Ignition button won't click down
The ignite button (which needs to pressed down while holding down the 'low' gas button to ignite the heater) wont click down?
  • lisarayner Jul 16, 2009
    It's a Gascraft Heater: model GC921
  • Steve Smith
    Steve Smith May 11, 2010
    Hi, Can you tell me what appliance this is on? I think i can help you Thanks Steve :)
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 109 Answers
Had the same problem. The HSI relay (SIEMANS T7CS50-24) on the circuit board went bad on mine. That part is hard to find since it's so old so I just got a panel mount 24V relay and soldered the two control wires to the correct locations on the board and everything is peachy. Most people should probably just get a new circuit board though.
Posted on Oct 30, 2009
Pilot light wont light
Rita, Check the attached links,instruction and guides to trouble shoot pilot light, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Gas Heater Pilot Light Troubleshooting
What to Do if Gas Furnace Pilot Light Won Stay Lit DoItYourself com
Furnace Won Ignite Why and What to Do
Aug 03, 2016 | Heating & Cooling
Is there a trick to starting the Pyrox 400? Turned the fan on and press on low then repeatedly press the ignition pilot light, start to smell of gas after a minute. Won't start Help please
Is the ignition sparking? When you press and hold down the buttons, the ignition should be sparking at the centre electrode. At the same time when you hold the buttons down, the gas valve is manually held open to release the gas. The spark is then supposed to ignite the gas. Hold the knobs down for about 3 to 5 seconds after ignition and the gas valve will stay on. If it lights but the flame wont stay on, it could be anything from a partially blocked aeration port to a worn knob. When you push down on the knob, it is supposed to press down on an electromagnetic lock which keeps the gas valve open when the flame is burning. When the knob or shaft isn't pushing down enough, it doesn't keep the gas valve locked and the flame will go out as soon as you let the knob go.
Apr 19, 2015 | Heating & Cooling
Why wont my everdure gas heater stay alight
Some heaters have to be "warmed up" by holding the button down for approx. 30 seconds after it lights. These are ones with whats called a "thermocouple". The thermocouple has to remain a certain temp. or the unit will shut off. If the thermocouple goes bad, it can be replaced
Sep 05, 2014 | Heating & Cooling
My Bradford White Defender M-I-30T6FBN doesn't show igniter button on instructions
1) Copy following links to identify gas control valve and read ignition procedure, and access service manual for your product:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
2) Honeywell gas control used on recent Bradford White gas water heaters has red knob that rotates to pilot. Press and hold red knob. Then push red igniter button until status light changes.
Feb 11, 2013 | Bradford White Bradford MI30T6FBN-337 30...
We have aRinnai gas heater and its about 30yrs old ????? we rent. anyway the three buttons on top dont seem to work the first one to ignite wont stay down and the others wont work without this can u help
hold the first button down until pilot lights and thermocouple heats then release slowly if still does not work possible faulty thermocouple lead need gas fitter to replace
Jun 10, 2011 | Heating & Cooling
Have 2 heaters 1st heater will not light, has gas
sometimes you need to hold down the button for 5 to 10 seconds while the heater heats up,, as soon as it gets to temperature then it should stay on with no problem.
as far as the one that is not lighting -- all I can thing of is that the igniter is not close enough to the fuel exit area ( ? ),, with the power off - ( un-plugged ) look inside as you press the igniter and see if you can see the spark arch. -- also, if this is a new heater there is a chance that there might be something wrong with the regulator and it is either getting to much or not enough gas.
c...
Dec 31, 2010 | Scheu (85-FAC) Heater
We have a fairly new heater. went to turn on the pilot light and it won't ignite. what do you think is wrong? gas has been turned on before igniting
Sometimes it takes a few seconds for gas to reach the pilot. When you place the thermostat knob/gas control in the pilot position you must then depress it (push it down and hold it down). Wait a few seconds while holding it down, then press the ignitor button with your other hand while continuing to keep the thermostat knob depressed. You may have to hold the knob down and press the ignitor several times. You should see a spark at the pilot if the ignitor is working properly. Continue to hold the knob down for 30 seconds after the pilot lights, then release the knob, it will pop up & you can then rotate it to lo/med/hi and the heater will come on.,
Dec 02, 2010 | Procom (177653) Utility Heater
Wont light
Is there a spark? or do you need a long match? The button usually just opens the pilot so it can be lit. If its not electronic.
Jun 19, 2009 | Pilot Pen Pilot Ignition Gas Water Heater,...
Rinnai burner goes out when ignition button is released
The thermocouple [s] require replacement, or in my experience try servicing the unit first. There is an injector for the main pilot and a secondary injector for the flame thrower ignition. Both of these are prone to blocking due to dust and can be enough to shut the unit down. Although usually this is thermocouple related as you are manually keeping the unit running when you hold down the button, if the tcouple is broken it wont send enough millivolts to hold the magnetic valve open when you release the button.
Cheers
May 16, 2009 | Rinnai Heating & Cooling
DOMETIC RM 7651l HAVE POWER AND GAS TO THE FRIDGE BUT WONT START (TWO MONTHS OLD)
Igniting a Dometic gas fridge
    Electronic Ignition
    1. Open gas cylinder or pressure regulating valve
    2. Turn on Electronic ignitor switch
    3. Turn gas control knob to the MAX position, press and hold down
    4. After ignition, hold down knob for a further 15 seconds before releasing. The neon light will stop flashing
    Piezo Ignition
    2. Turn gas control knob to the MAX position, press and hold down
    3. After approximately 10-15 seconds
      press Piezo knob several times until pilot light a lit
  1. Check the Pilot light is alight
  2. The flame can be controlled by aperture ©
    Should no ignition occur, repeat the ignition process after 1 minute
    (This could take longer than 10 seconds if the unit has been out of operation for a prolonged period or after replacing the gas cylinder. (Cause: air in the lines)
  3. Once sufficient refrigeration has been obtained in the cooling tank at the MAX position, the control knob should be turned to the MIN position by low outside temperatures or when the refrigerator is only lightly loaded respectively the ambient temperature is below +18c in order to avoid over freezing the contents.
I hope this helps you...
Regards
Wouter...
Sep 30, 2008 | Refrigerators
Heating & Cooling Logo
85 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
