Question about Visonik V2508 2-Channel Amplifier
I can't seem to get out of protect mode. Any suggestions
    Scholar:
  • 113 Answers
Hi disconnect everything, inputs speakers and leave power. If still in protect mode then there is a circuit problem, will have to send it in.
Best of luck
Posted on Jul 15, 2009
Nad av 716 protect
If your NAD amplifier is in protect mode with no speakers connected, it will be necessary to open it up and check for internal component failure.
Jan 05, 2015 | NAD Audio Players & Recorders
I have a AVD-C700es and there is power going to the receiver but it won't turn on. Any suggestions? It seems to be stuck in standby mode!!!!!
Could be blown, most receivers now a days have overload protection that protects them, try disconnecting or checking your speaker wiring and turning it on again. Also try leaving it unplugged for a few minutes and trying again after. If all else fails, it is probably a internal fuse blown to protect the receiver, a repair shop will probably charge 100 to repair it.
Sep 07, 2014 | Audio Players & Recorders
Play truth or dare on my computer
It seems that your OS has registry problem, so I would suggest you to fix it properly with the help of these tips given below:-
- start PC in safe mode, normally Pressing F8 key when windows starts up.
- In Safe Mode create a new user, with administrator privileges and protect it with password.
- Remove any Antivirus.
- Download Intel software partner reliable program RegInOut to fix OS registry properly.
- Restart your PC normally and log on to the new account created.
Hopefully it will help you
Thanks
Jun 11, 2013 | Video Game Consoles & Games
I have an Yamaha RXV440. It goes into protection mode instantly.
The Yamaha repair shop evidently couldn't find the failed component(s) and/or cold solder joints causing it to go into protection mode. Sony equipment has similar problems related to protection mode.
Mar 21, 2017 | Yamaha RX-V440 Receiver
Hi, ive jus added a pioneer avh5900 in to my car.. the problem i get is when my volume reaches between 17-21 which does seem to blast my speakers, my sounds jus cuts out on the system, altho the system...
Hi does the amp go into protection mode? or does the sound dip and amp stays on? if it goes into protection mode there's a good chance your running the amp wrong. If it dips and stays on its a power problem that can be fixed by adding a farad capacitor.. thank you for using Fixya.com
Feb 09, 2010 | Pioneer AVH-P5000D Car DVD Player
Stuck in protect mode
Protet mode is a special diagnostic mode that starts when a fault is detected.
When in protection mode the unit is prevented from starting by protection circuit, so to prevent further damage.
Check the speakers and speakers wiring, a contact in speaker wires, or faulty speakers can send the unit in protection.
Try unplugging power cable for one hour or so. then connect cable back and see if you get rid of protect state. Sometimes accumulation of electrostatic charges inside circuit capacitors can kick in protect mode. In that case unplugging the unit from main for some times can get rid of electrostatic charges, and reset circuits by draining power completely.
If that was the problem, you will not get Protect when plugging back power cable.
If you do all the above and still get Protect, then there is a real fault.
In that case the unit may be disassembled and tested to find the fault.
If that is the case I suggest contacting the manufacturer at the number listed on the owners manual, or asking a quote on repair to a local technician.
May 04, 2009 | Sony STR-D1015
It seems the amps went into protect mode?
is any wires touching like in the speaker or @ the speaker or amp
Nov 16, 2008 | Phoenix Gold Car Audio & Video
Nad C370
Since the problem seems to be sensitive to the volume level, I would be looking at the output wave form for any DC current. Although the protection circuit should detect any DC present, it is possible that some is leaking through. Also, verify that the speaker impedence is correct. If the amp is seeing too low an impedence load, it will work too hard causing excessive heat which will shutdown the unit as well.
Keep me posted.
Dan
Nov 04, 2008 | NAD C370 2-Channel Amplifier
Protect Mode
There are bad connections on the main board that are effected by heat. I would suspect that when the volume level is higher, the system shuts down sooner. This should be a simple repair that will not require parts. If you can solder, you should be able to repair this yourself. If not, the cost will be the local labor rate.
Dan
Jul 21, 2008 | Sony STR-DE345 Receiver
Visonik V2508 2-Channel Amplifier Logo
81 people viewed this question
Top Visonik Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Visonik Audio Player and Recorder Expert? Answer questions, earn points and help others
