Need to change the ip address from 192.168.1.254.
How do you do this? I know he new ip i need set, but not how to change the router settings to out it in!
  • BIG BUILDER May 11, 2010
    WHAT MODEL ROUTER?
    Novelist:
  • 166 Answers
To gain access to your wireless router settings and configuration menu then connect to the router either wirelessly or via a Ethernet cable. Open a web browser and type either:
http://192.168.1.1 or
http://192.168.2.1
Posted on Jul 15, 2009
I stupidly changed a setting on my router configuration using the ip address in the address bar on my internet page , now i cant access it and change it back , i was trying to change my NAT type to open ,...
Press and hold RESET button for 10 seconds it is in the back side of router. Then all settings defaults. Then need to configure it with below method.
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. Then click on WAN settings set it as your internet service provider settings enable DHCP Then click on wireless and enable it. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Sep 09, 2011 | D-Link DIR-615 Wireless Router
Tip
Wireless printer goes offline
Let's set a static IP address for the printer:<br /><br />- Print a Network Config Page from the front of the printer. Note the printer's IP address.<br />- Type that IP address into a browser to reveal the printer's internal settings.<br />- Choose the Networking tab, then Wireless along the left side, then the IPv4 tab.<br />- On this screen you want to set a Manual IP. You need to set an IP address outside the range that the router automatically sets (called the DHCP range). You can change the DHCP range of the router using its internal settings page.<br />- Use 255.255.255.0 for the subnet (unless you know it is different, if so, use that)<br />- Enter your router's IP (on the Network Config Page) for the gateway and first DNS. Leave the second one blank.<br />- Click 'Apply'.<br /><br />Now, shut down the router and printer, start the router, wait, then start the printer.<br /><br />After this you may need to redo 'Add a Printer' using the new IP address.
on Apr 02, 2011 | Office Equipment & Supplies
I need to get into my nat settings
All Linksys routers have a built-in web-based setup page that allows the user to customize settings and set up advanced properties.
NOTE: Before accessing the router's web-based setup page, make sure the router is powered on and the computer is wired to one of the Ethernet ports on the router (1, 2, 3 or4 ).
Accessing the Router's Web-Based Setup Page
NOTE:To access the router's web-based setup page using Mac, click here.
Step 1:
Open a web browser such as Internet Explorer.
Step 2:
Go to the Address bar and enter your router's IP address ("192.168.1.1" is the default IP of most Linksys routers) then press [Enter].
NOTE : For WRP400, the default IP address would be "192.168.15.1" and if you place the router behind a primary router with the IP address of "192.168.15.1", then the router will automatically assume a new default IP address, "192.168.16.1".
NOTE: If the IP address of the router has been changed, type the router's IP address in the Address bar instead.
The router's IP address can be changed by:
1. Running the router's setup CD.
2. Changing it on the router's web-based setup page.
If you forgot the router's IP address you can:
1. Check the router's IP address. For instructions, click here.
2. Press the Reset button at the back of the router for 30 seconds.
NOTE
: This procedure will reset your router to factory defaults. Any settings on the router will be erased. The router's IP address will be "192.168.1.1" and the password will be "admin".
Step 3:
A new window will prompt for a User name and Password. Leave the User name field blank then enter your router's password ("admin" is the default password), then click OK.
If you forgot the router's password you need to reset the router. For instructions, click here.
Windows XP
Windows 7
NOTE:
If the password of the router has been changed, type the router's new password in the Password field instead.
The router's password can be changed by:
i. Running the router's setup CD. Click here to learn how to download firmware.
ii. Changing it on the router's web-based setup page. Click here to learn how to change password on the web-based setup page.
Unable to Access the Router's Web-Based Setup Page
Reset your router for 30 seconds. Try accessing again using the default IP address "192.168.1.1". If you are encountering problems accessing the router's web-based setup page, click here.
Related Articles:
Setting-Up WPA Wireless Security on a Linksys Router
Changing the Wireless Network's Name (SSID) on a Linksys Router
Setting-Up a Router with DSL Internet Service
Downloading at Linksys by Cisco Support Site
Nov 09, 2010 | Linksys Wireless-N WRT150N Router
I am trying to set up a new printer to a Linksys router model no WRT300 Ver 2.0. I have lost my IP no and also my Network Security Key, Is there any way to retreive these nos Gordon Stephens
The router can be set to factory default by performing either of these two steps:
Resetting the Router Using the Reset Button
Resetting the Router Using the Web-Based Setup Page
NOTE: Pressing the Reset button on the back of the router for 30 seconds will reset your router to its factory default settings. All of the settings of the router will then be erased and the router's IP address will become 192.168.1.1.
Step 1:
Step 2:
NOTE
Step 3:
Aug 21, 2010 | Linksys Wireless-G WRT54G Router
Someone has changed my IP address hacked into in my router
I am not that much clear whether you can change your Ip adress, but any queries regarding Ip-detais can be solved here, http://www.ip-details.com/
Jul 06, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
2 Pc's with same IP
AT either desktop or laptop:
[Start]
[Run]
[cmd]
A dark "DOS" windows will appear
At the prompt, type: ipconfig
press [ENTER]
Note the "IP Address" (probably 192.168.1.2)
type: ipconfig /renew
press [ENTER]
Note the IP Address
If it has changed, then you are ok. Type: exit and press [ENTER]
If it did not change, then try this on the other computer.
If that didn't change either, the go to the Control Panel
[Network Settings]
Find the wireless or wired network adapter and Right-Click
Choose "Prpoerties"
In the Properties window, double-click "IP Address"
See the IP Address assigned? change the last digit by one number.
Example: if the IP Address is 192.168.1.2 then change to 192.168.1.3
[OK] [OK][OK]
It should work now...
Let us know!
Sep 17, 2009 | Linksys Wireless-G WRT54G Router
How do i change my lan IP so my router works
Hi!
Start by opening up a web browser (it doesn't matter if it can get to the internet or not, as long as its from a PC connected to the router) and, assuming the LAN address is still the default, goto the address "http://192.168.2.1" click on "login" and you will be prompted for a password.
Again, assuming everything is still default the password is not set and you can just click "Submit."
On the left side you will see a menu, underneath LAN click on the "LAN Settings" link. You will be presented with a page were you can set a new IP address for the router. Once you change the IP and click "Apply Changes" the IP of the router will be changed. Once the device finishes restarting you will now have to use the new IP address you just entered, in you browsers address bar instead of 192.168.2.1, in order to see and configure the settings of your router.
Hope this helps! Here is a link to the manual for product incase you get stuck. The juicy stuff you want is on page 33.
Mar 26, 2009 | Belkin (F5D5231-4) Router
Need to change ip address for my camera
How is your webcam connected to your network? Is it connected to your PC or your router?
If it is connected to your router, go into the router settings and see if the router reassigned a new ip address to the camera. If you set the router up for DHCP, it will automatically assign IP addresses to all devices that are connected to it, as long as the individual devices are also set to dynamic IP addressing. Your router is set up for the 1.0 network, so your pc is most likely 1.2, while your router port connecting to your home network is 1.1.
Another thing you can do is make sure your webcam is turned on and go into 'My Network Places', then click on workgroup computers. See if the webcam is listed there.
Apr 11, 2008 | Toshiba IK-WB01A Network Camera
Adding wireless
for a dsl connection, what you need to do is check first the ip address of the router that you have or the mpdem that is given by your internet service provider. if it has an ip address of 192.168.1.X, then you need to change the ip address of the linksys router to 192.168.2.1 or 10.10.10.1. how to check the ip address? just connect your pc to the device and then open your command prompt, type "ipconfig" then click enter.. just look for the ip address.. also, if it doesn't work, then just set your modem to full bridge mode, your internet service provider will know about that.
Feb 20, 2008 | Computers & Internet
Computers & Internet Logo
123 people viewed this question
David Payne
David Payne
