Question about Rainbow 75th Anniversary Canister Vacuum
FQ95x...motor gets very hot very fast
I purchased a Filter Queen 95x as a used vacuum in June '09. The motor gets very hot and so does the cap on top -- to the point that I cannot touch the underside of the cap (where the scent pad is located)when I remove it. Also, when the cap is removed, the exhaust air is extremely hot (just like a hair dryer!) Is this normal? If not, any suggestions? I've heard & read good thinks about this make of vacuums -- did I buy a lemon? Thank you! S.
  • 58 Answers
These old style majestic always ran on the hot side but since its pushing 20 years old, you need to have it serviced my a filter queen service center. that will help with the heat problem and prolong the life of the machine.
Posted on Aug 14, 2009
    Scholar:
  • 70 Answers
It sounds like you have a blockage either in your hose or the carpet sweeper. Try dropping a coin through the hose. If it comes out then check the sweeper.
Posted on Jul 15, 2009
Will run for a few minutes, then red light comes on canister an unit shuts off.
That's the thermal cut off circuit. If the motor gets to hot it trips and shuts it off. When it cools down it will turn on again but it is generally an indicator of one of the following; the cone filter needs changed or the inner filter ring that sits above the motor inside the unit is shot. One is an easy change the other requires dis-assembly, better carried out by a vac tech if you aren't comfortable taking it apart. In the meantime remove the cap out of the top of the vacuum, that will let it exhaust heat better but I strongly recommend getting that filter ring changed.
Nov 27, 2015 | Filter Queen Majestic Canister Vacuum
My canister motor shuts off after a few minutes and a red light comes on
We were told we can add water to the canister instead of using a paper filter. Is there a manual that shows the operation of the Majestic Filter Queen 95x?
This is a DRY vacuum only. Do not put any type of water in your vacuum unless you are cleaning the dirt container only.
Adding water to this machine will cause it to **** the water straight up through the motor and well, water and electricity do not mix.
Nov 11, 2010 | Filter Queen Majestic Canister Vacuum
How do I change the power cord on my Filter Queen vacuum cleaner?
First, remove the top filter cap. quarter turn.
Remove the three screws from under said cap.
The rubber switch cover will come off of the on/off switch pedal there. pull off and set aside.
undo the two clamps and remove the motor (chrome) section from the base.
give the handle a tug and the chrome cap should now come off and allow you access to the wiring and motor/switch.
optional side note: at this point you may want to replace the sponge filter around the motor too.
Remove the cord from the unit and rewire to the same spots the old cord comes out of.
reverse the instructions to put the machine back together.
Nov 05, 2010 | Filter Queen Majestic Canister Vacuum
I just purchased a tune up kit for my filter queen, how do I replace the dome cap pad? I can see it but I dont know how to get to it.
I was trying to replace the silencer filter, we had to take the dome cap off and remove the screws by the sn plate then lift the top off. It looks like the motor has been replaced at some point (I purchased this one used) so the wires had wire nuts holding them together. We had to separate the wires for the light so we could remove the old filter and install the new one.
Feb 06, 2010 | Filter Queen Majestic Canister Vacuum
Motor Brush for older model Filter Queen
Is there a Johnstone Supply in your area? How about an ACE Hardware. A vacum repair place? Sewing machine repair place?
If you have the data, ACE or Johnstone should be able to help you. Don't discount other electrical supply places. You will not get help at a big box place.
When I Googled "Filter Queen parts", I found lots of places on the WWW. There must be something close to you.
Give it a try. Let me know if this works for you.
a
Sep 21, 2009 | Filter Queen Cheetah II Ash - MU305...
Our Filter Queen is now making a loud and strange sound along with smoke coming out of the top... smells like something is burning. Help?!
thats got a realy bad motor. I don't know if you can still get motors for the model in the pic if that is your moddel
Jun 10, 2009 | Filter Queen Cheetah II Ash - MU305...
Where can a person purchase parts to repair the hose of an filter queen majestic model 360.
If you live in Iowa call 888-637-4692 or 800-344-1840 for the the Service Center near you. or online at http://www.filterqueen.com/contact-filterqueen-locate-distributor.html
FQ Master
888-637-4692 in Iowa
Your Filter Queen Authorized Service Center
Mar 03, 2009 | Filter Queen Majestic Canister Vacuum
Filter queen 95X (1991) Motor is noisy but still work fine. Can there be a loose screw inside ? Can I open the motor and look inside ?
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=766802
Generic problem for all Vacuums
Posted by alexun on Jul 10, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The sounds coming from the motor sounds like it is the 2 sheet metal fans that do loosen up and start to make noise; and if you are handy and can do service work yourself you can replace the fans, but make sure you mark the wires when you remove the wire and the motor. If you have questions feel free to contact your local vacuum cleaner dealer in your area or cal the Filter Queen cust serv line listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Customer Service 1-800-344-1840
custserv@filterqueen.com
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 10, 2008 | Vacuums
Need manuel
I've found an online manual in pdf format
Oct 29, 2007 | Filter Queen Majestic Canister Vacuum
Rainbow 75th Anniversary Canister Vacuum Logo
157 people viewed this question
Top Rainbow Vacuums Experts
Jim Parker
Jim Parker
Chris Nomland
Chris Nomland
Are you a Rainbow Vacuum Expert? Answer questions, earn points and help others
