,
wiggle the headlight swith a little. I have this problem with my chevy truck
Mar 23, 2009 | 1990 Chevrolet Astro Extended
Dashboard Lights
The fuse box is underneath the dash.
Check the red 10amp fuse marked 'LPS'.
To check it, pull it out with pliers or needlenose. Look at it. If the wire inside it looks burnt, it is. Replace it with a good one.
There is also a dimmer switch on the dash. Check to make sure it didn't get turned off.
Replace the hyperactive lighter. Some do that.
Hope this helps,
Mike
Jun 18, 2008 | 1993 Chevrolet Astro
Pioneer GM-X962 Car Audio Amplifier Logo
66 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
